Old Sep 06, 2011, 05:40 PM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
wrong post
pavcon is offline Find More Posts by pavcon
Old Sep 06, 2011, 09:29 PM
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
Thanks for the input on the landing gear. I wonder if the less expensive HET retracts are also good?
Another thing that I am wondering is if it is worth it, or even needed to do a bolt-on wing mod? It seems like Tim recommends epoxy, and he has designed the Panther to allow access to everything through the canopy.
Gamerjoe is offline Find More Posts by Gamerjoe
Old Sep 06, 2011, 10:20 PM
Cottonwood Arizona
Joined Aug 2003
I have a Panther and a Cougar, I converted both to servoless retracts for $7 per retract:
Main & Nose (I adapted or nose gear too)
http://www.hobbyking.com/hobbyking/s...dproduct=12883
If you want a nose gear specific with less work I use these on my P-38:
http://www.hobbyking.com/hobbyking/s...teerable_.html
I bend my own struts to fit the model. If you spend more on E-flights your wasting your money.
Chris
topher39 is offline Find More Posts by topher39
Old Sep 06, 2011, 10:44 PM
Boise, Idaho
Joined Jan 2006
The only other retracts I tried were the FlyFly ones. Useless in my opinion, but that was over a year ago so they may have improved.
When I converted my Panther there were few to choose from, HK did not offer any at the time.
I have some Eflites on a larger model, and they are perfect. But to each his own. we know the RClanders work on the Panther, but no doubt there are others...
v2plus10 is offline Find More Posts by v2plus10
Old Sep 07, 2011, 07:03 AM
Joined Jan 2010
man... read on the post...
the 7 dollar hk retracts ARE EXACTLY THE SAME RCLANDER E-RETACTS + THE STRUTS...
exactly the same..same make same specs same everything..
Old Sep 07, 2011, 04:04 PM
S.A.D Member
gooseman's Avatar
West Midlands
Joined Jun 2002
Panther
Gents,
i read someone earlier saying they cant wait for a video of a panther with out music
well here is mine
this has retracts but the grass was longish and bumpy, plus it hand lauches so easy anyway.
has a lander 3575kv fan in it with turnigy 4s1p (20c) pack up front
DSCF3369 (4 min 8 sec)
enjoy it shifts
Gooseman
gooseman is offline Find More Posts by gooseman
Old Sep 07, 2011, 04:07 PM
Joined Jan 2010
i could have taken so many videos of mine with the new dps system
But the guys at the field are lame cameramen
Old Sep 07, 2011, 04:09 PM
Joined Jan 2010
btw check out dsr-a and dsr-b retracts from hobbyking.
The longer of the two are the ones for the panther and the shorter ones are for the cougar
Old Sep 07, 2011, 04:33 PM
S.A.D Member
gooseman's Avatar
West Midlands
Joined Jun 2002
Retracts
I got a set for the hawker hunter off HK,
but they not a simple replacement, quite a bit of bodging to do to install them
the nose gear is the worst as the originals sit on metal posts and these are too long for the e-tracts
Gooseman
Old Sep 07, 2011, 04:37 PM
Joined Jan 2010
those are not for the hawker. And as i said on a previous post... You need to spread the wooden blocks a bit to fit the e-tracts
Old Sep 07, 2011, 04:44 PM
S.A.D Member
gooseman's Avatar
West Midlands
Joined Jun 2002
Retracts
Pavcon,
I know they not for the Panther , thats why i mentioned i got a set of e-tracts from HK for the Hunter.
The point was i know about them and have a set for my hunter. they a lot of work for the hunter.
below is a post i sent to you previousely on the HK forum
Pavcon,
The dsr-A are for the hunter and the dsr-B for the panther as they have longer oleo's
The dsr-C are for the f-16 and have the angled axles
regards
Grant
Old Sep 07, 2011, 04:47 PM
Joined Jan 2010
the dsr a is for the cougar .. thats what i discovered later ,)
Old Sep 07, 2011, 04:48 PM
S.A.D Member
gooseman's Avatar
West Midlands
Joined Jun 2002
Retracts
Yep, but also same ones for Hawker Hunter
Grant
Old Sep 07, 2011, 06:41 PM
Cottonwood Arizona
Joined Aug 2003
Ok Guys, I know this has been covered before but I am looking for a quick answer - I have a HET Fan that a friend gave me. Does the HET Fan do well on 4 cells with a 3200 KV
Same or Better than the Wemo Fan on same 3200
Thanks!
Old Sep 07, 2011, 08:02 PM
Joined Jan 2010
the het fan is better on higher kv..
the wemo is slightly and sometimes not noticeably better..
on high rpm Ifind the het better because it draws less amps.
