Old Nov 29, 2008, 06:24 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
That'll be awesome... Where do you typically fly in Raleigh?
Originally Posted by j.m.
LittleG,
My dad is letting me make a hotwire cutter, so maybe we could set something up...
I could probably hook you up with a couple sets of cores.
LittleG is offline Find More Posts by LittleG
Old Nov 29, 2008, 09:10 PM
j.m. is offline
Find More Posts by j.m.
Don't worry about it!
j.m.'s Avatar
Raleigh NC
Joined May 2008
Not doing too much flying right now...
All my planes are broke.
If I am flying, you'll see me at the AE Finley YMCA or the Leesville Elementary School athletic field.
Those big green monsters give me nightmares!
j.m. is offline Find More Posts by j.m.
Old Nov 30, 2008, 04:46 PM
Psychotica is offline
Find More Posts by Psychotica
AKA Captain Nifty
Psychotica's Avatar
Ontario, Canada
Joined Jan 2002
Gorgeous homebuilt! An inspiration indeed!!
Psychotica is offline Find More Posts by Psychotica
Old Dec 01, 2008, 07:49 AM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
Thank You! I Appreciate yours appreciation. I wood be happy too build one to order.
pyrsly is offline Find More Posts by pyrsly
Old Dec 01, 2008, 09:15 AM
j.m. is offline
j.m.'s Avatar
Raleigh NC
Joined May 2008
What kind of foam are you using?
And if you were to sell, how much would you ask?
Old Dec 02, 2008, 06:08 PM
LittleG is offline
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Thank you for all your efforts in taking photos and posting them here... I really appreciate it.
Your sanded wings look just as good as those wire-cut ones... Sanding the wings must create a ton of foam dust.
Originally Posted by pyrsly
This is about foam and sanding.
Old Dec 02, 2008, 06:22 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
yes it's messy bat taking photos was pure fun! I will post more pictures once i finish spar, reinforcement and glassing.
Old Dec 03, 2008, 03:44 PM
RU4GOD2falcon is offline
Find More Posts by RU4GOD2falcon
Joined Sep 2007
nice plane
RU4GOD2falcon is offline Find More Posts by RU4GOD2falcon
Old Dec 03, 2008, 05:44 PM
John255 is offline
Find More Posts by John255
Pensacola, FL, USA
Joined Dec 2000
Pyrsly,
Man, that is a fantastic shop.
I love to see pictures of creative clutter. Just like home for me.
I know a guy who paints the floor of his shop gray. He never makes anything!
Your DHL design .pdf is slick.
I see you also understand the advantage of CR2 cells. Rare!
Regards,
John255
John255 is offline Find More Posts by John255
Old Dec 03, 2008, 06:50 PM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
Thank You for good word. CR2s ar full of energy and voltage is just right. shame that I can't find rechargeable. easy replaceable with 4x1/3AA 280-300mA NiMH witch can reach 5.5V fully charged bat lasts only fraction of CR2s. Presented plans can be improved by shortening boom by inch or two, les led in nose but smaller static margin. Main idea was to reduce yaw inertia by moving E/R servos to center section of wing, simplifying pod and shortening pushrods. In addition this layout allows stronger wing (center must be reinforced) and running pushrods on outside of pod. Here is more pictures.
Old Dec 03, 2008, 07:21 PM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
Pyrsly,
New wing looks great!
If you are adding lead with CR2's you may get much greater service with CR123 cells.
They are 6g. heavier than CR2, but have nearly double capacity (1550mA). Here is a link showing same cell in double package (CRP2) for $3.30.
http://www.calcellular.com/crp2-dl223.html
Good luck.
John255
Old Dec 04, 2008, 07:25 AM
pyrsly is offline
pyrsly's Avatar
Joined May 2008
Try this http://www.megabatteries.com/cat_fea...d=223&uid=1426
and this http://www.all-battery.com/polymerli...mah501638.aspx
220 mA in les then 10g
Old Dec 04, 2008, 07:46 AM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
Those are all rechargable cells. Most guys that have experience with CR2's would never go back to charging/cycling. Camera batteries are cheap, safer, and always ready.
So why are they safer? Every battery has a fairly flat current output but when the charge is used up you reach the "avalanche" point where the voltage drops quickly. I face the "avalanche" with some slight risk about every 22 flying hours. With typical small packs you may face avalanche every 1.5~2 flying hours. And that is if your charger has cut off at the right peak and the cells are really fully charged.
The CR123's are predicted to nearly double that time, but I'm still evaluating that.
Regards,
John255
Rave Home build whith chainsaw... hamder Large Scale Cars 24 May 01, 2009 05:07 PM
Question Mig 15 home build parabelum Electric Ducted Fan Jet Talk 8 Sep 08, 2004 10:18 AM
home build zagi thingy Taco RC Foamies (Kits) 2 Dec 02, 2003 04:13 PM
home-build helicopter boxed Electric Heli Talk 0 Sep 05, 2001 05:05 AM
