Old Mar 25, 2001, 09:47 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
Best motor setup for Aspire glider
I just finished my Aspire EP glider, I was wondering what setups everyone was using on them as the stock motor probably wont fly it too well as the stock ones never do.
Steve H. is offline Find More Posts by Steve H.
Old Mar 25, 2001, 10:58 PM
Adam Neat is offline
Find More Posts by Adam Neat
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
Hi Cue; Check back a week or so. Marcus just got one up. I think he put a Magnetic Mayhem in his. Direct drive. He gave his impressions and some pictures also.
Adam
Adam Neat is offline Find More Posts by Adam Neat
Old Mar 25, 2001, 11:09 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
OK, I was thinking about trying that combo but wasnt sure if the 800ar's would handle the amps. I will probably try it tomorrow.
Old Mar 26, 2001, 07:59 AM
mthirsch is offline
Find More Posts by mthirsch
Alexandria
Joined Apr 1999
Cue, with the MM direct with stock prop and 8x800AR your Aspire will be very light. The 800AR seem to be handling 28 amps just fine, they just get a little warm. The cooling slot in the canopy helps.
If your 800AR are in a rectangular shape like mine (bundle) then you need to remove the battery tray so the pack can go all the way back. I have some pics that show how to make the pack easily removable like this without removing the wing, you basically line the sides with foam so the pack is snug, and then use a foam block with velcro to squeeze the front of the pack and hold it in place.
If you don't care about removing the wing then they'll fit ok as is.
I'll try to update my website to show this in the next couple of days.
The downside to the 800AR is you really only get about 1.5 mins climb (with reserve left over). These packs can charge so quickly that it doesn't matter if you have a few. The Aspire will really slow down at this weight, but does not handle much wind.
Enjoy!
Marcus
mthirsch is offline Find More Posts by mthirsch
Old Mar 26, 2001, 01:28 PM
mthirsch is offline
Alexandria
Joined Apr 1999
That's right, unfortunately. Plus any geabox will add 2 more ounces. I know, maybe I'm taking the weight thing too seriously for this big plane. I like the MM Direct solution because it only costs $20 and you can even use the kit prop. It works pretty well for direct drive. With a geared system like DrE suggests you will gain about 1/3 more climb in this situation.
Old Mar 26, 2001, 07:05 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
Well the only Mag meyham motor I had was a reverse one, but in my box I found a green car motor labled Lightspeed in a silver label so I thought I would give it a shot.
Using the stock prop and a 8 cell pack of 800ar's I got only 20 amps and 192 watts on a fresh pack. I will hopefully get to try this out tomorrow if the wind dies down.
Anyone know anything about the lightspeed motors? I semms I could probably use a bigger prop with it. It came out at 41 oz also.
[This message has been edited by Cue (edited 03-26-2001).]
Old Mar 27, 2001, 12:28 AM
dr.E is online now
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
The easiest upgrade is to use a graupner s600 inline planetary gb 8x800 and a 12x8 prop should do the job
dr.E is online now Find More Posts by dr.E
Old Mar 27, 2001, 12:54 AM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
OK, I would like to see the pics.
Also how much does that gearbox cost? every inline one I have seen costs at least $50.
Old Mar 27, 2001, 04:33 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
Well I flew it today, the results were kinda dissapointing. First it needed about 1/8 inch of right rudder just to fly straight, what couls cause that?
Then the lightspeed motor and 8 cells of 800ar's did not want to climb too well, the sub-c 1700's I tried climbed a lot better but still it would take forever to get to 500 feet like horizon states it will do on the stock motor. Alos the prop would not fold back at all and kept windmilling.
So where can I get a inline gearbox? and whats one of the best ones for it?
[This message has been edited by Cue (edited 03-27-2001).]
Old Mar 27, 2001, 10:00 PM
mthirsch is offline
Alexandria
Joined Apr 1999
Perhaps one wing is heavier than the other? Maybe some balancing of the wings would help...
The Dymond 3:1 inline works nicely.
Good luck,
Marcus
Old Mar 27, 2001, 10:05 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
I never thought about the wing weighing different, I checked and sure enough the left wing was heavier, it took a little more than half an ounce to balance it (quick test)
Old Mar 27, 2001, 10:54 PM
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
Yes you can get Dymonds Max05 motor and the 3:1 Gearbox for $59.99 if I remember correctly. Ive been using it with a 14x9.5 prop in a 70+ oz 100in glider. Its probably borderline as far as long term reliability the way im running it but I think in a 2 meter glider with a Graupner 12x10 it would be a pretty nice setup.
Adam
Old Apr 30, 2001, 10:54 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
Well after looking at it sitting in the corner for a while, I installed a cermark cobalt 05 motor with a sonic tronics 10x6 prop. It should climb well now on 8 cells
Old May 01, 2001, 08:56 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Neat, how well does that Dymond gearbox hold up? How many cells/amps are you putting through it? My brother just bought an Aspire to learn on. The stock setup burned up within the 1st 20 flights or so on 7-1900 and the stock prop. We tried a 6/1 Como Drill GB w/Sp600 and it tore up the GB only pulling 22 amps. We're looking for a sturdy and inline replacment with at least 3/1 ratio.
GregG is offline Find More Posts by GregG
Discussion Best BL motor setup for Kyosho F-16? Halifax1 Electric Ducted Fan Jet Talk 6 Jan 20, 2007 02:36 PM
Best Motor Setup For A T-Rex. Giglimesh Mini Helis 7 Aug 25, 2005 02:05 AM
best motor setup for mini funtana nappyroots2182 3D Flying 40 Feb 15, 2005 11:50 PM
Best geared motor setup for use with 4-cell 800mah Tadirans? Danny Troy Parkflyers 2 May 02, 2002 01:39 AM
Best motor and battery for X250 KatManDEW Sport Planes 18 Oct 08, 2001 12:11 PM
