Old Nov 13, 2011, 01:33 PM
Gravity Dodger is offline
Find More Posts by Gravity Dodger
White stuffs here time 2 build
Gravity Dodger's Avatar
Minneapolis Minnesnowtah
Joined Nov 2007
Thanks guys. Yes Steve I'm afraid it's only a matter of time before we'll have snow so I'm preparing to enter building mode myself, hopefully the weather holds so you can get your maiden in.
Gravity Dodger is offline Find More Posts by Gravity Dodger
Old Nov 13, 2011, 06:38 PM
velyter is offline
Find More Posts by velyter
Aviator
Bellevue, WA
Joined Dec 2007
Panther nav lighting
Has anyone wired the RC Lander pre-installed nav lighting system yet? I purchased the PVC version with Nav lighting and the instructions are a little funky. I got the lights to come on but the lighting ring in the exhaust comes on and stays on. I have it wired to the throttle port in the rx and I have the on/off wired to the gear port but it does not turn on and off with the gear switch. I am using a JR 10sx transmitter 2.4 gz.
Any help would be greatly appreciated.
Vern
velyter is offline Find More Posts by velyter
Old Nov 14, 2011, 12:34 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Vern
oh that thing is really sensitive. I did it on my dead/crashed/problematic panther but I decided to leave it off this one. those sensors on the light box is really pain in the ass to set.. play with those.
pavcon is offline Find More Posts by pavcon
Old Nov 14, 2011, 11:16 AM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
I got the light ring to work with the throttle but the on/off switch does not work.
Vern
Old Nov 15, 2011, 12:15 AM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Vern
Have you adjusted the VR1 and VR2 Pots? Slowly turn VR1 until the light go out with the switch on Tx to off position. Adjust VR2 to increase or decrease the Afterburner ring intensity. See the attached pictures for more help and information
Max
www.parkrcmodels.com
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Nov 15, 2011, 11:01 AM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
Max
Thanks for your help. The instructions have position 3 plugged into the gear switch which makes sense the lights go off when the gear goes up. Is that correct or should the lead go into aux 2?
Old Nov 15, 2011, 11:04 AM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
Max
I am using a flight pack LIFE battery to run the servo's so I don't need to plug into the 3s lipo on my 6s set up?
Old Nov 15, 2011, 11:21 AM
pavcon is offline
Joined Jan 2010
QUESTION..
Th EDF unit I have is the new DPS system 3580kv with p/n LEDFDPS68-1A36
now on giantcod there is this new one DPS68-1A40 68mm which is also 4s and claims to be 4000kv.
what exactly are the diferences??? because the specs are exactly the same..
Old Nov 15, 2011, 11:22 AM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Is it DPS2?
SMorrisRC is offline Find More Posts by SMorrisRC
Old Nov 15, 2011, 11:37 AM
pavcon is offline
Joined Jan 2010
no it doesnt say DPS 2.. it's not even in RClander page but Ive seen it somewhere else too.,
btw my DPS replacement arrived from Tim Wan. got one from HKing that got a hit during transit and guess what.. HK wouldn't replace it. Tim Wan did..
i hope it's the new one it's going in my Cougar
I also pmed Tim Wan nad see what hes got to say
Old Nov 15, 2011, 11:54 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
Tim Wan has the BEST CUSTOMER SERVICE ever.
Old Nov 15, 2011, 11:59 AM
pavcon is offline
Joined Jan 2010
I know .
I have many experiences with him and I guess I have the best.. some you can discover in this Thread
Old Nov 15, 2011, 12:13 PM
bonzaiglenn@bt is offline
Find More Posts by bonzaiglenn@bt
blackpool-england
Joined Oct 2007
Hi Guys,
Just got a basic airframe kit today and without reading all the pages what fan/motor combo do you recommend.
I have been give a :68mmfan/Motor 3400kv (14.8v) (but it could be the 3400kv, cant remember)PH019-11 Fan -Impeller 5 Blade -From a Phase3 Squall.Would this be any good??
Thanx
Glenn
bonzaiglenn@bt is offline Find More Posts by bonzaiglenn@bt
Old Nov 15, 2011, 07:48 PM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
Max
I have it on the aux 2 and if I put the switch to off and then turn down pot until light goes off it won't come back on when I flip the switch back to on. I also put it into aux 1 for the gear and that does not work either.
Old Nov 16, 2011, 02:52 AM
pavcon is offline
Joined Jan 2010
I got my answer from Tim Wan regarding the DPS series.
The first ones were 3580kv. According to Tim The performance was good but not stable to all 4pole motors.so they cahnged the batch to something new that's more stable and meets or overcomes the performance illustrated.
to add to that my own 3580kv DPS was producing 1030 watts at 69 amps so I was very satisfied since it was pushing my 1.82kg panther real well.
Now in my 1.4 and 1.38kg cougar(depending on what battery I use) this should perform real well can't wait to maiden the F9F-8 now
Once again Thanks Tim... Great Service..
And also.. I got the Mig-17 retracts and struts to put in my flyfly MB339.
They look absolutely GORGEOUS. anw.. on the work bench now
