Old Aug 05, 2008, 07:18 AM
sonicserve is offline
Find More Posts by sonicserve
Paoli, PA
Joined Jun 2008
Question
Spektrum DX6i Throttle Cut and Throttle Hold
I have a DX6i transmitter and not sure how to use Throttle Cut and Throttle Hold.
Per the instruction manual, the Throttle Cut button puts throttle and pitch to a preprogrammed position. Where can I see the value of the preprogrammed position? Can I adjust it?
When adjusting Throttle Hold value in Setup, its value can be any number from -100% to +100%. I guess 0 means no throttle, 100% means full throttle. My question is what does a negative throttle mean, say -20%?
sonicserve is offline Find More Posts by sonicserve
Old Aug 06, 2008, 08:58 AM
Paoli, PA
Joined Jun 2008
Can anybody please explain in what scenario should Throttle Cut and Throttle Hold being used? I am not quite clear about it. Thanks for your help.
Old Aug 06, 2008, 09:46 AM
hardnut is offline
Find More Posts by hardnut
flint
Joined Nov 2006
hi
First off Throttle Hold ,with this switch in on position the throttle control(stick) will not power the rotor blades up or more servo(glow heli), so you can test pitch or more heli to flight line and also safer as doesnt matter if you more throttle stick up or down on tx (BUT ALWAY BE CAREFULL NEVER JUST THINK ITS SAFE WITH THIS ON)
Second Throttle Cut ,this is for glow,petrol engines so when you land or just want to turn engine off etc you press the button and moves servo to lower position and cuts engine off
If you look in your manual on page41 tell you how to set Throttle cut
but have looked for throttle hold and nothing in manual ? i would just try it switch it on and connect power to heli then try moving the throttle slowly up hopefully the motor will not start but be carefull
Hardnut
hardnut is offline Find More Posts by hardnut
Old Aug 06, 2008, 12:28 PM
Skarn is offline
Find More Posts by Skarn
Maryland
Joined Nov 2006
For an electric heli, throttle hold is used to cut all power to the motor. The default setting in my radio is -5 and that works to ensure there is no power once TH is engaged.
As far as when to use it? Man, that should be one of the first things you learn. That's not busting on you at all, but it really is a safety issue. Never plug in your batter without TH being on. TH can also save parts in a crash. In a perfect world, hit TH just prior to the heli going in and it will save main gears, and other parts a lot of the time since all power/torque is cut as it hits. Of course that's hard to do, but hit it as soon as possible. One note: It's not always a great way to check pitch in TH...TH has it's own pitch curve so depending on what you set it at, it could be different from your normal or ST1 curves.
Skarn
Skarn is offline Find More Posts by Skarn
Old Aug 06, 2008, 02:16 PM
jrubenis is offline
Find More Posts by jrubenis
Custom CNC machining
jrubenis's Avatar
Plymouth, UK
Joined May 2006
Interesting point Skarn...On my tranny Futbaba 6exap...i can only set normal curves with throttle hold on...Idle updoesnt work. To set pitch of idle up i must unplug my battery wires!
jrubenis is offline Find More Posts by jrubenis
Old Aug 06, 2008, 02:39 PM
hardnut is offline
flint
Joined Nov 2006
hi
Both of you are right on the Throttle Hold Answer,
Skarn yes checking pitch curve with TH on can sometimes work as you have said but as it was a basic question i didnt want to confuse people to much
jrubenis, some Tx's dont have this but as you have done there is a way around this
number one point is Safety first alway test and retest before going close to heli with power connected
hardnut
Old Aug 06, 2008, 02:45 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
So would the best and safest way of checking main blade pitch be to disconnect the motor from the ESC?
dude_109 is offline Find More Posts by dude_109
Old Aug 06, 2008, 02:59 PM
hardnut is offline
flint
Joined Nov 2006
Hi dude 109
Ive had a very bad do with the blades on a raptor 30 Electric (someone turned switch off on my Tx )so im very carefull what i do and say/tell people now as i would'nt which that on anyone else.
I do use TH to check pitch on my Trex but on my logo 10/eco 8 i alway unplug batterys
Another way is to disconnect the esc from Rx and use a rx battery then no way of motor turning on !
Hardnut
Old Aug 06, 2008, 03:27 PM
mongo56 is offline
Find More Posts by mongo56
about:blank
mongo56's Avatar
Slovenia
Joined Aug 2007
Yes, disconnect one of the three wires to the motor (one is enough). I do it with a linear pitch curve on TH though, not as safe but more convenient.
mongo56 is offline Find More Posts by mongo56
Old Aug 06, 2008, 03:35 PM
Sky_Dancer is offline
Find More Posts by Sky_Dancer
Sky_Dancer's Avatar
Eatonton Ga. United States
Joined Sep 2004
Throttle hold can be your best friend in the world if the heli starts going in. There have been times I've had an "Oh crap!" moment and just known I was going to lose it and hit throttle hold and saved damage to the heli.
Sky_Dancer is offline Find More Posts by Sky_Dancer
Old Sep 13, 2009, 10:02 AM
retiree_caf is offline
Find More Posts by retiree_caf
Joined Sep 2008
With TH siwtch on, all is fine, I can move throltle stick and rotor won't spin. Here's the part I don't understand, with the TH siwtch on, if I turn my transmitter power switch off, the heli will start spinning !!!!!!!!!!!!!!!!!!!! How can this be prevented ??
retiree_caf is offline Find More Posts by retiree_caf
Old Sep 13, 2009, 12:35 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
This might be a dumb guestion . Is the sub trim for the throtle set at zero?
I had the same issue, I can't remember but I think it was a combination of the subtrim and the F:mode switch Be very carefull!! I do recall that this issue added to my already extencive collection of scar tissue
I allways(now) disconnect the battery from the escapment before I turn the transmitter off!, It dos'nt hurt near as bad
prop bender is offline Find More Posts by prop bender
Old Sep 13, 2009, 02:26 PM
shizack is offline
Find More Posts by shizack
Piro-maniac
shizack's Avatar
United States, FL, Winter Garden
Joined Feb 2007
Don't turn off the TX . Just kidding.
I'm assuming you have a DX6i or other Spektrum.
You may need to re-bind the rx to the tx. After the heli is set up, you need to bind the rx again so it knows where the fail-safe positions are. If, when you first bound the system, the throttle was up or stunt mode was engaged, the rx thinks its fail-safe position is full throttle.
shizack is offline Find More Posts by shizack
Old Sep 13, 2009, 02:30 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
NEVER turn TX power off while heli power is still connected. Though advanced RXs are supposed to go into failsafe under this condition, I wouldn't want to count on that alone to keep the heli from bashing its brains out or cutting my finger off.
TTBOMK, 'cut' zeros the THR channel and leaves PIT under stick control with whichever curve it was operating under. 'Hold' sets throttle to a programmable preset AND invokes a separate programmable PIT curve. Hold default THR value is zero, and hold default PIT curve is linear.
arbilab is offline Find More Posts by arbilab
Old Sep 13, 2009, 02:37 PM
USA, CA, Red Bluff
Joined Dec 2007
Amen to that!
Discussion Program SPektrum DX6I Aero Throttle Hold GeneR Radios 4 Sep 09, 2009 05:39 AM
Discussion DX6i USB cable & Throttle Hold? mitchfx Simulators 3 May 25, 2008 09:47 AM
Help! Spektrum Dx7 Throttle Cut misplacedtexan Radios 2 Sep 27, 2007 06:21 AM
Discussion Spektrum DX7 with Phoenix - Throttle hold questions... mdavenport Simulators 3 Sep 10, 2007 12:21 PM
Discussion Setting up the Spektrum DX6 for Throttle Hold (Heli) HavingFun2002 Radios 2 Sep 03, 2006 01:00 AM
