Old Feb 03, 2003, 11:16 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Creating CAD parts for Laser cutting...
Just kinda a quick question that may not be too quick.
How do you size notches in cad when you plan to have them laser cut? Meaning, I want a 1/8 x 1/8 notch because a 1/8 x 1/8 string is going to sit in it. Do you size both to exactly 1/8th? Or do you give a little on each part? You don't want to end up with too tight a fit nor a loose one... so I was just curious.
Paul
Arbo is offline Find More Posts by Arbo
Old Feb 04, 2003, 03:49 PM
balsaman is offline
Find More Posts by balsaman
It's just PLANE silly!
balsaman's Avatar
Ontario
Joined Jan 2002
I make mine the exact size. So far this has worked well.
Eric
www.e-zflight.com
balsaman is offline Find More Posts by balsaman
Old Feb 10, 2003, 05:24 PM
AerodromeRC is online now
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
Paul,
The whole part should be offset by 0.0035" for 1/16" thick stock and 0.005" for 1/8" stock. Offset on the outside to make the entire part larger. This process makes the part come out exactly as designed. It accounts for the beam width. However, if your laser cutter dosn't keep his beam focused and lenses clean then 0.005" for all parts is a good way to go.
Kurt
AerodromeRC is online now Find More Posts by AerodromeRC
Old Feb 10, 2003, 08:00 PM
Arbo is offline
Joined May 2000
Thanks for the replies.
I just got my first batch of laser cut parts. I had the parts at 1/8th inch, and the notches at 1/8th as well, and they went together well.. some more snug than others (inaccurate cad program?)... so I'm pretty happy.
Paul
Old Feb 10, 2003, 08:31 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
All of my balsa in the MiG29 kit is cut with no offset, the ply needed a very slight offset. Any difference in fit is probably due to slight difference in wood thickness.
-Haldor
www.halair.com
Haldor is offline Find More Posts by Haldor
Yippee! 3D CAD Parts for Helis DevelopedBug The Builders Workshop 1 Mar 07, 2014 08:23 PM
Tips for AutoCad -laser cutting gbruce Electric Plane Talk 7 Feb 08, 2009 06:14 PM
Discussion need free plan for laser-cutting salat Scale Kit/Scratch Built 43 Oct 25, 2007 09:29 AM
Discussion cad file for laser cutting rosco The Builders Workshop 2 Dec 08, 2006 09:50 AM
Looking for Laser cutting and routing service joe@tech-mp The Builders Workshop 5 Dec 18, 2005 09:26 AM
