Old Aug 02, 2008, 05:17 AM
Registered Abuser
fooesboy's Avatar
Hamilton, New Zealand
Joined Oct 2005
Pleas Help! Need info on USA car size quick!
Hi all,
I quickly need some help!
I need to make a box for transporting and protecting my models on our road trip in the USA. I do not know if the size of box I need to make will fit in an American car, we only have a small 2 door German sports car and there is NO WAY it will fit in it.
I had wanted to make a box that would fit on the back seat, but the smallest length to fit my 1 piece SR-7 wing will need to be about 160cm (approx. 63 inches)
Can someone please measure the distance between the doors, and between the seats and roof of a typical mid-sized American car. We have reserved a Pontiac G6 or similar from Avis.
Thanks in advance!
Chris
fooesboy is offline Find More Posts by fooesboy
Old Aug 02, 2008, 07:43 AM
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Chris, if I'm not mistaken, the Pontiac seats fold down, so the trunk flows thru and under, resulting in a pretty long trunk floor. I know for a fact there are not that wide as my wing halves dont fit and they are 62" each half.
You coming to SoCal???
WD
concreteman is online now Find More Posts by concreteman
Old Aug 02, 2008, 08:14 AM
Chief High Horse's Avatar
Orange County, CA
Chris, I have a similar car to the G6, 2 door I am thinking?
I just measured my car and a box that will slip in the car behind the front seats and sit across the back can be. 110cm width, 30cm depth, and 45cm height.
hope that helps
Chief High Horse is offline Find More Posts by Chief High Horse
Old Aug 02, 2008, 10:04 AM
Registered Abuser
fooesboy's Avatar
Joined Oct 2005
Thanks guys! Looks like the car we have reserved is going to be wayyyyy to small! I need to fit a box 160cm x 50cm x 50cm at a minimun! I have called the rental company and they recommended to change the car at the time of pick up.
Dave any chance build nights will be back on when I'm in SoCal?
Thanks again for the info!
Chris
Old Aug 02, 2008, 10:58 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, upgrading the car is no big deal. And you'll be pleasantly surprised
at how cheap the gas prices are.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Aug 02, 2008, 01:54 PM
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
Before you build a box, check out the Sport Tube. Designed for snowboards, it telescopes in length, and will hold several sailplanes. Best thing is that when you arrive at your destination, you can take your planes out of the sport tube and collapse it down to a convienet size.
WinchDoc
winchdoc is offline Find More Posts by winchdoc
Old Aug 02, 2008, 02:18 PM
H.A.L. 9000
checkenbach's Avatar
Benicia Ca. USA
Joined Jan 2001
Do yourself a favor and upgrade to a Toyota Sienna minivan if possible, loads of room, and a good driver as well.
checkenbach is offline Find More Posts by checkenbach
Old Aug 02, 2008, 03:34 PM
Registered Abuser
fooesboy's Avatar
Joined Oct 2005
Ian, the gas will still be about 1/2 of what it is here in Switzerland......
WinchDoc, I have seen the sports tubes here on RC Groups, but cant find any here. But this option will also give (I hope) good protection while traveling in the car. We are planing on driving about 5'000 miles.
Checkenbach, Thanks for the tip, not sure if Avis do Toyota's. Not sure if a minavan is the way to go or a SUV, we will just have to take a look when we are there.
Minhuahua, are your going to Sore Utah? I will let you know when we are on our way down SoCal.
Attached are a couple of photos of the box I have started on this afternoon. I hope it will stand up to the baggage "throwers"
Chris
Old Aug 04, 2008, 12:13 PM
Orange County, CA
Chris,
Make sure you have a support block in the middle of that box!!! The baggage handlers at the airlines WILL stack a couple of hundred pounds of suitcases on top of that box.
Old Aug 04, 2008, 12:23 PM
So many kits, so little time..
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Originally Posted by Minhuahua
Chris,
I wouldn't trust any cardboard box like that in the hold - it's gotta be much sturdier than that, ideally with a polycarbonate shell. It will be more expensive than yours to transport, but then arriving with a box of mangled plastic and foam isn't exactly cheap...
MattyB is offline Find More Posts by MattyB
HELP Need Info on Graupner ME108 Taifun Knoxie Scale Fuel Planes 6 May 26, 2004 04:36 AM
Need info on speed 400 size glider. tocano Electric Sailplanes 15 Apr 21, 2004 06:56 AM
Help!! Need Info on paint matching Solite! boomerace Electric Plane Talk 3 Oct 01, 2003 04:14 AM
Help! Need info on gearbox/pinion, etc. to use on MH Razor attached to Mini IFO.... eaglesoar777 Indoor and Micro Models 2 Aug 08, 2003 07:28 PM
HELP: Need info on building hot wire foam cutter Chic The Builders Workshop 4 Jan 11, 2003 11:13 AM
