Old Mar 16, 2011, 08:31 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Ouch, too late :-) who was the first one? :-)
Oh my... So... It looks like it wasn't THAT late!
Hoooraaah! I'm now happy as Emmett Brown on my picture :-) Thanks to Thomas for this funny and really unexpected surprise!
For those who haven't seen the previous qr-coded picture, the text was: "Have a nice day, fly safe ! The best of luck greetings from Thomas Scherrer Denmark - SPECIAL SECRET CONTEST !! the first one who email me : GIVE ME A FREE NR8 RECEIVER, will actually get it .. no joke !!"
I had a terrible week, I've destroyed my Headplay and crash my multicopter and get ill... but I hope all the bad is away now :-)
Again, many thanks to Thomas!
Rastislavko is online now Find More Posts by Rastislavko
Old Mar 16, 2011, 09:35 AM
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
hehe, your luck is about to change
thomasscherrer is offline Find More Posts by thomasscherrer
Old Mar 16, 2011, 12:30 PM
Husky2000 is offline
Find More Posts by Husky2000
I Love Tea!
Husky2000's Avatar
North East England
Joined Oct 2009
You lucky
Well done Rastislavco
I think I must have checked the thread about 10 mins too early to see your post Thomas. Oh well, maybe next time
Husky2000 is offline Find More Posts by Husky2000
Old Mar 16, 2011, 01:14 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Congrats!! Really cool Thomas.
bracky72 is offline Find More Posts by bracky72
Old Mar 16, 2011, 02:47 PM
Joined May 2007
your price is now packed, will be send tomorrow !!!
it only took 45 mins from I posted the first code, before it was broken
and I got the winner email.
wow I love when people win stuff they can use.
With other words my point is also this simple :
with me and my system, you luck is about to change to something better,
just get used to it.
Old Mar 16, 2011, 03:22 PM
barney1959 is offline
Find More Posts by barney1959
Joined Oct 2010
Hi thomas, I got my TLRS working and binding on the bench no problems. Thank You.
What I have done is used an old Futaba 9z. I removed the 35Mhz module. Next I opted to unsolder the Din plug socket from the 9Z circuit board and wired the TLRS directly to the circuit board at this point..
I have removed the 9Z battery and replaced this with a 3S 2250 Lipo to power the Tx via the standard battery box. This all appears to be working correctly prior to proper range checking. Does this all seem OK so far.
My next problem is with the wiring of the OSD (EzOsd) and Camera etc. How best can I provide a stable 5V supply to both my camera and VTR via a 4S Lipo. The TLRS RX/2 Elevon servos will be powered via the Esc's BEC.
Ideally I would like to run everything from the 4S Lipo. Vtx is a Lawmate 2.4 500mw and camera is a KX-201 5V
I was wondering If I could fit a Recom R-78B5.0-1.5 http://uk.rs-online.com/web/search/s...&cm_vc=prev_uk
Also would it be advisable to use a shielded cable to the VTX on the wing tip? and also add some LC filters such as these http://www.rcgroups.com/forums/showp...&postcount=339
Excuse my total ignorance of everything electronic but if so where exactly is it advisable to use the LC filters.
thanks
barney1959 is offline Find More Posts by barney1959
Old Mar 16, 2011, 04:02 PM
Joined May 2007
I dont know if the Recom conveter will work,
you must read its datasheet carefully, and add all the external capacitors and filters
so you are sure it is clean enought for your needs.
Yes, put the VTX on the wing tip, far away from sensitive stuff,
use shielded wire for the video signal, and local 1000uF cap on the VTX supply
that did the trick with my own install.
well about the toroid filter you linked to, be very carefull about it,
if done wrong you only make things worse, you see the VTX also need a video signal,
so make sure its video coax go inside the toroid too, ideally hold the power and coax
together, and then wind tru the coil, put the coil 1 wavelength from the VTX
and the cap as close to the VTX as possible.
Old Mar 17, 2011, 05:20 AM
Joined May 2007
NEWS: the TX PRO versions have been on delay for a little while,
I hear a new shipment of the TX PRO cases are on their way to me,
this is good news for orders with this type of case.
Old Mar 17, 2011, 04:55 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
This is how I managed to get my Futaba T7C and the Scherrer LRS to work together
Guide
Thanks Thomas, for helping me out with this problem
SpookiePower is offline Find More Posts by SpookiePower
Old Mar 17, 2011, 05:59 PM
Adrian Lewer is offline
Find More Posts by Adrian Lewer
Australia, VIC, Melton
Joined Jun 2009
Hi Everyone I have sifted through most of this thread and have decided to take the FPV plunge. I would like some advice on what I can do. I have asked Thomass but he directed me to ask my question here so hopefully you guy's can help me out.
Here is what I asked Thomass-
I have a futaba 14 MZ which as you would know has a smaller than normal module. I would like to use your UHF system and also use head tracking through the same trainer port.
As far as I know the trainer plug on futaba radio's has a PPM in and separate PPM out pin ? is this true ?If so can I do the following ?
Open the plug in the UHF lead take the power leads off and run external power to the UHF 11.1 volt Lipo but leave the PPM 'OUT' wire in the plug,
Open the Head tracking plug and find the PPM 'IN' lead and place it into the plug of the UHF (Which will be an un used slot) and then run the power to the same external 11.1 volt battery I am using for the UHF ?
Sorry for the un technical question but it seems to be the only way I can get this to all work together...
On top of this Does anyone know if I can legal use this in australia ? I think I might be able to on low power 500mw but don't think 1 & 2 W will be legal.
I intend to put this into a 40 sized trainer with 900Mhz 500-800 mW Video.
Thanks for taking the time to read my post and hopefully I will have one of these in my hot little hands soon...
Adrian Lewer is offline Find More Posts by Adrian Lewer
Old Mar 17, 2011, 10:25 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
You won't find the PPM signal on the module pins.
Only place is the trainer port and yes it can input and output signal at the same time.
I sell a special adapter in my shop: You plug it to the trainer port and it have ports for the LRS a 3S lipo and a tracker device. When you switch the trainer on in the 14MZ's menu the device automatically switch on and provide power to the LRS and tracker.
I also have a trick to use it in 12ch mode, search for: "12Z" in this thread and look for my post.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Mar 18, 2011, 03:22 PM
Joined May 2007
great hugo !
correct
nope, so just dont use those levels.
good, I always suggest to put the VTX in one wing end,
this way the RF noise emitter is far away from receivers and other sensitive parts.
also keep the GPS and RC RX away from the cam, and OSD and similar digital parts
Old Mar 18, 2011, 04:18 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
but at least 1 & 2 watts are there if you need them briefly in an emergency
AussieHoppy is online now Find More Posts by AussieHoppy
Old Mar 18, 2011, 05:02 PM
Tankogen is offline
Find More Posts by Tankogen
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Enjoying the thread. Great sense of individualism back there with the 1/2watt settings and booster discussion.
I have an 9Cap with TLRS. Will this setup be ok if I use a RHINO 2620 Li-po Transmitter pack?
the 9cap circuitry will run off my lipo, rf module none, TLRS uhf!
Curious if the 9cap will be fine. For years..
Tankogen is offline Find More Posts by Tankogen
Old Mar 18, 2011, 05:49 PM
iceman77 is offline
Find More Posts by iceman77
iceman77's Avatar
Mx
Joined Mar 2008
ok so tests with JRx12 over! Only 8 ch out, the thing is that when i plug my pan and tilt to different ch. lets say 9 or 10, they seam to work together with ch 5 and 6... any idea why? i can not control them separate, but they have shared signal wired?
Ice
iceman77 is offline Find More Posts by iceman77
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 502 Jun 10, 2015 07:16 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 06:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 08:24 PM
