Old Aug 14, 2011, 09:05 PM
AlphaWhisky is offline
Find More Posts by AlphaWhisky
Alpha Whisky
Queensland - Australia
Joined Jan 2006
I eventually got that cockpit hatch off - had to push like crazy from the underside. I can`t see how I will ever get it to release once the bottom forward fuselage is glued on.
Will definitely change the catch detail - will look at shifting the plastic two-pin thingy forward from the aft end and maybe putting a magnet back there ...
Another minor mod I will do as learned from my recent HK F-18. I have made up a plug from scrap foam to fit inside the flimsy nose cone. This time I will glue the nose cone in place last in case I might need to add some nose weightand in there will be the ideal location .....
Alan W
AlphaWhisky is offline Find More Posts by AlphaWhisky
Old Aug 15, 2011, 05:23 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Alan W
did the same thing on the nose cone with my F-22. It's a good place to hide the leads
pavcon is offline Find More Posts by pavcon
Old Sep 02, 2011, 02:05 AM
Gamerjoe is offline
Find More Posts by Gamerjoe
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
Alan W
Wow, I am having the same issue with my canopy! I am pressing pretty hard from underneath and I do not see this thing coming off without breaking it.
If I ever manage to get the canopy off, will I need to trim foam to make it fit better for battery changes?
Gamerjoe is offline Find More Posts by Gamerjoe
Old Sep 02, 2011, 02:23 AM
Alpha Whisky
Joined Jan 2006
Sure, it`s a neat fit but I don`t see it as an issue for trimming any foam. Seems to me that the plastic catch is just too tight and there is no handle or lever there to help release it. I`ll still intend to go the magnetic catch way.
I`m currently held up awaiting delivery of extension leads so I can glue the tail in place. While waiting I took out that nasty little snowman pilot and replaced him with a more acceptable HK guy ....
Alan W
Old Sep 02, 2011, 04:39 AM
pavcon is offline
Joined Jan 2010
yeap.. The problem is the plastic catch...
Havent done any mods yet to add magnets but i should to be honest
And then there is the pilot i also replaced it with an rclander pilot
Old Sep 02, 2011, 09:23 AM
topher39 is offline
Find More Posts by topher39
Cottonwood Arizona
Joined Aug 2003
(shifting the plastic two-pin thingy forward from the aft end and maybe putting a magnet back there ...)
That is exactly what I did with my hatch, swapped the plastic 2 pit to the front and 2 rare earth magnets to the back, used two flat head counter sunk wood screws into the foam for the magnets to cling to. I did shave some foam off the rear of the hatch because on mine the tight fit lengthwise was making the hatch bow just a bit in the center.
topher39 is offline Find More Posts by topher39
Old Sep 02, 2011, 08:28 PM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
maiden
I maiden the panther today, i like this one better than my cougar, but it was hard to see, the grey and blue drowned out in the sky. but flew nice with the sapac mb1, with a 5s 3000 pack.
Mannyman535 is online now Find More Posts by Mannyman535
Old Sep 02, 2011, 11:02 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Sapac MB-1 Black Tornado on 5S will melt its motor mounts if its not mounted on an alloy EDF. (ask me how I know)
DaveBC is offline Find More Posts by DaveBC
Old Sep 03, 2011, 01:39 AM
edf flyer
Joined Feb 2009
I have never had a problem. It pulls just over 1000 watts
@ 70-80 amps. I had it in my sapac l-39 composite
Old Sep 03, 2011, 02:58 AM
DaveBC is offline
Obessive Compulsive
Visalia, California
Joined Mar 2010
Hmmm that's seems pretty low.. you should be getting more like 1600 - 1750 watts with that on 5S. Are you useing a good 40C or better pak? Is your ESC timing set to Hi (15 to 22 degrees)?
Old Sep 03, 2011, 03:08 AM
pavcon is offline
Joined Jan 2010
I wonder why ppl still go with the sapac which is an amp hog and can destroy batteries when they can have something much more powerfull on that amp draw.
Old Sep 03, 2011, 06:25 AM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Because its an inexpensive way to get that power.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Sep 03, 2011, 07:56 AM
edf flyer
Joined Feb 2009
My packs are 20c. And the motor is only rated for 1000w max
Old Sep 03, 2011, 07:57 AM
edf flyer
Joined Feb 2009
What motor would u recommend
Old Sep 03, 2011, 09:01 AM
pavcon is offline
Joined Jan 2010
well I get 1000watts + on 4s with 65amp draw with my rclander EDF unit. Runs cool and smooth.
some have tried it on 5S with success.
oh and forgot to mention thatit's only 65usd from HK
