Old Mar 31, 2011, 03:24 AM
anestetico is offline
Find More Posts by anestetico
Brazil
Joined May 2009
Originally Posted by thomasscherrer View Post
you need a large directional antenna, to be able to seek and find lost stuff,
why not let this antenna be the one you use for video,
and save the money on other things you try not to have any use of anyway.
I found my lost funjet with a patch antenna, the camera on it was disconnected by the impact, I simply pointed to where the fuzzy screen was a little more black, It was 2 km far away, That time I was very very lucky too
http://www.baronerosso.it/forum/atta...8122010184.jpg
http://www.baronerosso.it/forum/atta...8122010183.jpg
http://www.baronerosso.it/forum/atta...8122010185.jpg
I am using a GPS-GSM tracker in my cularis, I have 1260 txv and Thomas 433, I hope GSM doesn't give me problems.
anestetico is offline Find More Posts by anestetico
Old Mar 31, 2011, 04:17 AM
hartwig is offline
Find More Posts by hartwig
Joined Oct 2006
Originally Posted by Rastislavko View Post
Thank you very much. You are true, so I'll not try to run both systems. But mostly you don't have video right into the ground. For the first longer flights I'll only use locator buzzer and later I will perhaps order this one and set it to activate after 2 hours - if I will not find my plane up to two hours, any further interferences will not harm it any more... :-)
I highly recommend using a GPS tracker and a beeper. As long as there is GSM coverage at the crash site (and the tracker has not been destroyed in the crash), you will get exact positional information where to look for the plane, right onto your phone. (btw, 446MHz is typically used for cheap PMR radios. So if you want to go this way, it would be a good idea to feed it with encoded GPS derived positional data).
hartwig is offline Find More Posts by hartwig
Old Mar 31, 2011, 04:18 AM
hartwig is offline
Joined Oct 2006
I am using these trackers for years now and have not noticed any interference with any LRS system I've used so far.
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
I do nok like when people put words like "hope" into FPV installations..
you must KNOW !!
the problem with GSM devices is they are VERY hard to test for jamming of other units.
you know GSM devices automaticly change band and tx power
depending on where they are located and how they receive from the tower,
this means you can test all to be perfectly fine while on one location
at one time of the day, and maybe NOT while flying, so be very cautions with this.
thomasscherrer is offline Find More Posts by thomasscherrer
Old Mar 31, 2011, 04:21 AM
Joined May 2007
that is offcourse very good info,
what mount distance, and mode of opperation of the tracker ?
I always play the VERY safe, and VERY cautions type of game,
I know it is ignoring to listen to all the time, but I prefer people do not have any tech problems
and crash that can be avoided with smart thinking
Old Mar 31, 2011, 04:28 AM
Brazil
Joined May 2009
you must KNOW !!
Sorry but that's why I said hope, I've tested it on the ground calling with my phone but I can't test it on the whole run without flying it, I've put it near the motor, very far away and I have a very well working RTH.
Old Mar 31, 2011, 04:40 AM
smoln1 is offline
Find More Posts by smoln1
2R Fly Team
smoln1's Avatar
Slovenija, Radovljica, Radovljica
Joined Jul 2009
Hello!
Do you have a possible connection diagram six pin connector Futabo T10cg for LRS Tomas Scherrer? Everything I tried, but it does not work.
smoln1 is offline Find More Posts by smoln1
Old Mar 31, 2011, 04:59 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Here is the diagram:
The picture is from the connector on radio, so you have to match your trainer plug correctly. You have to bring black wire (PPM signal) to the number 3, red cable (power) to the number 5 and shielding wires (ground) to the number 2.
(source: http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb3.htm)
Rastislavko is online now Find More Posts by Rastislavko
Old Mar 31, 2011, 06:00 AM
Joined May 2007
be carefull about thrusting the color of the cables of student cables !!
I have seen it mixed a few times !
check and double check, before you connect to LRS TX
Old Mar 31, 2011, 07:08 AM
Joined Jun 2006
Thomas: You can buy spare futaba square trainer plugs... So no need to bother with cables and their colors... Something like this one: http://www.flytron.com/22-futaba-mini-square-plug.html - you may offer them for customers with futaba radios :-) Even though I prefer module installation...
Old Mar 31, 2011, 09:33 AM
Joined May 2007
I prefer to let customers get their own connectors this way I can focus on things
only I can solve, and this way keep a good quality vs price ratio.
Old Mar 31, 2011, 09:56 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I been offering a futaba adapter in my shop for a while, approx one customer out of two order it. It plug into the trainer port and let you plug a battery, the LRS and a tracker.
It contain a relay that click on when you power the radio, so very little power is drawn from the trainer connection. It then feed the LRS + tracker from the external batt.
I also offer radio integration to those who want to ship their radio.
http://www.truerc.net/canada/shop/lo...f_systems.html
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Mar 31, 2011, 10:23 AM
PnoT is offline
Find More Posts by PnoT
PnoT's Avatar
USA, NV, Las Vegas
Joined Jan 2011
I have a DX8 and I'm trying to figure out how I can setup the AIO goggles and the TLRS together. Any ideas?
PnoT is offline Find More Posts by PnoT
Old Mar 31, 2011, 11:04 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I think the DX8 cannot output and input PPM at the same time.
You will need some kind of mixers, I know FMkit here sell such device, I ordered some, but they never worked properly.
-Hugo
Old Mar 31, 2011, 12:14 PM
PnoT is offline
PnoT's Avatar
USA, NV, Las Vegas
Joined Jan 2011
-Hugo
I'd really hate to have to buy a new TX...
Will a Futaba do HT with the all in one googles & TLRS at the same time?
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 502 Jun 10, 2015 07:16 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 06:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 08:24 PM
