Old Aug 07, 2008, 01:36 PM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Help!
I need some advice on lighting up my AA saucer
Hi all,
I recently purchased an AlienAir Flying Saucer, http://www.hammacher.com/publish/75493.asp. And I had an idea to take the existing body off and making a more "ufo" looking body for it. But I would like to add a string of led's around the outside that would chase each other in a circle.
How would I be able to do something like this? The weight would have to be kept at a minimum cause it only weighs in at about 42g stock.
Thanks for any help you can provide
ICU
ICU is offline Find More Posts by ICU
Old Aug 09, 2008, 09:27 PM
TSnake is offline
Find More Posts by TSnake
The Penultimate flyer
TSnake's Avatar
Joined Apr 2007
I'm no Albert Frankenstein, but I may be able to help a little with a free LED chaser circuit. Or you can just buy a chaser circuit kit from an electronics hobby shop...the geeks working there will know what you're after.
http://www.instructables.com/id/SBHRZ3MFC2BTKW0/
Weight is going to be a real problem, you could try not using a circuit board in your circuit, and just solder the components directly to each other (be careful not to over heat them - use heat sinks when soldering).
Whatever you do is however going to present a balance issue when you fit this chaser circuit to your UFO. Maybe before you buy anything, you could estimate the weight of the components, wires and solder needed...then see if your UFO can carry the weight.
Good luck, it sounds like an interesting project...however it turns out I'm sure you'll learn heaps.
Edit : Oh and by the way, the 555 timer in the circuit can be used with an input voltage of anywhere from + 4.5Vdc to + 15 Vdc.
And the CD4017B chip will work from +3Vdc to +18Vdc.
A different input voltage may alter the chaser speed, but that might end up being a good thing.
As an afterthought, you could go to a dollar shop and buy a kids toy with a chaser circuit in it, that way all the engineering has already been done for you, and you wont have to buy any components or do much soldering.
Just a thought.
TSnake is offline Find More Posts by TSnake
Last edited by Trouser Snake; Aug 09, 2008 at 10:19 PM. Reason: Additional information
Old Aug 11, 2008, 10:16 AM
ICU is offline
ICU
ICU
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Great!! Thanks for the advice/help. It's greatly appreciated.
Old Aug 14, 2008, 06:47 PM
TSnake is offline
TSnake's Avatar
Joined Apr 2007
http://www.diyrc.com/LED-Flashers.htm
I was just given this link, it's great, check it out.
Old Aug 18, 2008, 03:07 PM
ICU is offline
ICU
ICU
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Thanks I'll check it out.
Help! Need expert advice on hooking up my Optic 6 with RealFlight G3 funfly123 Mini Helis 7 Nov 21, 2006 09:13 AM
Need some help on fixing up my tiger moth wing lttakas Foamies (Kits) 1 Feb 03, 2005 06:27 PM
Need some advice on making my Mega scream... n111kx High Performance 16 Feb 15, 2004 08:46 PM
Need some advice on my Ugly Bird(Pterodactyl)!! Electriflight Foamies (Kits) 9 Sep 02, 2002 08:06 AM
Got my Zero! Need some advice on Rx and battery pack cfossa Parkflyers 0 Apr 01, 2002 10:37 PM
