Old Oct 06, 2012, 01:47 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Well done on the maiden Savvy.
Not sure if it applies to you; but the factory COG notoriously makes these Panthers tail heavy. They fly better with the lipo pushed forward and COG around the 65mm to 62mm mark.
Cheers
Goody63 is offline Find More Posts by Goody63
Old Oct 08, 2012, 09:39 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Congrats Savvy!
Did you land on the gear or just belly in?
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Oct 08, 2012, 03:27 PM
savvy is offline
Find More Posts by savvy
Marton, New Zealand
Joined Apr 2005
Thanks very much. The grass was really quite long so I belly landed it in both times. The fibre glassing really helps it to skid along and protects it well from any possible damage. The surface is also smooth enough now that dirt marks simply wipe off.
I had the pleasure of flying at my first club-field in the weekend so took the Panther to see how it would fly off a very short grass runway. The front gear collapsed again where the wooden plate glues into the inside fuse, a bit annoying. Because of the gear problem I also belly landed at the field. Certainly a lot more stressful when there's a group of people watching the 'new kid'
One thing I noticed was that they were flying in a right-to-left clockwise pattern but for some reason I always fly anti-clockwise, was amazing how much that put me off. It seemed odd to fly the wrong way around the track, certainly something I need to practice at.
savvy is offline Find More Posts by savvy
Old Oct 08, 2012, 03:33 PM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
you are not alone!
The circuits at out club depend on wind direction and subsequent pits choice. I hate left hand circuits as I am just not used to them. I guess with enough practice you become ambidextrous! (I hope,)
Impailer is offline Find More Posts by Impailer
Old Oct 08, 2012, 03:34 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I had same problem with my front wheels collapsing...finally had to drill holes (toothpick sized) through from the fuselage into the wooden platform and Gorilla Glued them in there. Was barely visible from bottom side.
Old Oct 08, 2012, 09:47 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
My new Panther (Thanks to Tim at RC Lander)
Still working on tuning her, fan is choking for air...
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Oct 09, 2012, 02:19 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Nighthawk,
looks great! Just like mine..
Curious. I 've seen some videos of your "other one" I think. It was very fast with the CS10 fan.
What are the differences between this one and the other one related to airflow?
I also had the fan choking and removed all of the red plastic covering the bottom cheater. Mine also had a 56mm exhaust.
anlucas is offline Find More Posts by anlucas
Old Oct 09, 2012, 02:56 AM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
sounds good for Turbine then
CrocEnd is offline Find More Posts by CrocEnd
Old Oct 09, 2012, 12:23 PM
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by anlucas View Post
Nighthawk,
my last one was the old version, so huge cheater at the bottom. Id like to avoid doing that with this one. Will probably add two more intakes on the sides.
The new fan unit does sound great though in the airframe
Old Oct 09, 2012, 10:32 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
Thanks for confirming that.
I haven't noticed any differences in handling(balooning etc) with the bottom cheater open btw.
Old Oct 10, 2012, 03:45 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Nav & Afterburner Lights
My new Panther got the nav and afterburner lights option installed at the factory. I finally got to hook them up last night. Not terribly hard but LOTS of wires to contend with between the light controller and the receiver! Channel 7 on my Futaba 7C runs the light switch by default with the way they have you hook it up. It's a great deal 'cos you can turn the lights off or on that way. I was worried about using power to run them all (tail light, wing tank lights, head light, and afterburner lights) but with a flick of the switch...no lights. I had to adjust the "travel" so they wouldn't come on with lowest switch setting and to come on brightly with another switch setting but that was as simple as turning a screw on a potentiometer (sp?) per the instructions.
The lights are brighter than I have seen on other planes...like my FMS Petie on the wing tips (hardly visible at all)...the head light is especially bright. The wing tank lights flicker on and off and vary the flicker time...very cool. Haven't flown it yet so don't know how visible they are in daylight but will report back.
Hope to maiden this weekend...if all the stars align...will take some pics and video. Also got the factory installed landing gear hooked up last night and the etracts worked very well.
Now to install the motor/fan/esc tonight.
Russ
Old Oct 12, 2012, 10:56 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Don't do what I did
After installing lights, the wing was next. Well...I just found out that when you custom order (like I did from ParkRCModels.com) you HAVE to order "Deluxe Removable 1 Piece Wing" option to get wing hold down hardware included (blind nuts, bolts, ply pieces to make wing removable...aka...not permanently glued in). I thought the deluxe version would be some exotic version that I didn't need. I just wanted to bolt in on and be done with it. The previous one I got from HK had all the wing hardware included so I thought that was a base version. But, live and learn.
I contacted Max @ ParkRCModels.com and he was very nice about it and immediately shipped out the parts I needed at his cost. He surely didn't have to do that and I appreciated it. He also said that the procedure for installing hardware is not in the manual and he contacted the factory to get pictures for me to complete installation. Talk about customer service! He's got my business from now on.
I'll post pics and vids when complete but won't be this weekend.
Russ
P.S. Here are the pics that Max sent from RC Lander factory today.
Old Oct 24, 2012, 05:33 AM
rexmexx is offline
Find More Posts by rexmexx
Joined Jul 2010
6s setup is definitely choking for air
Guys, I just maidened my new Panther with the springloaded intakes on top of the fuselage and the new Lander 10 Blade Fan at 6s.
The jet was only half as fast with the closed (old + huge) cheaterhole at the bottom than with the removed panel to open up the old one. That means, if you go with 6s, you definitely nees more air than coming the fan from the normal intakes and the new springloaded cheaterhole.
rexmexx is offline Find More Posts by rexmexx
Old Oct 28, 2012, 08:04 PM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Just finishing my hand launch HK 3S version. Should I cover the intake with the supplied cheater holes or leave off? Should I cover the main gear holes or leave open for extra intake? I plan on covering the nose gear hole. Instructions call for running throw- accurate?
Bugbitten is offline Find More Posts by Bugbitten
Old Oct 29, 2012, 01:54 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
big cheater vs. gear doors open
Haven't finished mine yet but FWIW some knowledgeable guys over in the
Geman forum say that they have the handlaunched version getting air
via the open gear channels, and close the main cheater because it would
get in too much dirt in the landings. I guess I wil try that too eventually.
So it has been done successfully
EDIT: As those guys are using Wemos, their success doesn' mean
that a Change Sun 10-blade won't be starved for air w/ only the
gear wells open and no cheater - the CS needs a better air feed
in general...
cheers
Clemens
mopetista is online now Find More Posts by mopetista
