Old Dec 04, 2008, 08:52 AM
Phiber Optik is offline
Find More Posts by Phiber Optik
Womb Drifter
Phiber Optik's Avatar
NC, USA
Joined Dec 2004
pyrsly,
I really dig your sanded wing! Great setup!
How long does it take you to shape a panel minus the freehand detail/touchup work?
You must come out of your shop looking like you dove into a bag of flour!
Phiber Optik is offline Find More Posts by Phiber Optik
Old Dec 04, 2008, 11:18 AM
2motheus is offline
Find More Posts by 2motheus
3 Sons - Legos and Lift
2motheus's Avatar
Grand Rapids, MI
Joined Apr 2004
Resin?
pyrsly,
How are you applying the fiberglass skins without bagging - resin or water-based varnish?
Do you work on just one surface at a time?
If it's resin, how do you keep the weight down?
Your results look good.
Tim
2motheus is offline Find More Posts by 2motheus
Old Dec 04, 2008, 12:45 PM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
Simply spray foam with 3M77 and drop on flat spread glas. Cut exes glass fold edges and do whatever you need. Repeat on other side. Soak whole thing wet in epoxy than gently remove exes using squidgy and paper towels. Wing ready!
Wait for more photos you will se.
pyrsly is offline Find More Posts by pyrsly
Old Dec 04, 2008, 04:15 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
Originally Posted by Phiber Optik
pyrsly,
about one hour for bouth panels
Old Dec 05, 2008, 06:06 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
Gratings!
I decide to experiment with torque web similar to Fireworks 3 and 4. All I goth left to do is epoxy everything together. I hope that wax paper trick will work. Before I was just mounting outerskin to core and soaking from outside. I'm expecting weight reduction. I guess I could put all reinforcement on wax paper and mop even more epoxy but I wont take small steps, maybe next time.
Old Dec 05, 2008, 07:03 PM
j.m. is offline
Find More Posts by j.m.
Don't worry about it!
j.m.'s Avatar
Raleigh NC
Joined May 2008
Nice!
Most manufacturers make the webs get closer together at the root, instead of evenly distributed, but what you did should work fine.
Like this:
http://www.pcm.at/fw4/pic-gr/F4-TS4.jpg
http://www.pcm.at/fw4/pic-gr/f4-DISS.gif
http://www.linkage.jp/F4-S4.jpg
Looks to me like you should be making a hotwire cutter and starting to experiment with different types of foam...
j.m. is offline Find More Posts by j.m.
Old Dec 06, 2008, 08:20 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
uff
Old Dec 09, 2008, 06:15 PM
Larry051967 is offline
Find More Posts by Larry051967
Joined Jul 2007
Has anyone tried Icarex in stead of f/glass for their home-builds?
http://ecom.citystar.com/hang-em-hig...FABRIC&pgidx=0
There are lots of ways to do it and this is an example of how some combat fliers use it.
http://www.tufflight.com/icarex.html
I have used a single layer for coverings and multiple layers to make a tapered re-enforcement. It weighs 1/2 oz/sq yard. It's woven but does not stretch like rip-stop nylon does. I have used it on a wing that I change the tension on during flight to change flight characteristics. I did a landing that put the wing into a chain link fence post and it only put a small dent in the foam which came with a little work. The fence post jumped into my path quicker than I could avoid it (lol).
Larry051967 is offline Find More Posts by Larry051967
Old Dec 10, 2008, 06:49 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
I'm really happy the way things turnout. Wing is extremely stiff in torsion and wax paper trick made nice finish. It's time to cut flaperons and servo bays. More pictures coming soon!
Old Dec 17, 2008, 06:12 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
it's coming along...
Old Dec 22, 2008, 07:35 AM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
Fresh photos. U can't beat Florida weather!
Old Dec 23, 2008, 07:18 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
one picture for thousand words + hot like Florida weather slide show http://www.rcgroups.com/forums/showthread.php?t=971893
Old Dec 24, 2008, 07:08 AM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
can you post photos and templates of how you made the pod?
LittleG is offline Find More Posts by LittleG
Old Dec 24, 2008, 01:44 PM
Mun is offline
Mun
Find More Posts by Mun
Mun
Joined Dec 2008
Nice glider! I'd like to build something like this. Can you please post the plan?
Mun is offline Find More Posts by Mun
Old Dec 24, 2008, 05:04 PM
chucker is offline
Find More Posts by chucker
swanton, vermont
Joined Apr 2005
Fort Zachary?
The back ground in your photos looks like Fort Zachary. Could it be?I'll be there next March. I hope to see your good work in the air.Thats a neet project you have going, keep up the post & photos
chucker is offline Find More Posts by chucker
Rave Home build whith chainsaw... hamder Large Scale Cars 24 May 01, 2009 05:07 PM
Question Mig 15 home build parabelum Electric Ducted Fan Jet Talk 8 Sep 08, 2004 10:18 AM
home build zagi thingy Taco RC Foamies (Kits) 2 Dec 02, 2003 04:13 PM
home-build helicopter boxed Electric Heli Talk 0 Sep 05, 2001 05:05 AM
