Old Mar 10, 2013, 12:24 PM
disho is offline
Find More Posts by disho
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Mine arrived safely took it out of the box and checked parts all seems well, ive took the lander metal 3s fan out, i will be putting a lander 10 blade dps fan in and running on 6s, will start the build as soon as my fan arrives should be a quick build
disho is offline Find More Posts by disho
Old Mar 11, 2013, 11:57 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Mine wasn't a quick build...... 18 mths (?) later and still not finished.... LOL
PeterVRC is online now Find More Posts by PeterVRC
Old Mar 12, 2013, 04:47 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Originally Posted by Manu Simon View Post
For the record setup is L2855 2300 kv on 5S 3000 mah and CS10.
Glad to hear that the maiden went well! Mine's still languishing in its box, due to the fact that I can't find a suitable pilot. Anything I find that might fit is out of stock! Would you mind letting me know where you got your pilot from and what it is? Thanks!
GordonTarling is offline Find More Posts by GordonTarling
Old Mar 12, 2013, 06:06 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
The CS10/Turnigy L2855-2300kv is a good option for the Panther for scale speeds and it doesn't the stock 60A ESC to be changed.
The Lander Alloy 10Blade 6S EDF should make it go.
The airframe can handle some weight very well but needs to be brought in for landing with some power. CG is very important (62-65mm) to avoid balooning when power is cut.
Had a few flights on Sunday...
RC Lander Panther F9F-2 - ChangeSun 10Blade EDF/L2855-2300kv 5S - Flight 30 (3 min 7 sec)
anlucas is offline Find More Posts by anlucas
Old Mar 12, 2013, 12:32 PM
Manu Simon is offline
Find More Posts by Manu Simon
Manu Simon's Avatar
Belgium
Joined Aug 2008
Hi Gordon
http://www.hobbyking.com/hobbyking/s...x56x66mm_.html
Unfortunately out of stock...
Manu Simon is offline Find More Posts by Manu Simon
Old Mar 14, 2013, 04:30 AM
Joined Mar 2001
Simon - thanks for that - seems that size pilot is a bit of a rare beast right now!
Old Mar 14, 2013, 05:04 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Nice video, and great - quiet - sound! You have the bottom cheater completely open if I remember correctly, and no cheaters cut in the top of the fuse?
cheers
Clemens
mopetista is offline Find More Posts by mopetista
Old Mar 14, 2013, 11:58 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
cheers
Clemens
Clemens,
the bottom cheater is 90% open and 2 small cheaters on the top.
Old Mar 15, 2013, 10:26 AM
Manu Simon's Avatar
Belgium
Joined Aug 2008
Mine has the perforated screen at the bottom and the two cheaters fully opened and is as quiet as Anlucas'
Definitively my quietest EDF so far
Old Mar 15, 2013, 05:07 PM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
http://www.youtube.com/watch?v=--thswpCJQ4
i have tried mine at 65mm cg and as far forward as 58mm cg. although this reduces the ballooning a little, i believe you will never really eliminate it while using the bottom cheater hole. it creates a significant area of low pressure when the power is on, hence when the power is removed the area of low pressure goes away and the plane starts to climb. conversely, i have noticed that when you add power after gliding and allowing the plane to slow down , the plane will dip or lose height for a fraction of a second before the thrust and lift equal things out. try to think of it as having a vacuum cleaner installed in the plane and the intake for it is underneath. i also hand launch and have the wheel wells open to use as hand holds and allow extra air- this has the same effect as the cheater hole. all you can do is anticipate the pitch change when throttling on or off. the bad part is when you are low and slow (are gliding)and are about to drop short of your landing area- you add a little power to extend your flight path and initially it sinks-you just have to be ready for it or add power a little sooner
jb0005 is offline Find More Posts by jb0005
Old Mar 16, 2013, 12:36 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
I have experienced all this when the cg is behind 62mm.
With the cg set 60-62, I get no balooning at all when cutting power for the final approach. I think it's almost visible in the video but not quite...
Old Mar 17, 2013, 08:19 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
So the CG can go as far forward as 60mm? I've yet to maiden mine
fooyukvoon is offline Find More Posts by fooyukvoon
Old Mar 17, 2013, 09:13 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
yes , the elevator does get less responsive , but doable.
remember, a nose heavy plane may fly lousy , but a tail heavy one flys once
chas650r is offline Find More Posts by chas650r
Old Mar 18, 2013, 01:19 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
It's not necessary to go that far. It may take longer to rotate on take-off.
62-65mm is just right.
Old Mar 20, 2013, 11:58 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Motor and Fan Replacement
Last night I replaced my E-Flite DF15 (3600kv) with HET 6904 fan (which was anemic in performance together) with a Cyclone Power 480-3300kv 4S/5S w/ CS 10 blade setup. I'm using SkyPower 100 amp ESC w/ 6 amp SBEC (HeadsUpRC).
Here are the numbers using Zippy Compact 35C 3300 4S battery:
Amps: 70 max
Watts: 985
Ran at about 650 watts and 45-50 amps at 60% throttle where I think it will run most of the time.
Ran for 3 minutes mostly at 75% or higher throttle and it had 3.75 to 3.8 per cell. The ESC was just warm to the touch, the battery was just warm to the touch and the wires from battery and to motor were cool but the smaller wires next to my watt meter were HOT. I use EC5's for connectors on battery/ESC and use 5mm connectors to motor even though it is a patch cord down to 3.5 mm that came with motor...can't reach those wires to see how hot they were since they are under the motor housing and don't stick out any.
Can't wait to try it out this weekend.
Russ
RGS2010 is offline Find More Posts by RGS2010
