Old Nov 19, 2011, 02:17 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Tim,
Sorry.. I guess that I am after part numbers & dealers (I'm in Australia).. can you help with this?
BulletMaster is offline Find More Posts by BulletMaster
Old Nov 19, 2011, 06:02 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I fixed the nose and took a pic. I feel better now..... other then the snow that fell today! Argh.
Vintauri is offline Find More Posts by Vintauri
Old Nov 20, 2011, 02:29 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
gorgeous mate.. for me this is by far the best looking scheme..
take good care of her .
pavcon is offline Find More Posts by pavcon
Old Dec 06, 2011, 01:42 AM
Tarolog is offline
Find More Posts by Tarolog
Tarolog's Avatar
Joined Mar 2011
question
Hi guys. I want to buy this model. Give me please, what battery is best to put? What are the wheels? And there is in this model, the turning mechanism on wheels, or I have to do a rotation mechanism?
Tarolog is offline Find More Posts by Tarolog
Old Dec 06, 2011, 03:10 AM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Good battery: http://www.hobbypartz.com/77p-sl3000-6s1p-40c-6666.html good Landing gear:http://www.sonicelectric.com/Merchan...roduct_Count=4 good Motor and fan: http://skyartec-usa.com/product_info...roducts_id=461. Enjoy your panther !!
DaveBC is offline Find More Posts by DaveBC
Old Dec 06, 2011, 07:55 AM
pavcon is offline
Joined Jan 2010
the landing gear is for the cougar.. don't get those/... it's shorter..
Old Dec 06, 2011, 08:03 AM
pavcon is offline
Joined Jan 2010
http://www.hobbyking.com/hobbyking/s...dProduct=17220
fan unit.. best you can find out there for this model that will have power and also good flying time
http://www.hobbyking.com/hobbyking/s...dProduct=17248
I'm flying with those 6minutes and have time for 2 go arounds and still have juice. also balances perfectly ..
and get an 80 amp ESC I'm flying with a 60amp though :P Turnigy plush 60amp
if you are getting the plane from HK it will include the good
http://www.hobbyking.com/hobbyking/s...dProduct=15092 these are the landing gears to get..
you will need some work to install... minimum work actually.. in fact the same work to convert the original mechanical ones to these because these are the exact same as the rclander
Old Dec 06, 2011, 11:49 AM
Tarolog is offline
Tarolog's Avatar
Joined Mar 2011
The manufacturer recommends for this model Battery 3700mAh 3s ~ 5000mAh 3s Lipoly Battery http://www.hobbyking.com/hobbyking/s...dProduct=17219 What happens to the engine if I put 4S??? can be selected 3S???
Old Dec 06, 2011, 05:41 PM
pavcon is offline
Joined Jan 2010
if you are getting the one with an edf unit and not the kit then the 4300kv is for 3S ONLY.. 4s will only last for a few minutes or couple of flights..
Old Dec 07, 2011, 04:25 AM
Tarolog is offline
Tarolog's Avatar
Joined Mar 2011
Thanks guys for the advice. What else pay attention?
Old Dec 07, 2011, 06:26 AM
pavcon is offline
Joined Jan 2010
the e-retract mounts will always stick out 2-3mm. don't try to dig the foam too much.. that's the way it is for those wood blocks. otherwise you will end up witha hole on your wing
the CG is at 62mm from wing tip.. don't try the recommended 70mm .. you will end up super tailheavy and unable to land safely..
oh and also if you have a heavy plane like min at 1820g flying weight.. flaps are good.. they are good
of course the flaps add to the weight ..
God I'm flying too much thi aermacchi I have lately.. I miss my panther.. today is panther day..
Old Dec 08, 2011, 05:51 AM
joee75 is offline
Find More Posts by joee75
Brisbane
Joined Jul 2007
Hey Pavcon, can you help me with the c of g on my panther? I put a 5000mah 409 gram battery in mine, balanced it as per the manual, 70mm, it balanced perfect but it flew like a brick, nose straight into the dirt, 0 lift with flaps, I tried balancing at your recommendation of 62mm and she is coming in tail heavy with my battery in the same position as before..no retracts on mine, hand launch.
Any advice much appreciated
joee75 is offline Find More Posts by joee75
Old Dec 08, 2011, 07:36 AM
pavcon is offline
Joined Jan 2010
my battery weights 485g and it's pushed as forward as possible.
is yours a 3s?
but if you balance at 70mm and comes tailheavy you don't make any sense..
btw you have to measure from where the wing is joining with the fuselage..
Old Dec 08, 2011, 11:08 PM
joee75 is offline
Brisbane
Joined Jul 2007
is yours a 3s?
Thanks Pavcon, balanced it at 70mm from the wing join perfectly and it nosedived.. yes it is 3s with more than enough thrust, my throws on the elevator are set to their maximum of about 16mm each way.
When i tried to balance it at 62 mm that is when it came in tail heavy.
Old Dec 09, 2011, 04:09 AM
pavcon is offline
Joined Jan 2010
if you balance it at 70mm it will come more tailheavy.. what do you mean??
balancing at 62 ist means you have more weight on the front..
balancing at 70 means more weight to the back meaning tailheavy..
you are confusing me..
