Old Aug 11, 2008, 01:43 AM
dj_d is offline
Find More Posts by dj_d
USA, WA, Seattle
Joined Jul 2007
DX6i for differential thrust - impossible?
I've been trying to program my DX6i for differential thrust. My idea was to put one motor on throttle and one on rudder. Then mix like this:
Mix 1: Throttle -> Rudder 100% 100%
Mix 2: Rudder->Throttle 100% 100%
What I found is that the rudder motor works as expected, but the throttle motor doesn't seem to do anything differently. That is, the rudder channel doesn't affect the throttle.
Any ideas? Anyone get differential thrust working on the DX6i, maybe with a V-tail mixer?
Thanks!
PS: working on this:
http://sketchup.google.com/3dwarehou...67&prevstart=0
dj_d is offline Find More Posts by dj_d
Old Aug 11, 2008, 07:29 AM
el_tel is offline
Find More Posts by el_tel
Joined Nov 2007
diff thrust on dx6i
hi
it's easy when you know how:
turn on dual airelons in wing type
mix throttle to flaps (aux) d +100 u +100
reverse airelon (not flap)
can set 100% differential to stop one motor slowing when turning (other motor speeds up).
Connect one motor (via esc1) to rec airelon, and the other (via esc2) to rec aux. Dont forget to disconnect one of the red wires (centre) from the plug or you'll blow your reciever.
you'll need to play around with dr, travel adjust, and expo, to suit your model. It's easy to create wild oversteer.
tel
el_tel is offline Find More Posts by el_tel
Old Aug 11, 2008, 07:31 PM
dj_d is offline
USA, WA, Seattle
Joined Jul 2007
Brilliant, thanks! I've been playing with it and had both ESCs on different batteries with their BECs connected to the receiver... sounds like that's not such a clever idea.
I'll give this a try tonight.
Problem though: this is going to be an elevon bird. I want rudder connected to differential so I can use elevator/ailron for the elevons. Any ideas for how to make that work?
Old Aug 12, 2008, 12:23 AM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
The reason why this mix doesn't work is the dx6i software has a bug. And as a result throttle can't be used as a slave.
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Aug 12, 2008, 01:25 AM
dj_d is offline
USA, WA, Seattle
Joined Jul 2007
Kwok - thank you! That explains the problem I'm seeing. That stinks, though.
Old Aug 12, 2008, 11:07 AM
el_tel is offline
Joined Nov 2007
closer... but still not quite there
by using the v-tail wing type in addition to what I said above, you can get a bit closer:
turn on v-tail wing type (keep dual airelons)
connect airelon1 to rec elev and airelon2 to rec rudd
airelons will be left stick instead of right, elevator right stick as usual, and you can't use differential on the airelons as that's routed to the other channels.
The problem is essentially that there's no provision for twin engine setups on any trannys I've seen, which I find surprising. Surely even if diff steering is not required then there would be the need to balance motor output?
tel
Old Aug 12, 2008, 06:18 PM
dj_d is offline
USA, WA, Seattle
Joined Jul 2007
It sounds like the dx6i could ALMOST do it except for that darn firmware bug.
Old Aug 14, 2008, 02:05 AM
el_tel is offline
Joined Nov 2007
yeah, you're right. I think the DX7 can do it.
Old Mar 15, 2009, 09:29 AM
Dick Adams is offline
Find More Posts by Dick Adams
Dick Adams's Avatar
Michigan's U.P.
Joined Dec 2003
U.P to El-Tel!
El-Tel, if I am following what you are doing, do you end up with the differential throttle steering on your right stick?
Having trouble thinking this through!
In a 3 flight control channel flying boat, I put the rudder on the aileron channel output so I am flying on the right stick. So that wouldn't work on a rudder elevator ship? If I am following, your setup could work on an aileron ship, or no?
Dick
Dick Adams is offline Find More Posts by Dick Adams
Old Mar 15, 2009, 11:04 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
As I mentioned in your other post - you need two channels (one foreach motor - *modified by the throttle )
ther is nothing wrong with the DX6i-
* or modified by the rudder
richard hanson is online now Find More Posts by richard hanson
Old Mar 15, 2009, 08:34 PM
Dick Adams's Avatar
Michigan's U.P.
Joined Dec 2003
Redux, et al...
Richard, I tried to follow what you wrote in my earlier thread, but couldn't follow all of it! When I asked some follow up questions, I didn't hear back from you. I reread it and still am having problems.
http://www.rcgroups.com/forums/showthread.php?t=1013553
Here's one part that you wrote that still throws me now that Horizon has confirmed a programming bug:
"If rudder is master- throttle can INCREASE or DECREASE as rudder is moved left OR right."
What's wrong with the Dx6i according to Horizon, not me, is that the throttle channel cannot be a slave!
The reason I posted on this thread is that work arounds were being discussed. Do you have a work around for the Dx6i bug that doesn't require making throttle a slave?? I would love to hear it and try to understand it if you do.
I am new to mixing and computer radios, but am an old dog who still tries to learn new tricks.
Dick
Old Mar 15, 2009, 08:56 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
Hello Dick Adams,
I didn't see your last post, until I went back to that old thread to reread what "richard hanson" wrote again. All I can say is, none of it makes any sense to me and I am not a noob. It's easy enough for him to me wrong by providing the proper DX6i settings.
-Kwok
Old Mar 16, 2009, 07:04 AM
Dick Adams's Avatar
Michigan's U.P.
Joined Dec 2003
Mornings are a good time to fish!
Good morning, Kwok!
Well, glad to see it's just not me. But Richard tried to write a mixing primer for me, and the center power off thing did turn on a light and got me a step closer to understanding this stuff. You thought a primer wasn't needed.
I keep proving that it is!
Let's see if Richard will take the bait.
TTYL,
Dick
Old Mar 16, 2009, 07:58 AM
Joined Oct 2007
Why solve it for you - that would spoil your fun!
Hint:
two ouputs -one for each motor is needed .
a master which modulates each is also needed.
here is a picture of a more involved mix
A-rudder deflection moves both halves of air brake as a normal one piece iem
B- low engine settings open airbrake porportionately (power setting increases spread of halves)
C-elevator is trimmed down porportionately (trim) as brake is deployed
It all worked as noted I did this one 10 years ago using a JR10 tx
Someone else has also posted what looks to me like a working setup for the DX6i- but I have not tried it. I think it was basically, two throttle outputs modulated by the rudder channel.
Old Mar 16, 2009, 12:27 PM
Dick Adams's Avatar
Michigan's U.P.
Joined Dec 2003
Mission Impossible Assignment Accepted!
Hah! A mystery assignment with clues. I am game. But the rules are:
1. only 2 mixes allowed (as that is all the Dx6i has!), and
2. throttle can't be slave, and, last
3. can't have a weird result, like my present "lame duck" mix of throttle to rudder that requires the reflexes of a cat and the memory of an elephant, both of which, trust me, I lack
Fair?
Had my Tx packed up to ship back for the stick pot inspection, but will unbox and tackle this tonight.
TTYL,
Dick
Ps: Richard, are you sure enough about this to bet something really valuable, like a 6 pack of good beer??
Mini-HowTo Dual ESC's for Differential thrust rudder control UNGN Power Systems 29 Mar 10, 2012 04:18 PM
Question How to mix differential thrust for rudder? dagauss Power Systems 0 Oct 19, 2006 04:20 AM
Discussion Differential thrust for A-10? Fiasco Radios 7 May 12, 2006 07:20 AM
need ideas for fast differential thrust plane devilscries Flying Wings 22 Jul 17, 2004 09:29 PM
What parts for differential thrust? J Cubed Power Systems 5 Jun 22, 2001 05:47 AM
