Melbourne, Australia
Joined Aug 2007
ok..here is a short maiden flight of the ARK X500 heli before the rains set in. The tail has not yet been trimmed properly, as you can see, she piros in one direction, but not fully the other way. Got that fixed now and hope to get another video tomorrow night @ an indoor funfly sponsored by Aidan (arkinnovations.com)
Joined Aug 2007
Another short video of the X500 hovering @ a local indoor funfly in Doncaster, Melbourne. Hopefully, next video will be taken outdoors when the winter weather clears.
Joined Aug 2007
Been working on the best power option for my ARK X-500, using the stock motor (1550kV) with Scorpion 90A ESC on 3S 2500mAh lipo. Getting 4.5 mins putting back in 2000mAh. Using the 18T pinion rather than stock 16T. RTF weight 1.3kg. Headspeed is now much better but flight time is down to 4 mins.
Now experimenting on 2 x 2200 mAh lipo (connected in parallel) & getting about 6.5 mins FFF. RTF weight 1.45kg. Best weight out front for batts about 350g for CG. I suspect 4S would be best power option for this heli. Will report back once I have received the lipos & tested it on her. |
Joined Aug 2007
In order to fit the larger 4S lipos, I have had to make a minor modification to the ARK X500 design by relocating the canopy mount and using a bigger canopy. I chose to use my spare unpainted white Protos canopy and relocated the mount slightly higher up to accomodate the larger Protos canopy. To ensure a secure fit @ the base, I attached a velcro tab @ the base.
I have also painted the canopy in the Protos style, but used navy blue (to match the blue anodised metal head) instead of black on the top. The base remains in flourescent orange for orientation. The larger 4S setup will end up on the X500 Pro version, which has all metal setup including the tail, and CF horizontal and vertical tail fins and the newly painted canopy.
Joined Aug 2007
Joined Aug 2007
Joined Aug 2007
I am now running this heli on 6S using the SJM430 motor. The motor mount bracket on the X500 does not have the standard screw mount holes and only the SJM430 motor seems to fit fine. Running her 6S is the ideal setup now, and she really comes alive. Also, the standard pinion from ARk Taiwan also fits on the SJM motor, so it all falls into place. I have since moved on from the X500, and have got my new CopterX 500 heli. But I still fly her from time to time to try on new manouvers. Good luck in whatever you decide.
Joined Aug 2007
| Thread Tools | |
| Northrop X-4 Bantam Build thread | Robert May | Electric Ducted Fan Jet Talk | 232 | Dec 14, 2009 02:45 AM |
| Build Log Oakdale Aircraft X-32 prototype build thread | FrankW | Electric Ducted Fan Jet Talk | 41 | Jan 20, 2008 08:44 AM |
| RBC A-4 Skyhawk build thread X.X | Willmsy | Electric Ducted Fan Jet Talk | 6 | Nov 22, 2005 10:01 PM |
| Is there an Ark X-400 build manual Online? | Blaze_au | Mini Helis | 7 | Nov 14, 2005 10:47 AM |
| ARK X 400 build problem | thanhTran | Mini Helis | 22 | May 13, 2005 09:05 PM |
