Old Jan 28, 2013, 08:14 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
not a Lander Panther...
...but you'll like it (modified Airworld model)
Panther F-9F at 200 mph / 321.8 Km/h (3 min 2 sec)
mopetista is offline Find More Posts by mopetista
Old Jan 28, 2013, 08:29 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Nuthin' like a turbine!
RGS2010 is offline Find More Posts by RGS2010
Old Jan 29, 2013, 10:46 AM
nighthawk0077 is online now
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by Manu Simon View Post
Thanks for the comments Alan.
I never tried any bungee launch so far....Still hope the Panther will make it by hand...
I have a composite Eflite F86 that will need the bungee for sure, but she's still in the box.
Well if you think you have enough power you can try an underhand launch. It takes a bit of coordination. Set your throttle to 1/4, then go to full power as you release. Works like a charm with over 50 flights..
New 10 Blade DPS Alloy 70mm Fan in Lander Panther (4 min 10 sec)
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Jan 29, 2013, 02:58 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
nice launch and flight. can u explain the concept of the low power release? i have always launched at near full if not full throttle . is it just a matter of not being able to hold onto it at higher settings w/ one hand?
the dps sounds sweet ,what cell count and battery size did u go with ?
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 31, 2013, 06:30 PM
Canada, ON, Vaughan
Joined Oct 2009
I go to full power as I release, which requires you to put some faith in the fact that everything will work as expected.
Again this will only work when you have better than 1:1 thrust.
Battery in the video is a 6cell 4000mah
Old Jan 31, 2013, 08:46 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
thanks, i just wondered why not throttle up then throw?
Old Jan 31, 2013, 10:28 PM
savvy is offline
Find More Posts by savvy
Marton, New Zealand
Joined Apr 2005
From my experience you get an extra punch of thrust just after you hit full throttle then it seems to settle a bit. Maybe it's just a perceived benefit but it always seems to work better for me to throw just after hitting full throttle.
savvy is offline Find More Posts by savvy
Old Jan 31, 2013, 11:45 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
ok, it looks impressive
Old Feb 01, 2013, 12:25 AM
Canada, ON, Vaughan
Joined Oct 2009
Don't think it will work when doing a one handed underhand toss. One slip/sweaty hands and you have a problem. Set just enough throttle to take up most of the weight of the plane. Then you get a nice controlled launch.
Old Feb 01, 2013, 04:16 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
chuck.
i think that's what i guessed back here.
Old Feb 25, 2013, 08:34 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Here goes, finally got my Lander F9F ready for flight. Setup is a follows.
4375kv motor installed into a Change Sun 70mm shroud.
3S 3700mah 30C packs
100A Esc.
Retracts.
No Flaps (flaps were not cut out. V1?)
A.U.W. Around 1.5kg
Think this will lift off the ground? Heaviest foamie I've got. After swapping the alloy lander parts for the lighter CS shroud with the exception of the motor, it still spins just as smooth.
Any comments,ideas or thoughts about it before I commit it to the sacrificial altar? (aka maiden) Just can't figure out how else I can remove weight.
Thanks.
fooyukvoon is offline Find More Posts by fooyukvoon
Old Feb 25, 2013, 08:46 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
1.5Kg should still fly totally fine.
Hopefully ROG and not hand launch! hehe. But still should be fine...
PeterVRC is online now Find More Posts by PeterVRC
Old Feb 25, 2013, 09:07 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
3.3 pounds is not much for these airframes , some are over 6 lbs
that being said the landers motors do rely on heatsinking to the alum housing . the wattage is down on the 3cell so maybe the heat generated wont be as much , but the current is fairly high and most of the heat is made by current flow. have u ran it much? on some other inrunner set ups the motor has gotten hot enough to melt the motormount area of the plastic housing. just saying.
might want to run it up for awhile and see how hot the motor gets, dont want a catastrophic failure.
chuck
Old Feb 25, 2013, 10:34 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Definitely ROG
I've discharged the 3700mah pak thru it quite a few times already and everything seems ok. Very happy with the fan/motor conversion actually. It turned out ok. I m more worried about the retracts collapsing on landing.
Have burnt 3 servos trying to get the retracts working properly.
Maiden will b 4 days away then..
Old Feb 26, 2013, 12:44 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Originally Posted by fooyukvoon View Post
Definitely ROG
good luck then!
