Old Aug 02, 2008, 11:07 AM
icrashrc is offline
Find More Posts by icrashrc
icrashrc's Avatar
Indiana
Joined Jul 2003
CC BEC Output Voltage
Is there anyway to coerce an extra 2 tenths of a volt out of the CC BEC? I'm trying to use a CC BEC in a non-RC related installation. I need less than 400ma of current at 9.2 volts but the max output available is only 9 volts. Thank you,
Scott
icrashrc is offline Find More Posts by icrashrc
Old Aug 02, 2008, 03:51 PM
Spidious is offline
Find More Posts by Spidious
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
What could you possibly need .2v extra for ?
Have you checked the CC Bec actual output voltage ?
Wouldn't be surprised if it actually is 8.8v or 8.9v !
Spidious is offline Find More Posts by Spidious
Old Aug 02, 2008, 06:39 PM
icrashrc is offline
icrashrc's Avatar
Indiana
Joined Jul 2003
I checked. It's 8.98 volts. And yes, believe it or not the bump up to 9.2 volts is important!
Old Aug 03, 2008, 12:01 AM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
why not use a line driver? ... feed the signal into a driver i mean if you only need 400mah you could easily get the extra voltage you need at no loss to anything "seeing as you only need 4W total power and the CC BEC is capable of 90W"
turbored21 is offline Find More Posts by turbored21
Old Aug 03, 2008, 05:06 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
For your application just get an adjustable voltage (LM317 or equivalent) and make your own circuit. Radio Shack and other electronic stores has them and they are very inexpensive.
RC Man is online now Find More Posts by RC Man
Old Aug 03, 2008, 05:54 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Yup - $2.29 for the regulator, the data sheet from National has a dozen or more schematics.
..a
Old Aug 03, 2008, 09:23 AM
icrashrc is offline
icrashrc's Avatar
Indiana
Joined Jul 2003
I've built a number of things with both a LM317 and a LM350 as part of the regulation circuit. I was just hoping for a plug and play setup with something i already have. The CC BEC missed the needed voltage by so little...
Old Aug 03, 2008, 11:31 AM
United States
Joined Feb 2001
You can call CC on Monday and see is they will make a special software version for you with higher voltage options. Several have been asking about a 12v option so they might add that to the next software update. If they are going to include higher voltage options in the future be sure and let us know.
The problem may be that the next software update might not be scheduled for some time. They will probably want to charge you for a custom software version. If you need it any time soon you will probably have to make your own regulator. To make a LM317 regulator would only take half an hour to make and test if you have the parts.
Old Aug 03, 2008, 10:45 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
How about this one? Adjustable output up to 13V.
Tom Frank is offline Find More Posts by Tom Frank
Question CC Bec what are your actual voltage readings ? Spidious Castle Creations 9 Jul 15, 2008 07:27 AM
Question Kontronik Jazz 40-6-18 BEC Output Voltage Innovator Power Systems 2 Feb 19, 2006 05:39 PM
CC 25/35 BEC - what voltage should I expect? Neil Walker Castle Creations 5 May 09, 2005 07:17 PM
Charging ... what about charger output voltage Peter Khor Batteries and Chargers 12 Jul 31, 2002 10:01 PM
c/10 output voltage Taube Beginner Training Area (Aircraft-Electric) 2 Jun 30, 2001 05:10 PM
