Old Jul 31, 2008, 12:10 PM
graggy@dejazzd is offline
Find More Posts by graggy@dejazzd
Joined Apr 2008
putting a gyro in a PA Addiction
is it possible to put a gyro in an Addiction to make it hover? I just cant seem to be able to hold it there on my own and thought with a little help I could learn it better.If it is possible what type of gyro would I use and what control surfaces would it control? thanks
graggy@dejazzd is offline Find More Posts by graggy@dejazzd
Old Jul 31, 2008, 12:20 PM
jrubenis is offline
Find More Posts by jrubenis
Custom CNC machining
jrubenis's Avatar
Plymouth, UK
Joined May 2006
It is possible but dont bother. Just grit your teeth and learn the hard way. The addiction is a breeze to hover check your setup. CG etc.
Good luck
jrubenis is offline Find More Posts by jrubenis
Old Jul 31, 2008, 12:21 PM
Bryan Davison is offline
Find More Posts by Bryan Davison
Joined Mar 2006
possible...yes....good idea....no
Problem with gyros is while it will hover...it will make it where it doesnt want to do much else.
Better to correct your CG, and learn how to hover without the gyro.
Bryan Davison is offline Find More Posts by Bryan Davison
Old Jul 31, 2008, 12:31 PM
bleary is offline
Find More Posts by bleary
Cookie Monster
Australia, QLD, Diddillibah
Joined Aug 2005
Like the other guys are saying...perhaps move your COG back a bit or slow down your thumbs a bit,or even consider carpet bowls.Gyros are for choppers IMHO.
Bleary
bleary is offline Find More Posts by bleary
Old Jul 31, 2008, 12:47 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
instead of a gyro, put money into a sim... keep hovering until you get it. Next time you go back to the real thing, it'll be muuuch easier.
I could hover, but it's pretty clear that I learned torque rolling on Aero Fly Pro Deluxe. There's a lot to be said for repeatedly and fearlessly practicing the same thing over and over until you get it down
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jul 31, 2008, 01:18 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
.. or get a cheap foamie until you're more confident. $12 for an airframe can't be beat!
http://www.hobby-lobby.com/yak55.htm
..a
Old Jul 31, 2008, 05:53 PM
dmiller746 is offline
Find More Posts by dmiller746
I havent decided yet
Indiana
Joined Jun 2006
I have used gyros on the rudder of several planes with success. I found they worked against me on all other surfaces. a simple rate gyro works well with the gain set fairly low.
dmiller746 is offline Find More Posts by dmiller746
Old Jul 31, 2008, 05:54 PM
Indiana
Joined Jun 2006
also, if you would search you would see that this question gets asked every week. there is alot of info already here for you to read.
Old Jul 31, 2008, 06:57 PM
SabreHawk is offline
Find More Posts by SabreHawk
Off we go.............
SabreHawk's Avatar
Seattle, WA. USA
Joined Jan 2006
I agree with most on this, a gyro in an airplane just isnt practical, or nessicary and besides if you did get it to work as you wish, it isnt you with the skill but rather its the device. And you wont ever develop the skill you wish to have, you only get that by working for it.
And yes, search. Questions get asked here everyday every hour on the hour for which the info already exists, and often it's right in front of you a few threads away.
SabreHawk is offline Find More Posts by SabreHawk
Old Jul 31, 2008, 10:03 PM
Indiana
Joined Jun 2006
I did learn the hard way (without gyro) but if you ever decide to just have some fun with this hobby, go ahead and install one as it is quite fun and very easy to operate. Most naysayers have never tried it. I also beleive it is a good training tool for hovering. As you get better you gradually decrease the gain on the gyro till you can do it by yourself. Again, the only place that I have found to put it that wouldnt have adverse effects on the rest of the flight is the rudder.
Old Jul 31, 2008, 10:04 PM
Indiana
Joined Jun 2006
I have read a few times on Horizon Hobby website where Mike McConville describes hovering and he always says to turn on the gyro at this point as if it is standard operating practice for him. I beleive it is in the tutorial section at Horizon.
Old Jul 31, 2008, 11:08 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I have read that too and I think it's a little odd, because gyros are illegal in competition. If you're just a weekend flyer, I think it's fine to use them, but the Addiction is one of the most stable planes in its size, and you should be able to hover it just fine without electronic help. If you can't, you either need more practice, or you have something set up wrong. Lateral balance and a straight rudder is pretty important, as is balancing the prop and having the correct thrust angle. You can hover a plane without these things, but it's gonna be really hard.
I second the Yak-55 foamy - if you are afraid of busting up the pretty plane, get a cheap foamy. If you can learn to hove the Yak-55, you can hover anything.
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 01, 2008, 01:20 AM
rballz is offline
Find More Posts by rballz
I butcher foam
rballz's Avatar
Springfield, MO
Joined Jun 2008
Gyro for hovering..that's not ninja at all..
rballz is offline Find More Posts by rballz
Old Aug 01, 2008, 07:56 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
I read once where, if all you want to do is hover a plane, make it real tail heavy... Putting the battery in the tail section will allow hovering, but not anything else.
Or, if you don't secure the battery pack good enough in a vertical maneuver.
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Aug 09, 2008, 11:06 PM
Spackles94 is offline
Find More Posts by Spackles94
War Eagle!
Spackles94's Avatar
Birmingham, Alabama
Joined Feb 2007
Yeah, get a sim and learn how to hover "the real way." The new RealFlight 4.0 has a really nice hovering tutorial, too.
I don't mind using technology for helping me fly better (mixes, expo, ...) , but using a gyro almost crosses the line of "cheating" in my book....
Spackles94 is offline Find More Posts by Spackles94
Any Sky Scooter Experts in Central PA? Veedubber Foamies (Kits) 32 Aug 07, 2003 03:38 PM
Trying to find a Slope in NJ/PA/NY area max throttle Slope 2 Oct 30, 2002 07:27 PM
gyro in two channel? 4throttles Parkflyers 2 Jun 05, 2002 12:52 AM
any electric/slope stuff in ~wilksbarre, PA worth checking out? opualuan Electric Plane Talk 11 Apr 25, 2002 10:31 PM
Question Gyro in 3D? Bdouglas Competition Aerobatics 0 Apr 22, 2002 06:27 AM
