Old Sep 06, 2009, 06:32 AM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Hi - just a question on the stock lander Panther (the standard EPO version, not the coated one!) on 4 s:
how fast is it approx. in horizontal passes in mph?
markus
relaxr is offline Find More Posts by relaxr
Old Sep 06, 2009, 08:57 AM
giddyuperic is offline
Find More Posts by giddyuperic
giddyuperic's Avatar
USA, CA, Riverside
Not that fast!!!!!!!!! It depends on your setup,wind,temp sea level,ect,ect,ect can you tell us what you are running? Mine does about 60mph maybe 70 on the down line but these birds are not made to be blistering fast.
giddyuperic is offline Find More Posts by giddyuperic
Old Sep 06, 2009, 09:42 AM
Zoomer-Ron is offline
Find More Posts by Zoomer-Ron
Zoomer-Ron's Avatar
United States, FL, The Villages
Joined Jul 2002
I would like to know how large the battery compartment is. What are it's dimensions? I am planning to use Zippy 4S 5000 30C packs. They measure 5 3/4 long by 2 wide, by 1 3/8 thick. Will they fit?
Zoomer-Ron is offline Find More Posts by Zoomer-Ron
Old Sep 06, 2009, 11:15 AM
dustdeb is offline
Find More Posts by dustdeb
dustdeb's Avatar
Germany
Joined Sep 2008
Zoomer-Ron you should be fine, i have to use a rhino 3700 4s pack all the way in the front to get the c of g and its still a tad tail heavy... just bear in mind the added weight? There is loads of room in the battery bay,are you hand launching of using gear?
dustdeb is offline Find More Posts by dustdeb
Old Sep 06, 2009, 11:18 AM
relaxr is offline
RC-Kraut
relaxr's Avatar
Joined Feb 2006
thanks giddyuperic - the speed of 70 mph is ok, otherwise it would be to fast to see its beautiful style in low passes. A fine plane!
Old Sep 06, 2009, 11:43 AM
Zoomer-Ron's Avatar
Joined Jul 2002
Thanks, dustdeb. Still waiting to order. I might hold out for the Cougar. I would get the metal fan, 4S motor, flaps, metal retracts (probably not gear doors) and servos installed.
The club has a nice paved runway. I'm currently flying an early Hobby Lobby F-18 Red Viper on 3S 2200 packs.
Old Sep 07, 2009, 08:24 PM
schoonerj is offline
Find More Posts by schoonerj
schoonerj's Avatar
Berne, NY
Joined Sep 2004
Flight 7, 8 , and 9 today. What a great plane. I ordered some new Turnigy 3600 30C 4S packs, and they really make the Panther scream!
I am planning on ordering new graphics from Calllie. That should add a nice finishing touch!
I can't wait for the F9F-8 Cougar to be released
schoonerj is offline Find More Posts by schoonerj
Old Sep 08, 2009, 07:23 AM
grbaker is offline
Find More Posts by grbaker
La Porte, Texas
Joined Sep 2004
Bigger batteries
I'm running Rhino 4S 25C 5000 mah packs in mine. Flies great!!!
Hand Launch
grbaker is offline Find More Posts by grbaker
Old Sep 08, 2009, 08:05 AM
Zoomer-Ron's Avatar
Joined Jul 2002
Hand Launch
Good to know. They should be the same size as the Zippy's.
Old Sep 08, 2009, 08:07 AM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Rhino's
Rhino's are usually a little bit longer than Zippy/Turnigy batts.
jpflyer is offline Find More Posts by jpflyer
Old Sep 08, 2009, 09:37 AM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Alright guys, I am finally finishing up my build. I am hooking up wires and going to primer it some time this week. Before I take to the skies can anyone recommend a good CG to start from?
Orion Pax is offline Find More Posts by Orion Pax
Old Sep 08, 2009, 02:29 PM
schoonerj's Avatar
Berne, NY
Joined Sep 2004
I started out at the factory recommended 75mm. I thought the plane was a bit touchy, and required a lot of down trim. I changed the CG to between 65 and 70 mm, and I am much happier with it.
So I would recommend starting at 65mm or so, and you can move it back from there.
Just my 2 cents.
Old Sep 08, 2009, 02:52 PM
Orion Pax's Avatar
Joined Dec 2006
Thanks Schoonerj
Old Sep 08, 2009, 03:13 PM
jpflyer is offline
Joined Oct 2001
My Panther is on the way
I just got an email that said my Panther has been shipped, yipppeeee.
Old Sep 08, 2009, 05:48 PM
schoonerj's Avatar
Berne, NY
Joined Sep 2004
Orion,
Good luck with the maiden!
