Old Aug 27, 2009, 10:21 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
Nitro... you will love it. Did you get the new metal retract version... I have been slack, still not finished fitting the new oleos to mine yet..
BulletMaster is offline Find More Posts by BulletMaster
Old Aug 27, 2009, 04:08 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Busted the nose off mine on Saturday due to pulling up too soon on takeoff. Tip stall and nose in. Clean break though and will be easy to repair. My LG is still the original plastic, and I have the metals on hand, so I will also swap those out before the next flight.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 27, 2009, 06:59 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Got it as a belly lander - but have a real nice set of MAP air retracts here that may get retrofitted.
NitroCharged is offline Find More Posts by NitroCharged
Old Aug 29, 2009, 04:07 PM
sperry is offline
Find More Posts by sperry
St.Petersburg, FL
Joined Feb 2004
Has anyone had success getting the landing gear doors to work with the newest all-metal suspension landing gear?
sp
sperry is offline Find More Posts by sperry
Old Aug 29, 2009, 06:57 PM
giddyuperic is offline
Find More Posts by giddyuperic
giddyuperic's Avatar
USA, CA, Riverside
Yes
What part are you having trouble with??
giddyuperic is offline Find More Posts by giddyuperic
Old Aug 29, 2009, 09:22 PM
USA, CA, Riverside
Sorry that is the hunter not the panther. Sorry my Bad>>>>>>
Old Aug 31, 2009, 07:59 AM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
I had heard that the new retracts with suspension had fit issues with the gear wells and the gear doors. I was hoping someone had gotten them all worked out.
sp
Old Aug 31, 2009, 06:24 PM
Chillaxin dude!
Joined Apr 2003
still haven't sorted mine yet Sperry (but then again I am slack )
Old Aug 31, 2009, 07:46 PM
USA, CA, Riverside
Right now I have the suspension out of the hunter and I tried to fit them into the F9 panther and they are a lot bigger. So the whole area would have to be hoged out and two bigger wood mounts made to fit them it the Panther for sure. No way are the just going to slide right in. On the other hand I got the stock one's to work a lot better. There was no flat spots on the rod on the gear so the just kept spinning around and that was causing the gear to fail.
Old Aug 31, 2009, 09:00 PM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
Mine came with the original thin ply mounting strips, so I will need to replace them with hardwood sticks no matter which gear I end up using.
I'm waiting on the mailman for both the metal bodied and the suspended gear. I'll have to see how much hogging out is required in relation to where my gear doors mount. If that poses a problem, I'll use the metal bodied un-sprung set.
sp
Old Sep 04, 2009, 01:05 AM
Jim Petro is offline
Find More Posts by Jim Petro
Gary, IN, USA
Joined Jul 1999
Is there warranty on the 4s fan/motor? I bought the RC Lander EPS Panther with the 4s power unit in February and just finished it in August. 1st flight was once around the field and landed because it was tail-heavy. The next flight was after rebalancing and was doing very well but as I decided to land with adequate power reserve, the plane began making a loud raspy sound and power quit. Landed OK.
I thought the 60A ESC failed and ordered a Turnigy 80A ESC with ubec. When I replaced the "bad" unit, I found that the new one got very hot and only ran 5 seconds before the motor quit and hot electrical stink blew out the tailpipe. The new ESC is outside the body and not the source of the smell. This fan/motor was/is a vibration free powerhouse for it's short life.
I welcome comments and suggestions.
Jim Petro is offline Find More Posts by Jim Petro
Old Sep 04, 2009, 02:55 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Best thing is to contact your supplier and explain. I'm sure its possible to see if the motor/fan has been abused or not and for them to repair/replace under warranty. It is possible they have had a bad batch and will simply replace it without question, but they may not admit to that.
Keep calm and explain the situation and you might be suprised by the results. If your supplier will not help contact the manufacturer direct.
Good luck and let us know how you go.
clive45 is offline Find More Posts by clive45
Old Sep 04, 2009, 03:42 PM
Lexta is online now
Find More Posts by Lexta
Lexta's Avatar
Victoria BC Canada
Can someone help me find where I can get a new nose cone for the Panther?
Lexta is online now Find More Posts by Lexta
Old Sep 04, 2009, 05:23 PM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
I got my replacement nose cone from EJF. Order 2 they're cheap but easily damaged.
sp
Old Sep 04, 2009, 08:59 PM
Lexta is online now
Lexta's Avatar
Victoria BC Canada
sp
thanks
