Old Aug 08, 2012, 07:22 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
makes sense. and i am not in the habit of making slow passes
chas650r is offline Find More Posts by chas650r
Old Aug 09, 2012, 08:10 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
On my first full flight...I came in fairly slow and the nose still was too high and I lost too much air speed before I could get the nose down and that's what caused the crash on the gear that took out the nose gear plywood platform.
On second landing with more speed I could put it perfectly on the runway but with max concentration. So I will find the balance for me of programming with flaps, elevator and throttle to make it work.
Interestingly, my buddy at the flying field has two EDF's (F-22 & F-35) both 70 mm that do exactly the same thing as far as ballooning. This is my first jet to do this.
RGS2010 is offline Find More Posts by RGS2010
Old Aug 09, 2012, 08:38 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Again cg at 62mm
Flaps at 30 degrees and land with half to 1/3 throttle. Depending on the headwind
pavcon is offline Find More Posts by pavcon
Old Aug 09, 2012, 09:38 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Originally Posted by pavcon View Post
Again cg at 62mm
agreed, cg is very important on any w/ narrow wing cord. i have found as little as a 1/8" change can make a big difference. sounds like u are describing pitch sensitivity which lots of airframes display . i always make sure to have a positive rate of descent on approach , keeping the nose down slightly , use the throttle to control rate of descent and elevator to keep the nose down and flair only at the ground. when i find it's hard to make small enough adjustments w/ the elevator then its time reduce travel and or add expo and or move the cg slightly forward.
chuck.
Old Aug 09, 2012, 11:07 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Thx and will try to get some good video this weekend.
Old Aug 09, 2012, 06:10 PM
pavcon is offline
Joined Jan 2010
I would suggest that if you are moving cy forward keep your elevator travel as it is since you will notice less eeffectiveness with cg cuange only
Old Aug 12, 2012, 07:34 PM
AlphaWhisky is offline
Find More Posts by AlphaWhisky
Alpha Whisky
Queensland - Australia
Joined Jan 2006
Lander Panther
Test only.
Still trying to simply pics here in a simple manner. If this works, you get to see my recently hand/bungee launch Panther ready to go..... (This model 3S powered - I`m about to start on its 4S powered replacement shortly)
Alan W
AlphaWhisky is offline Find More Posts by AlphaWhisky
Old Aug 12, 2012, 07:35 PM
Alpha Whisky
Joined Jan 2006
Originally Posted by AlphaWhisky View Post
Test only.
Alan W
Eureka!
Alan W
Old Aug 12, 2012, 11:30 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Test only.
Alan W
Thanks for the photo Alan.
I'm still setting myself up for bungee launching (even got the bungee chord) cos I think all my flying friends are getting sick of their nickname - 'Chuck'!!!
Apart from the Panther, I've also got a HK F-14 and (yet to be finished) FF Super Sabre that would benefit from bungee launching.
One question though; is the ramp absolutely necessary for planes like the Panther that have a smooth underbelly?
Was thinking that I might be able to just sit it on the grass for the bungee release?
Cheers
Dave
Goody63 is offline Find More Posts by Goody63
Old Aug 13, 2012, 01:18 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Hehe, watch what happens if it pulls a little bit amiss and one wing catches grass......
Ramp = safer.
PeterVRC is online now Find More Posts by PeterVRC
Old Aug 13, 2012, 02:36 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Ramp = safer.
Ok....I can imagine
I'm just being lazy.
Off to Bunnings I go......
Cheers
Old Aug 21, 2012, 09:41 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Weekend Flying
Had two good flights this weekend. I had my CG at 62mm and was still getting too much ballooning on landing so I moved battery forward about 3/8 inch. It made a noticeable difference on landing and not much difference on takeoff. It flew well in the air and still ballooned if reduced power quickly but if power is removed gradually on landing and you get low on landing to start with, then the effect is much less. I made a perfect landing the FIRST time!
The second time was a great flight but I came down too hard, trying to push the envelope and the nose wheel strut folded in. Now, of course, i got the second flight on video (will post when I get it compiled).
I have the metal mechanical retracts and I will replace with electrics when I get the flight characteristics down pat but for now I am just going to JB Weld the nose wheel from being able to fold again (it will still steer) until I make the electric retract mod.
Great flying plane in the air...getting a bit of twist when I fly a loop and trying to figure out which way that I need to trim the rudder to counter. Right now I'm too preoccupied with landing to worry about too much else.
More later,
Russ
Old Aug 21, 2012, 10:05 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
russ just a thought, the elevator can be very stiff at the hinge line , i had to work mine a lot by over bending . maybe u are getting flex/ twist that would cause roll w/ elevator?
chuck.
Old Aug 21, 2012, 10:35 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
chuck.
I'll check it Chuck...thanks. You are right that puppy is STIFF...I worked it too but never really got it where I wanted it.
Old Aug 21, 2012, 04:20 PM
killickb is offline
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Can't remember if the elevator has a foam hinge as sent from factory? Been flying mine for two years now with no problems -- its basically become an EDF trainer. Anyway I remember my elevator being stiff so cut it off and re hinged using pinned hinges. The slight dihedral using that wire elevator half connector doesn't help any, could also be causing different throw of each half = roll coupling? Should be able to check that on the bench.
killickb is offline Find More Posts by killickb
