The model arrived today (a day earlier than originally projected) on the big brown truck and was no worse for the trip from California. The covering could use a touch fro the heat gun here and there, but no cracked wood or plastic anywhere.
Thankfully, the cowl fits. The wings felt a little heavy, but then I remembered that they also have to support the landing gear. I think I will be able to use only long stand-offs to mount the motor, but that isn't certain yet. Will have to look back through Peter's earlier photos to see what to Dremel out to make room for the batteries, and where exactly to cut the hatch and how to size the battery cradle. The elevators aren't as huge as they appeared to be in the photos, so I think I will use the Hitec mini servos that I have on hand, the 5245's. I would use 225's if I had them. Plenty of torque and way more speed than necessary, and they will fit under the stabs easily. There isn't as much space back there as I thought. However, if I use the mini's I don't think they will need to be offset. Rudder will remain pull-pull. The way they have it set up will make installation a snap. Glad I don't have to figure out the cable exit holes. As usual, looks like another great product from Seagull. The general quality level of ARFs is incredible these days. Recently assembled a 3DHS Osiris and it was superb as well. -- Bob |
![]() I test fit them in the fuse and don't think there will be a problem with having enough space. -- Bob |
I got a little work done today, getting the elevator servos installed in their modified locations, as well as marking out the battery hatch where it is to be cut on the top of the fuselage.
The servo modification was pretty straightforward... just cut some ply doublers, CA them in and cut the openings for the servos. Figuring out where to cut for the battery hatch was somewhat tricky. I used the thick balsa "ledges" on the inside of the fuse as a guide and stuck some T pins from the inside out to get a starting guide, then worked from there to try to square everything up, with some rubber bands then stretched around the outside curves to help make a guide for marking. I will do the Big Cut tomorrow. |
I hope it comes out half as nice as yours! I will content myself with the fact that a multitude of sins can be absolved with a good sanding bar and some Oracover, of which I happen to have the exact color on hand. Haven't yet decided a latch method. Perhaps some magnets and some small ply guide tabs will do since the model will not see a lot of negative aerobatic G forces. -- Bob |
Peter, what down thrust angle are you using?
I got the hatch finished and magnets hold it on very well. On to the motor mount which should be the last tricky bit. I am going to wait until almost done to put in the battery cradle so that I have the CG figured out and know better how far forward or aft it needs to be. With heavier motor and batteries, I am guessing the batteries will end up farther aft than yours. -- Bob |
Bob,
You're a go getter! ![]() I've used between 1 and 2 degrees of right and down thrust on mine and have never any cause to revise this even though I used tube standoffs that are very easily adjusted. With the battery box I just made it as long as I reasonably could and just use foam spacers front and rear of batteries to maintain the CG in the correct location. I also find that the foam spacers protect the batteries very well when I crash and are very easy to adjust if you try different motors, batteries or even as the weight distribution changes as repairs are made. Consequently I've taken this approach on all my conversions. Keep at it! And post some more photos please! ![]() Regards Peter |
That's good to hear, another completed conversion would be great!
![]() My recollection is that the standard firewall is square to both axis. I build my false firewall square (which is just one end of a very long battery box) as well and just built in the side and down thrust by using different length standoffs for the motor mount. LOL, I'm sure Bob will correct me if I'm wrong!
Mine has some right thrust built in. Looking at it from the side, it appears to have a bit of up thrust.
However, this is subjective because I don't know what exactly is the base line for the measurement. I am going to eyeball it and give it what appears to be a bit of down thrust owing to the facts that the thrust line isn't all that far above the wing, and the wing itself has a semi-symmetrical airfoil. |
Some pix from today's work. I forgot to get some photos of the covered hatch by itself but will do some more later. The magnets were glued in with copious amounts of CA and were covered with Oracover. They hold the hatch very well and the hatch is centered without the need for some additional guide tabs. It will likely need a small "lift tab" on the edge of the hatch on one side near the magnets to assist in removal, such is the power of the magnets. This hatch is not going to come off in flight, I am absolutely sure. |
| Thread Tools | |
| Dumas Sparrow Hawk conversion | Martin Hunter | Scale Electric Planes | 196 | Aug 26, 2007 11:50 AM |
| First flight of the Dumas 30" Sparrow Hawk! Pics and video included | Martin Hunter | Scale Electric Planes | 59 | Mar 23, 2004 10:48 PM |
| Seagull Models ARF | darrenb | Fuel Plane Talk | 14 | Jan 06, 2004 05:56 PM |
| Sparrow Hawk Conversion? | tekochip | Parkflyers | 1 | Dec 25, 2002 11:07 PM |
