Old Sep 21, 2012, 06:16 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
This is the one...
http://www.hobbyking.com/hobbyking/s...0watt_6s_.html
anlucas is online now Find More Posts by anlucas
Old Sep 21, 2012, 01:39 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Here's one more. Lots of air traffic and people running across the field, so this was a tamer flight
New 10 Blade DPS Alloy 70mm Fan in Lander Panther #2 (4 min 43 sec)
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Sep 21, 2012, 02:20 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Using iPhone Speed Gun app I clocked your Panther at 90mph @ 2:10 and 88mph @ 2:42.
Nice flight!
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Sep 21, 2012, 05:05 PM
anlucas's Avatar
Joined May 2011
Nice flight!
Russ
That sounds low. Looked to be much faster. These apps are not very accurate.
Old Sep 21, 2012, 07:31 PM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
RGS2010
When you use iPhone app how and when or is it the noise from the video
Cheer's
CrocEnd is offline Find More Posts by CrocEnd
Old Sep 21, 2012, 09:42 PM
Canada, ON, Vaughan
Joined Oct 2009
I was flying around for most of that flight at half throttle, so it's probably close.
In the first video I posted on the last page, I was at full power for most of the passes.
Old Sep 22, 2012, 12:21 PM
Tim Wan is offline
Find More Posts by Tim Wan
Joined Apr 2008
I have done some testing again of DPS/MBS70 1A22 6S & 1A30 4S on our F9F-2 Panther PC version & F9F-8 Cougar for testing respectively..
The following is two link of those testing video for sharing with all of you.
RCLander DPS MBS 70mm 6S with F9F 2 PC version testing flight video 20120922 (3 min 47 sec)
RCLander DPS MBS 70mm 4S version testing flight video 20120909 (3 min 23 sec)
Tim
Tim Wan is offline Find More Posts by Tim Wan
Old Sep 24, 2012, 07:39 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Originally Posted by CrocEnd View Post
RGS2010
Cheer's
I'm no sound engineer but it's the sound that the plane makes as it approaches and goes by and it somehow averages the sound and interpolates that into speed numbers. I've found it to be quite accurate in real life...I have no idea how accurate it is from a video.
Tim...nice motor setups...was hard to see the planes though...liked your helmet cam.
Old Sep 24, 2012, 09:41 AM
Tim Wan is offline
Joined Apr 2008
Hi RGS2010'
Yes, i use the helmet cam to record..
Tim
Old Sep 24, 2012, 06:37 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Tim, were you showing the two power versions as a comparison of the 4S and 6S versions? They seemed to be pretty close to exactly the same end result(?).
PeterVRC is online now Find More Posts by PeterVRC
Old Sep 24, 2012, 09:13 PM
Tim Wan is offline
Joined Apr 2008
Hi PeterVRC,
6S version flying performance is better.. 4S is also well. I show two versions as a comparison in order to let customers easy make the choice to fulfill their need against their on hand battery event.
Tim
Old Sep 24, 2012, 09:15 PM
Joined Nov 2006
Oh ok, thanks Tim.
Old Sep 26, 2012, 03:37 AM
CrocEnd is offline
CrocEnd's Avatar
Darwin
Joined Aug 2002
RSG2010
Cheer's mate have done more reading, You gave me the go hold it at the source
Thank you
Old Oct 03, 2012, 10:45 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Help Please
I'm tying to put the power plant in my new panther. It's an E-Flight BL15 motor with ChangeSun 10 blade fan and Cyclone Power 85 AMP w/ 5amp switching BEC. It's the ESC giving me the trouble.
After hooking it up it just kinda turns forward and then back but not smoothly. It jumps back and forth. I switched wires...no effect. I went through the programming modes setting timing to auto (default), low timing, high timing and still no effect. These motors (I tried 2 of them) work great with other ESC's. I then put back to factory restore mode and same thing.
Any ideas?
Thanks in advance.
Russ
Old Oct 03, 2012, 10:54 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
bad connection
Any ideas?
Thanks in advance.
Russ
Kind of sounds like a bad connection between the esc and motor. Are you using bullets or they soldered? Check those and see if it makes a difference.
jpflyer is offline Find More Posts by jpflyer
