Old Aug 06, 2008, 09:57 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
ESC Capacitor Help
With my battery moved to the nose of my A-4 I need a 25" lead..
I have a CC 110HV
I got the info that I need to add a Capacitor for every 4" over 12" so to round off I need three capacitors
I called castel creation today and they said I need three 180 mfd 50v caps.
Or I could multiply 180 times 3 = 540 mfd and add one large cap
heres my problem I went to a huge electrical supply house and they don't have 180 mfd 50v cap.. they siad most are 100, 220 and on up
They had a 470 mfd 50v (pretty close to 540 mfd ) will this work?
I have no clue about caps.. anybody good with this stuff ... I'm going to email CC but that could take awhile
Also here is a pick of the cap which side is neg. and pos. ? I know I need to bridge the pos. to the neg.. but which way does this thing go?
there is an arrow on the white strip and an O what in the world does this mean?
also there are differnet caps .. the electrolytic caps looks to me like the ones on the ESC .. any one know?
These EDF's are really making me nerdy.. I'm mean I was staring at capaitors for 30 minutes.. now if I can just make a flux capacitor I'd get back to the future
thanks
Ron
Ron101 is offline Find More Posts by Ron101
Old Aug 06, 2008, 10:17 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Ron thats a great question that I always wondered about also. They really should include this kind of stuff in the destructions for the esc's. Like something noting basically what you were told. They should also make them available through the manufacturer.
lavochkin is offline Find More Posts by lavochkin
Old Aug 06, 2008, 10:29 PM
Brett_Warwick is offline
Find More Posts by Brett_Warwick
The need for speed
Perth Western Australia
Joined Apr 2005
Dont waste your time it wont help one bit. If you want to play it safe get rid of the castle creations ESC.
Brett_Warwick is offline Find More Posts by Brett_Warwick
Old Aug 06, 2008, 10:35 PM
eatond is online now
Find More Posts by eatond
EDF Jet Jam 2017, June 15-18th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Ron,
yep, the 470mf should work.
yep, you need the electrolytic caps
Your pictures a little fuzzy but I think I can make out a stripe on the side with a minus sign. The arrow points to the negative lead. Here's a pic of a cap showing the same thing. Some caps have both leads coming out the same end. In that case the lead thats closest to the racing stripe is the negative one.
Looks like in your pic the negative lead is on the left and in mine it's on the right.
Dan Eaton
eatond is online now Find More Posts by eatond
Old Aug 06, 2008, 10:41 PM
Ron Pogue is offline
Find More Posts by Ron Pogue
United States, AZ, Phoenix
Joined Jun 2002
Hi Ron -
Well, let me get you started;That symbol facing the camera is a minus sign.
Yeah, it looks like an egg, but it's a minus sign. It should be lined up with one of the leads. That would be the negative, Ground, black lead. If it's an axial lead capacitor, and it looks like it is, the arrow points at the negative lead.
Get the polarity wrong and the capacitor will 'Blow' and be ruined.
Capacitors, like resisters, come in certain standard sizes. Get the values in the ballpark, and you will be good as gold.
Ron
Dan! You beat me to it - I am just a two fingered typist
Ron Pogue is offline Find More Posts by Ron Pogue
Old Aug 06, 2008, 10:45 PM
Flatspin is offline
Find More Posts by Flatspin
United States, MI, Lyon Charter Township
Joined Oct 2001
I have about 3 feet of extension...2 330mf capacitors...twist the 2 positive and 2 neg leads together. then tap into your extension (not esc) and solder the pos to red and neg to black...make sure they don't touch using electrical tape. worked fine for me on my Fly Fly Raptor which is presently disabled waiting for a new fan and motor combo. Probably a winter project at this point. There electrolitic caps with a stripe down one side with neg symbols, the other of course is pos...an arrow usualy indicates current flow direction like in diodes. hope this helps
Ron
Flatspin is offline Find More Posts by Flatspin
Old Aug 06, 2008, 11:15 PM
The need for speed
Joined Apr 2005
To all that have responded so far .Id like to ask what effect do you think its going to have apart from adding weight.
By the way if you are going to install caps why not make them at least low ESR types after all i guess its the ripple current your all worried about.
Old Aug 06, 2008, 11:28 PM
Joined Jun 2002
I add caps coz I like the color.
Old Aug 06, 2008, 11:59 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
Thanks so much guys..
No I get it.. it's a funny lookin negitive sign
Cool.. I set it up tomorrow
Brent,
I love all my Castel ESC.. guess we all use what works for us
and I'm adding caps because Castel tell you on leads over 12"
Ron
Old Aug 07, 2008, 12:24 AM
The need for speed
Joined Apr 2005
Im a little bias because i recently tested the CC bec for load performace at my work..
I was shocked at what i saw, there spec claims are ridiculous and i refused to use it in my plane.
Then in a seperate incident a friend of mine's CC110HV caught fire destroying his Yellow aircraft F16.
After doing a bit of reasearch i found other quality issues with CC
As an Electronic design engineer i always look past the flashy covering.
Old Aug 07, 2008, 01:28 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
i guess im down the middle! lol having used tons of them and at the same tie frying some of them, I know its not the best part one can use, but long as I consider its not safe to operate it past 90% or so of what they say is nominal, I get by. Kontronik is a much better ESC, and has been SHV for a while now!, but it is big and heavy. So I just try to stay safe when I use CC in high power apps and dont over abuse it and get the additional safety from sticking it on the fan stream everytime.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Aug 07, 2008, 01:52 AM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Schulze provide details on their website:
http://www.schulze-elektronik-gmbh.com/index_uk.htm
click on 6 - Important Tips in the sidebar and click on the further links to see pictures and fitting instructions.
They sell the caps too and I bought some to fit to my Kontronik Beat 55A esc which was supplied without them. No doubt after receiving many escs back for repair due to long lead burnout (mine among them) Kontronik must have learned the lesson that all other reputable esc makers had learned before them, and subsequently all Kontronik escs, eg Jazz, have come fitted with capacitors.
As Brett said, low ESR ones are needed.
Ref the CC110HV, I did buy one for use on 12S. It's not in use yet, but do I take it that I'd be better limiting it to, say 10S?
Gordon
Gordon is offline Find More Posts by Gordon
Old Aug 07, 2008, 02:18 AM
Joined Aug 2002
12 is ok but for me I just dont go over 105, and i mean peak peak. for even lotta peak
I dont like over 100 and prefer high 90's for nominal.
Barry
Old Aug 07, 2008, 03:35 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
That is really interesting with the CC....I go for 12S90A on my CC110 so it is ok!
I get this in a few days.
http://www.yge.de/artikel.php?search=ygecap&more=yes
Martin
MaHö is offline Find More Posts by MaHö
Old Aug 07, 2008, 04:57 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
why do we want to reduce line inductance in the power leads when they are longer than 12"?
NitroCharged is offline Find More Posts by NitroCharged
GWS ESC problems. Help? Gonflyin01 Power Systems 2 Apr 24, 2002 05:41 PM
Zagi.. STOCK AVEOX ESC.. Need help ASAP Tram Foamies (Kits) 1 Dec 18, 2001 08:29 PM
ESC construction help?!?!?! cjs Power Systems 5 Sep 24, 2001 02:33 PM
did i go wrong with this esc???? Please Help BeechSkipperDude Power Systems 16 May 15, 2001 02:02 PM
did i go wrong with this esc???? Please Help BeechSkipperDude Foamies (Kits) 15 May 14, 2001 07:45 PM
