Old Sep 21, 2011, 07:01 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
1.31??? with pack??? where does the extra half kilo comes from in mine?
pavcon is offline Find More Posts by pavcon
Old Sep 21, 2011, 07:54 AM
BRIARCROFT is offline
Find More Posts by BRIARCROFT
maghull , merseyside
Joined Aug 2010
Hi pav, mine is 950gm - no batt, u/c or flaps but with 3575kv lander fan.
Could be you have got the heavier foam.
BRIARCROFT is offline Find More Posts by BRIARCROFT
Old Sep 21, 2011, 09:58 AM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Duct tape? sorry, couldn't resist.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Sep 21, 2011, 01:38 PM
pavcon is offline
Joined Jan 2010
ahhahahahhahahhahahahhaaa..
noooo.. no wounds on this plane mate.. even 1 repair that been done it was it the same hot glue that I had in there to reinforce the front ertract plate.. I just remelted that one..
this plane is still clean
Old Sep 21, 2011, 02:15 PM
DaveBC is online now
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Odd problem. My Panther ESC caught fire. I was able to put it out but not before it burned the inside of the fuse to an irregular shape. And when I changed the ESC it wouldn't take off. Just run down the runway. So, I thought it was a damaged motor. (should have check watts up meter). Changed the motor to a new HET 2W-25 and off to the field. SAME THING ! runs like crazy down the runway but no lift off. What the heck I'm wondering if the irregular fuse interior is messing with the air flow. Like buffetting or somethng. Watts up meter shows 1100 watts. Should fly fine. Any one got any Ideas?
DaveBC is online now Find More Posts by DaveBC
Old Sep 21, 2011, 02:18 PM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Which ESC was it?
mike2663 is online now Find More Posts by mike2663
Old Sep 21, 2011, 03:17 PM
SMorrisRC's Avatar
UK
Joined Jan 2010
Can you get a pic?
Old Sep 21, 2011, 03:22 PM
Obessive Compulsive
Visalia, California
Joined Mar 2010
Originally Posted by mike2663 View Post
Which ESC was it?
Both the old and the replacement are Hobbywing 80amp ESC's.
Old Sep 21, 2011, 04:36 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
well at 1100 watts and runs like crazy down the runway u would think it would fly.
how about an incidence problem from the heat when it burned? if the wing to horz stab changed just a small amount or if the angle of attack on the gear changed to less positive it may just be being pushed to the ground.
chuck.
chas650r is offline Find More Posts by chas650r
Old Sep 21, 2011, 05:05 PM
pavcon is offline
Joined Jan 2010
and what about becomming more noseheavy whe n it burned material from the back??
Old Sep 21, 2011, 10:52 PM
Obessive Compulsive
Visalia, California
Joined Mar 2010
chuck.
What a great idea. I would have never thought of that. I'll look for any sign of warpage.
Obessive Compulsive
Visalia, California
Joined Mar 2010
Plane still balances on the CG
Old Sep 22, 2011, 07:15 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Just a thought when sitting on it's gear is the plane sitting in a nose low I once installed a new set of retracts in a EDF that way and ran like a bat of of hell but would not rotate. Changed to a positive stance and the problem was solved.
Old Sep 22, 2011, 01:28 PM
Obessive Compulsive
Visalia, California
Joined Mar 2010
I understand angle of attack issues. But keep in mind this plane has flown fine for two years. Only thing changed is fire. ESC and Motor.....
Old Sep 22, 2011, 01:37 PM
pavcon is offline
Joined Jan 2010
have you done that watt test?
if it's not power it's definetely some king of incidence since the elevator surface is moving fine
