BoneDoc's 3D Clinic #6: Take Off and Landing - NEW VIDEO ADDED
Hi Guys,
This is Josh "BoneDoc" Young. If any of you guys have been following the 3D Flying Forum, you'll notice that for the last month / two, I've been posting a series of 3D Clinic sessions, with videos included. Some of the past Clinics include: BoneDoc's 3D Clinic #1: Harriers, Upright and Inverted BoneDoc's 3D Clinic #2: KE Spins & Blenders BoneDoc's 3D Clinic #: Knife Edge BoneDoc's 3D Clinic #4: Hover BoneDoc's 3D Clinic #5: Rolling Harrier In the process, I've gotten a lot of request to do a clinic video on take off and landing, so here it is. Some basic primer on take off and landing: Take Off Apply throttle, correct heading with rudder As the model began to lift its tail, then gently pull on the elevator for a nice scale looking take off. That's IT! ![]() Landing The most important part of landing is to visualize in your mind the flight path that your airplane is going to take. From where the plane is to where it needs to be, visualize the "semicircle" arc that the flight path will take, and fly it accordingly. The mistake most beginners make is to come in too high, and too hot. In their mind, they determined to LAND, and so they "force" the landing. Instead if you're still too high and too hot (fast), either take a BIGGER arc, or make a turn around. The next mistake made is when they try to use too much elevator and not enough throttle to keep the nose up. When you do that, you'll bleed off speed, which brings the model ever so closer to stall speed. You can FEEL when you're getting close because your control will feel a little "MUSHY" instead of nice, crisp, and responsive. When this happen, ADD THROTTLE. Personally, I like nose down 5-10 degrees until I'm about 6 inches off the ground, then I level off and bleed off the rest of the speed. A little nose down will ensure that my model will still fly at sufficient speed until I'm ready to flare and touch down. The other thing to consider is to use: THROTTLE to control your descent rate (how fast you're loosing altitude) ELEVATOR to maintain attitude (which way the nose is pointing) As you gain more practice, you'll start to really get the feel of it. Just remember, that landing is the *only* required maneuver .ADDITIONAL RESOURCE Scott Stoops book, "Mastering Radio Control Flight" is also a great educational tool also in not just 3D, but precision flight as well as basic flight. It's a recommended must read and a book that you're not going to outgrow. Of course, thanks to my lovely wife Inn, who not only film my flight, braving the torching Texas heat, but who is also my biggest supporter and fan. Enjoy! Josh "BoneDoc" Young Special Thanks to: My lovely wife Inn, who makes all these things possible Ben and the 3D Hobby Shop crew Andrew Jesky for designing a great 3D platform for us mortals 3D CLINIC VIDEO #6a: Take Off and Landing 3D CLINIC VIDEO #6b: Take Off and Landing, Featuring Mike "KingsFlyer" McD |
| Thread Tools | |
| Mini-HowTo BoneDoc's 3D Clinic #1: Upright AND INVERTED Harrier - NEW SECTION & VIDEO ADDED | BoneDoc | 3D Flying | 98 | Oct 14, 2012 03:01 PM |
| Mini-HowTo BoneDoc's 3D Clinic #5: Rolling Harrier | BoneDoc | 3D Flying | 115 | Sep 18, 2011 03:48 AM |
| Discussion BoneDoc's 3D Clinic #4 - Hovering - New VIDEO ADDED - Hovering in the wind | BoneDoc | 3D Flying | 138 | Feb 21, 2010 10:53 PM |
| Mini-HowTo BoneDoc's 3D Clinic #2: KE Spins & Blenders | BoneDoc | 3D Flying | 65 | Aug 27, 2009 06:36 PM |
| Mini-HowTo BoneDoc's 3D Clinic #3: All About the Knife Edge | BoneDoc | 3D Flying | 81 | Oct 13, 2008 02:38 AM |
