Old Aug 04, 2008, 06:38 PM
Screamin' Eagl is offline
Find More Posts by Screamin' Eagl
Earh, i think
Joined Aug 2008
ESC hook up
This may be a dumb question, i don't know.
Say I get a radio that comes with 2 servos. I need an ESC. Does the ESC plug right into the reciever instead of the servo? If so and the connecters are not the same can i get an adapter or re wire a connector?
Thanks in advance.
Screamin' Eagl is offline Find More Posts by Screamin' Eagl
Old Aug 04, 2008, 06:59 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Yes.
Yes.
aaaaaaaaaand ... (drrrrrrumrrrrrroll)
Yes.
And welcome too
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 04, 2008, 09:37 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Succinct, Ron.
Welcome to RCGroups, Screamin' Eagl! Take the time to read the "sticky" posts at the top of forums that interest you, feel free to use the great search engine to a huge database and above all, don't get too serious around here.
Obviously, we don't.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Aug 04, 2008, 10:02 PM
Joined Feb 2001
Also
www.ezonemag.com
-> faq
and
http://www.wattflyer.com/forums/forumdisplay.php?f=3
-> Everything You Wanted To Know About Electric Powered Flight
Written exam will be next Monday
Old Aug 05, 2008, 01:49 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by Screamin' Eagl
... Does the ESC plug right into the reciever instead of the servo? If so and the connecters are not the same can i get an adapter or re wire a connector?
Thanks in advance.
The ESC plugs into the throttle channel of your receiver. All ESCs I've used come with a servo-type plug, which goes straight into my receiver without any modification. They use a Hitec/JR type plug, which so far as I know, will plug into any modern receiver. Only problem is, it can go into some receivers (e.g. Futaba) either way round. No damage is done if it's wrong way, it simply won't work. The negative and signal wires (black and white, or brown and orange or yellow) should always be facing the same way when they're plugged in, so just observe which way your servos are plugged in, and plug your ESC the same way round
abenn is offline Find More Posts by abenn
Old Aug 05, 2008, 04:38 PM
Earh, i think
Joined Aug 2008
Thanks everyone! As for the exam, I think I'll pass...
Old Aug 05, 2008, 10:15 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Don't sweat it. It's open webpage.
mw
Discussion twin engine to ESC hook-up ysgte62003 Electric Plane Talk 6 Oct 26, 2007 07:50 AM
Help! ElectriFly C-12 ESC Hook-Up mikeaero Micro Helis 7 Jan 20, 2007 08:52 PM
Discussion BEC and ESC hook-up dborros Mini Helis 2 Mar 14, 2006 06:32 AM
Pegasus 35H esc hook up? hnearnest Electric Heli Talk 4 Feb 03, 2003 08:52 PM
how to hook up 2 batts. to 1 ESC? barn buster 50 Electric Plane Talk 3 Dec 26, 2001 09:14 AM
