Old Aug 05, 2008, 08:21 PM
sonicserve is offline
Find More Posts by sonicserve
Paoli, PA
Joined Jun 2008
Question
Gyro Mounting Foam/Tape?
What mounting foam do you use to mount your gyro? I am using Logictech 2100T but the stock mounting foam is gone.
Based on my understanding it is important to use a good mounting foam instead of just mounting tapes. Do you have any recommendations?
Are Futaba Gyro Foam Mounting Pads good?
thanks.
sonicserve is offline Find More Posts by sonicserve
Old Aug 05, 2008, 08:40 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Justplanechris sells some good gyro tape. Look at his store in www.allthingsthatfly.com.
Gino CP is offline Find More Posts by Gino CP
Old Aug 05, 2008, 11:52 PM
Paoli, PA
Joined Jun 2008
I do not see any mounting foams at the website you mentioned.
Old Aug 05, 2008, 11:54 PM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
I just use cheapo white double stick foam tape from the local office supply store.. 2 layers of it... for more cushioning... works fine!
Slyster is offline Find More Posts by Slyster
Old Aug 05, 2008, 11:59 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Perhaps Justplanechris ran out. PM him just the same. Some double sided foam tapes work well. It should be springy enough but not weak as to rip apart. The idela foam tape will damp out vibrations.
Old Aug 06, 2008, 12:38 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
The best foam tape ive used is the black "servo tape" Trinity sells it
http://www3.towerhobbies.com/cgi-bin...?&I=LXFZN9&P=7
or the wide trinity http://www3.towerhobbies.com/cgi-bin...?&I=LXKC60&P=7
The one with the plastic center tube thing is what i always look for, and the blue strip at the start. Some are like rubber but ive never had good luck with it or the white type. They always fall off after a while.
What ever you use you still want to use a zip tie or a velcro strap because they will get bumped and work loose.
BowerR64 is offline Find More Posts by BowerR64
Old Aug 06, 2008, 03:21 AM
LaurenceGough is offline
Find More Posts by LaurenceGough
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
You don't want to use a zip tie on a gyro. Transmits vibrations.
I always use the included tape.
LaurenceGough is offline Find More Posts by LaurenceGough
Old Aug 06, 2008, 05:29 AM
henryd123 is offline
Find More Posts by henryd123
trex 500esp msh protos
henryd123's Avatar
south west uk
Joined Apr 2008
car accessory stores sell double sided tape for sticking on mouldings/badges etc,this works well as its quite thick to help damp vibrations
henryd123 is offline Find More Posts by henryd123
Old Aug 06, 2008, 07:37 AM
Paoli, PA
Joined Jun 2008
A quick search on "double sided foam tape" at staples.com returns multiple results. The smallest package is still 36 yards and costs $54.99
http://www.staples.com/office/suppli...s_10051_SEARCH
Old Aug 06, 2008, 07:41 AM
Paoli, PA
Joined Jun 2008
I found sth from autozone.com
http://www.autozone.com/selectedZip,.../selectZip.htm
Should this be okay?
Old Aug 06, 2008, 10:16 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Not as much as if it falls off.
Old Aug 06, 2008, 10:20 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I just wrap electrical tape over the gyro unto the boom clamp with enough slack for the gyro to move. This holds the gyro in place in case of foam tape failure.
I've had the Futaba foam tape expire on my heli until it was crumbly. Luckily the tape held the gyro in place to have decent control for an emergency landing.
Old Aug 06, 2008, 10:29 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Well ive put bits of foam tape where the zip tie makes contact to the gyro but i didnt notice it helping much. Im a n00b so i couldnt tell the difference if i wanted. My stuff is all just junk anyway so the little vibrations (if any) the gyro sees probobly make it fly better.
Old Aug 06, 2008, 11:50 AM
Reading, UK
Joined Sep 2007
Haha, never had a problem just running the stock tape on my 2100T throwing it around.
Old Aug 06, 2008, 12:03 PM
bao is offline
bao
Find More Posts by bao
bao
It was on fire when i arrived!
bao's Avatar
France, RA, La Laupie
Joined Dec 2007
I use 3M brand double sided foam but i still use a velcro battery strap as i find the foam seems to un stick in warmer weather.
dont worry about those big ears on my servo i cut them off lol
bao is offline Find More Posts by bao
Discussion My five year old commandeered my 401 gyro mounting foam! Sky_Dancer Mini Helis 9 May 27, 2007 07:19 AM
gyro mounting foam tape derway Electric Heli Talk 8 Dec 02, 2003 12:12 PM
Foam Tape for Servo Mounting Farley Parkflyers 7 Jul 18, 2003 08:55 AM
House Fly gyro mounting tape KillerWatt Electric Heli Talk 1 Jan 22, 2002 12:43 AM
