Old Sep 04, 2008, 04:37 AM
Airbusboy is offline
Find More Posts by Airbusboy
Airbusboy's Avatar
Bishops Stortford, UK
Joined Dec 2005
I fly off grass too, and have done the same mods as you, but I have found the gear legs are forever getting bent backwards. They weren't designed to get hammered from use on grass. I've got on order a set of SF retracts as used on the Executive Jet. They have a pre bent spring coil on the gear legs, but apart from that they look identical so should be an easy swap. Been thinking about a set of metal body retracts as well as from previous experience the plastic won't last. You guys who fly off smooth tarmac surfaces are sooo lucky !!
Airbusboy is offline Find More Posts by Airbusboy
Old Sep 04, 2008, 05:50 AM
xairflyer is offline
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Just want to confirm that the fan unit sits with the curved lip over the curved foremost moulding on the foam as there is no specific grove in the foam for the 8mm ring around the fan unit. I have the 68-1A 4300 fan.
Also do you run the wires Under the fan unit (looking at it with the fuselage upside down)
xairflyer is offline Find More Posts by xairflyer
Old Sep 04, 2008, 10:41 AM
mobird is offline
Find More Posts by mobird
Canada, NS, Truro
Joined Aug 2004
Originally Posted by Tim Wan
Dear Charles,
This flying video was taken on early of last month during rainy and strong wind weather. It was powered by 11.1V 3S 2500mAH x 2 as a maiden flight.
Also the setting was not yet trim well on that time. Due to the weather too bad. I was just taken one flight only on that day. After I am so busy no time to make another flight for her. FYI, She will be taken off again on tomorrow. I will post the video for sharing with all of you.
Thanks for your interesting in our products and welcome any comment.
Thanks.
Tim
Thanks for your explanation Tim, I've ordered a Rafale M from Robert, I'm looking forward to receiving it.
Charles,
mobird is offline Find More Posts by mobird
Old Sep 04, 2008, 10:42 AM
mobird is offline
Canada, NS, Truro
Joined Aug 2004
Originally Posted by AceMigKiller
Hi Charles,
Ohh you meant the Rafale... *sigh* sorry I was reffering to the Panther. I will ask a buddy of mine who is doing the testing on the Rafale and get back to you ASAP.
Vic
No problem Vic, I've ordered a Rafale from Robert, I'll look out for your buddy's post.
Cheers,
Charles.
Old Sep 04, 2008, 10:45 AM
sperry is offline
Find More Posts by sperry
St.Petersburg, FL
Joined Feb 2004
XAIRFLYER asked:
I have the same question concerning the 3900 68-1A EDF unit. Exactly which groove does the front lip rest in?
I am also having some trouble understanding the nose gear retracts. Specifically, Is the steering arm where it needs to be as shipped or is some adjustment of the angle of the steering arm needed?
sp
sperry is offline Find More Posts by sperry
Old Sep 04, 2008, 11:40 AM
Tim Wan is offline
Find More Posts by Tim Wan
Joined Apr 2008
Metal EDF68-1A installation
Dear xairflyer,
Please refer to the attached photoe to install the EDF68-1A fan unit into F9F-2. Since the original postion is designed for our noraml EDF68-1AP. So you need to make a 8mm curvey slot to install the metal EDF set and do the same thing on the EDF cover too. Please be reminded to use two strong double foam tape to fix the EDF set then tight up the long 3mm screw that so.
Hope this above information is clear to you. If you have any question, please feel free to contact me.
Thanks.
Tim
Tim Wan is offline Find More Posts by Tim Wan
Old Sep 04, 2008, 11:59 AM
Tim Wan is offline
Joined Apr 2008
Nose gear steering issue
Originally Posted by sperry
XAIRFLYER asked:
sp
Dear sperry,
Please refer to the attached photoe which can assist you to make the steering better.
Thanks.
Tim
Old Sep 04, 2008, 12:00 PM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Tim,
Just a quick note to say that you are doing an AMAZING job at providing EXCELLENT customer support for your product here!
Bajora is online now Find More Posts by Bajora
Old Sep 04, 2008, 12:19 PM
Tim Wan is offline
Joined Apr 2008
Originally Posted by BARNESJONR
Tim,
Dear Jon,
This is our service and hope everyone to be enjoyed our products well.
Tim
Old Sep 04, 2008, 12:41 PM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
Thanks for the nose gear photo Tim. That answers my question.
I'm still not too clear about the curved slot for the EDF68-1A. Is the curved slot 8mm wide or 8mm from the existing one?
We really do appreciate your responses
sp
Old Sep 04, 2008, 12:56 PM
Tim Wan is offline
Joined Apr 2008
curvy slot
sp
Dear sperry,
you just make 8mm wide of curved slot to fill in the EDF. That is OK.
Thanks.
Tim
Old Sep 04, 2008, 08:44 PM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
I can't believe I did this, though experience says I shouldn't be surprised. I went and lost the nose gear retract pushrod. I've turned the place upside down and cannot find it.
Tim, can I order a replacement from RC LAnder? In lieu if that would someone be kind enough to provide me with a photo or two and some dimensions so I can bend up my own.
I would find the single most complex shape in the box to loose.. Doh!!
sp
Old Sep 04, 2008, 08:47 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia
Joined Mar 2006
Post 172 shows the rod your after I think
clive45 is offline Find More Posts by clive45
Old Sep 04, 2008, 08:59 PM
sperry is offline
St.Petersburg, FL
Joined Feb 2004
Thanks, I was hunting for that pic on the wrong thread. I'm sure I can bend up something that will operate.
I was fitting & fiddling and just couldn't see how I was going to operate the retract with the plastic wheel well in place. Now I see that slot and I'm much relieved. I have this and other threads to hand on my home comuter, but I'm at work now and having to look it all up again.
Thanks Clive
Old Sep 04, 2008, 09:50 PM
clive45 is offline
clive45's Avatar
Australia
Joined Mar 2006
Sperry, no problems at all. Waiting to hear how it goes. I am very interested in one of these as our club is getting anew runway laid but I'm not sure how smooth it will be, also waiting for all the bugs to be ironed out by you guys
So far so good with good back up from the manufacturer..
Cheers
