OK it seems that I am being misunderstood so let me try to explain it differently.
Back on post 2997 it was recommended by by schoonerj that my CG be between 70 and 65 mm from the leading edge. So if this is the case, should my Panther balance anywhere with in this range I should be OK on flight, give or take a little on flight preference. The following text by Vic, Quote:
Thanks again for all the help, Orion |
I have been flying mine with gear up as the field I was at was to rough so have been hand launching it. I went to a new field yesterday and on the first landing the nose gear/battery tray popped right off, so out the retracts came! I am staying with belly on mine.
Don |
Latest blog entry: Wicked Powered Tech One Neptune EDF!
I originally flew the Panther on a 3s Rhino 3700 and I needed some nose weight (the 4s setup didn't need it from what I saw/heard). Odd... I would just start shuffling equipment as aft as possible. Last thing I would do is add weight to the tail. I'm not doubting your situation, it's just kind of an oddball, or maybe I'm not understanding correctly again...
Also my AUW is 1658 g. |
Guys are freaking out, the panther is forgiving, how nose heavy are you, is it really bad nose heavy at 65mm? I dont think it is, i ballanced mine a minute ago at 65mm and the nose droops, as for when its flying it needs down trim, yes ballance it upsidedown!!
It wont bite you if its nose heavy for the first flight to see what "its really doing", if when you fly it like it is now and it is a tad nose heavy it the air, come the landing approach you just need to bleed off the speed as she floats like a leaf on water! |
![]() Orion, It should still fly really well with CG forward at 65mm. Really hope you get your CG issue sorted out, the Panther is awesome, just a pleasure to fly everytime! |
Does anybody know what is a good color match for the blue as I need to touch up the belly a little? I figure there must be a Model Master color that is a good match?
Don |
Don,
I've looked for a match for almost every color... You can get really really close, but I usually end up having to lighten or darken it up a shape. Actually, to match my F-16's light gray I had to add some light blue!!! It is possible to mix up a matching set of paint using Model Masters, but the stock touch-up paints are your best bet. Vic |
SOOOOOOO when you gonna fly it ACE??????? Maidened the Lancair. I think she is pretty darn fast. James |
