Old Feb 03, 2003, 06:43 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Ascent or Just Right?
Very similar specs; but quite a diffrence in price.
Of course there is a bit of an issue with the Ascent posibly being over propped; or is it just an LMR?
jrb is offline Find More Posts by jrb
Old Feb 04, 2003, 03:19 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Or, other recommedations for an electric sailpane that uses Zagi packs?
Old Feb 04, 2003, 06:22 PM
Mighty Mik is offline
Find More Posts by Mighty Mik
Berkeley, CA USA
Joined Apr 2001
look in parkfliers re: ascent prop...maybe a 6 x 3 is the way to go.
Mighty Mik is offline Find More Posts by Mighty Mik
Old Feb 06, 2003, 07:07 PM
sierra-gold is offline
Find More Posts by sierra-gold
Joined Sep 2002
Ascent - intended use
Been following a couple of threads on the Ascent glider. I just took delivery of one today and will probably not get to assembling it until next week.
I think the operative word in the name of this plane is Ascent "GLIDER." The plane/motor/prop combo is intended for motor use to be a climb to altitude, shut down motor for thermal searching (and cooling) and then another burst of motor when required to climb back to altitude. That's why the suggestion of an ESC with brake... to lock the prop in folded position during the soaring portion of the flight.
I'm sure if one runs the motor at full bore for 8 mins., or whatever is possible, that both the motor and battery will get quite hot.
I suspect that it actually will benefit from a gear box and a larger folding prop to climb out with more authority.
sierra-gold is offline Find More Posts by sierra-gold
Old Feb 06, 2003, 07:40 PM
Chuck McHugh is offline
Find More Posts by Chuck McHugh
Orlando Fl
Joined Jan 2002
sierra-gold, I think you are right about the geared option, mine takes 5 min to get to altitude so it is pretty hot by then.
BTW after a bad launch( dumb stunt) the battery was shoved to the front of the fuselage(forward CG) it seemed to climb and glige better.
Chuck
Chuck McHugh is offline Find More Posts by Chuck McHugh
Anti-Semetic, Ignorant, or just Funny? Michael in Toronto Life, The Universe, and Politics 27 Feb 12, 2010 10:43 AM
Discussion Too much, too little or just right gtstubbs Life, The Universe, and Politics 10 Oct 07, 2006 11:29 AM
WTB- mini blade wings or just right one KingOfTheHill Aircraft - Sailplanes (FS/W) 3 Sep 27, 2004 10:37 PM
Batteries for sky scooter! (Or just about anything else) e-flyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 10, 2001 11:24 AM
Watt Age esc's, No good? Or just mine? slowflyer Electric Plane Talk 9 May 29, 2001 08:38 PM
