Old Aug 08, 2008, 03:35 AM
GeorgeC is offline
Find More Posts by GeorgeC
GeorgeC's Avatar
Perth, Tasmania, Australia
Joined May 2000
Hacker B40-5L 4.4:1 LiPo question
I have a Hacker B40-5L (carbon) 4.4:1 in my 2m Organic. I am currently using a 14x9.5 with GP2200's. I am looking to move to LiPo and have been told that 2S is the maximum. I have tested this on a Hyperion 2S 3300 but I am only able to draw around 40A. Volts drop quickly to about 6.4 and only 270W.
I read reports of people with the same battery but using 15X8 drawing 100A! Does anyone have any experience with this set up?
George
GeorgeC is offline Find More Posts by GeorgeC
Old Aug 08, 2008, 03:42 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Hi George
How many GP cells are/were you using?
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Aug 08, 2008, 05:29 AM
GeorgeC is offline
GeorgeC's Avatar
Joined May 2000
Originally Posted by cvanscho
Hi George
Hi Chris,
Sorry, I should have said 7 cells (this complied with the 7 cell LMR competition). I am now restricted to 6600mAh for LiPo which is 2S 3300 or 3S 2200 etc.
I was advised by Hacker USA that 2S was the limit for the B40-5L.
George
Old Aug 08, 2008, 05:34 AM
CV580drvr is offline
Find More Posts by CV580drvr
Super Secret Agent
CV580drvr's Avatar
Sink City, USA
Joined Oct 2007
George...just to clarify something here.
2S 3300 is still 3300ma. 3S 2200ma is still 2200ma. A series connected battery does not increase the "capacity"....only the voltage.
Paralleling cells is another story. Voltage remains the same, and capacity increases.
That said...
You might get more feedback to your question by posting it in the "High Performance" section above. I'm sure somebody there can help you make your Hacker glow cherry red!
CV580drvr is offline Find More Posts by CV580drvr
Old Aug 08, 2008, 05:35 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No, you can run 2s 6600mAh. The mAh is the cell capacity, doesn't matter how many you have in series (although, in the case of 7-cell LMR, you're limited to 2s LiPo)..
I use 2s Neu 4900's - which is a little lighter than 7-cell 2200 - and just a tad over 100A for the 45s task. They must be warmed up before the flight, however, for peak performance.
..a
Old Aug 08, 2008, 06:17 AM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
George
George I am doing some figuring for the Aussi LEG rules (6600 ie 2x3300mah ...3x2200mah etc)
I have the carbon 5l hacker on the bigger g/box 6.?/1
got if off rcgroups from ClayH
Testing with 17x13 rfm prop .. you will have to work backwards from this for your props
Tested the rfm 17x13 on the rfm prop hub (38mm yoke?) with the master 105 controller
firstly 2s with my 2500 neu 30/60 pack 97/102 amps 4400/4700 rpm
3s 5000mah 30/60 neu pack =====> prop flew off - doh!!!!
retest...
175/180 amps 5200/5700 rpm give or take a few, little difficult doing
all this on my own and keeping the bursts down to 3 seconds. 17x13 looks like
too much prop for leg 3s 2200 cells?
temps after 3s 5000 tests 4 bursts of 3 seconds in quick succession..
Motor 43 degree C and controller 41 degree c.
Although the 3s tests are way outside the controller and motor
recomendations and will be outside a 3s 2200 batteries ability
it did show what was possible
>warm battery.. I am finding out about this now that winter has hit QLD. I am using neu 2s 3300 cells driving a hyperion z3025/6 at 70-80amps and find that i have to warm up the batteries so that the LVC doesn't prematurly cut in on my hyperion opto 80 controller.
cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 08, 2008, 08:29 AM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
..a
Andy, you sure about that? I read the rules differently, this is from the rules LEG rule book:
LiPo cells up to 6600 cell-mAH max
Li Ion cells up to 10000 cell-mAH max
The maximum Cell-mAH of a flight pack is found be multiplying the number of individual cells in the pack by their rated capacity. This must be below the limits shown above.
Some examples of valid packs are:
2S 3300, 2S 3200 mAH Lipo
3S 2200, 3S 2170 mAH Lipo
4S 1600, 4S 1500 mAH Lipo
5S 1200 mAH LiPo
4S 2300 mAH Li Ion (A123 cells)
7 * GP 3700, GP 2200, IB 4200 (or any other) NiMh
6 * any NiMH cells
Or, are we talking a different event?
Ed
www.commonsenserc.com
Ed Franz is offline Find More Posts by Ed Franz
Old Aug 08, 2008, 10:09 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
OK, they have their own rules, sorry. 7-cell sailplane (Class A over here) AMA event has been modified to "8.4V nominal" which is 2s lipo, of ANY capacity.
..a
Old Aug 08, 2008, 09:40 PM
GeorgeC is offline
GeorgeC's Avatar
Joined May 2000
Hi all,
Thanks for the replies. Just to clarify, the 6600mAh is a "nominal" figure used to limit LiPo use in our local LEG competition. In the same way 7 cell was used previously. i.e. it is the product of multiplying the #cells by the capacity and is limited to a maximum of 6600 (2x3300, 3x2200 etc). I am still a little perplexed as to why I only get 40A?
George
Old Aug 08, 2008, 09:50 PM
brisbane australia
Joined Nov 2002
Temp of the 2s pack prior to testing? - Was it cold - are we talking Tasmania here, only 100NM from the South Pole and it is winter?
What amps and volts did you get with 14x9.5 with GP2200'
Old Aug 08, 2008, 11:03 PM
GeorgeC is offline
GeorgeC's Avatar
Joined May 2000
Jeff,
Yes it is cold here in Tassie .We struggle to find thermals in our AEFA LEG events (unless they are the ones we are wearing ). I don't really have anything to test the LiPo temp (maybe if I tape my sensor to the pack?)
I'll set up the GP2200's again and do a test (I usually charge at 4.5A to get some heat in them first). I'll report back tomorrow.
George
Old Aug 09, 2008, 01:29 AM
Super Secret Agent
CV580drvr's Avatar
Sink City, USA
Joined Oct 2007
Jirvin...
Innocent bystander here in the Arc welder forum but...
Unless you're loading your system the same....you can't deliver the same amperage. You're running 40A....they're running 100+. It's not battery temp.
Crank up the prop size until stuff starts burning...then you'll be there.
Old Aug 10, 2008, 02:24 AM
GeorgeC is offline
GeorgeC's Avatar
Joined May 2000
Originally Posted by CV580drvr
Jirvin...
I agree that cranking up the prop size will increase the amps but we should be comparing apples with apples. I am comparing my 14x9.5 getting 40A on a 2S3300 LiPo with their 100A on a 15x8.
My readings using 7xGP2200 charged at 4.4A
Prop 15 x 9.5
Charge finish temp 27degrees C
Volts 6.7
Amps 77
Watts 516
RPM 5730
Prop 14 x 9.5
Volts 6.84
Amps 69
Watts 469
RPM 6060
My test with Hyperion LVX3300 2S
Prop 15 x 9.5
Charge temp 15degrees C
Volts 6.5
Amps 55
Watts 360
RPM 5025
Prop 14 x 9.5
Charge temp ?
Volts 6.33
Amps 39
Watts 252
RPM 4500
Strangely Electricalc estimates 120A for the 2S and 14 x 9.5 setup and 103A for 7xGP2200.
I'm still at a loss.
George
Old Aug 10, 2008, 04:36 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Maybe the motor is mislabeled.
Are your batteries 40-50 C?
I am perplexed as well. You should be drawing more current.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Aug 10, 2008, 04:55 AM
GeorgeC is offline
GeorgeC's Avatar
Joined May 2000
I can't see the motor as being mislabeled - I bought them new.
Battery is 25-40C (40C short burst)
George
hacker b20 12l 4;4;1 lipo question snowfallonme Power Systems 2 Jan 10, 2005 08:19 AM
Ebay: New Hacker B40-8S + 4.4:1 GB & MASTER 70-3P opto Esc rck Aircraft - Electric - Airplanes (FS/W) 0 Jan 01, 2003 05:20 AM
FS: New Hacker B40-8S + 4.4:1 GB & MASTER 70-3P opto Esc rck Aircraft - Electric - Airplanes (FS/W) 24 Dec 31, 2002 12:05 AM
FS Hacker B40 8L+4.4:1 Barye Aircraft - Electric - Airplanes (FS/W) 6 Aug 14, 2002 06:38 PM
FS: Hacker B40 8S 4.4:1 + Jeti 40 Atindra Aircraft - Electric - Airplanes (FS/W) 3 Jun 25, 2002 05:10 PM
