This thread is privately moderated by darksiede, who may elect to delete unwanted replies.
Old Jul 31, 2008, 12:47 AM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Inventory
Planes:
GWS Slo-stick * (Undergoing rework for a BL setup)
20" flying wing * (Down for repairs)
PZ UM Sukhoi (Waiting on warranty brick)
2x PZ UM Sukhoi SU-26XP (1 waiting on warranty brick, 1 flying)
PZ Champ
PZ Vapor
Eflite Blade mSR
*: denotes currently inop
darksiede is offline Find More Posts by darksiede
Old Jul 31, 2008, 12:50 AM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Inventory:
Motors-
2x 2111 TURNIGY 28-30-azj 14A 1100Kv Brushless Outrunner
1x hexTronik 24gram Brushless Outrunner 1300kv
1x 2000KV Aoxing outrunner
1X Walkera 12mm inrunner 11,000kv, 3.7v 0.7a
1X HK 12mm inrunner w/ 7.1:1 gearbox, No load data: 7.4v, 0.8a, 11830 rpm at the prop
1x EPS 400 (GWS -SS brushed motor & "D" gearbox)
1x HZ 480 (HZ Supercub brushed motor & gearbox)
Chargers-
1x HX8080 hexTronik Balance/Charger (2S to 4S or dual 2S)
2x Turnigy 2-3 Cell Lipoly Balance/Charger
3x Etomic Li-Po charger (3.7v for vapor)
1X Highly modified 1s Etomic charger for 250+ mah cells
1x Celectra 4 port 1S charger (3.7 volt)
Servos-
11x HXT500 5g / .8kg / 10sec Micro Servo
3x HZ proprietary servos (5 wire)
Receivers-
1X AR6100E
Rx & Esc combos-
1x HZ "blackbox" Rx & ESC (3 channel + X-port)
1x AR6400L
1X AR6400
ESC's-
1x SuperSimple 30A BL ESC
1x SuperSimple 20A BL ESC
1x SuperSimple 10A BL ESC
1x Thunderbird 9 ESC
1X Walkera 1s 10A esc
Batteries-
Lipo's:
1x Mystery 2400mah 3S1P 15C
2x ZIPPY 1300mAh 2S1P 20C
2x Mystery 900mAh 2S1P 15C
2x 70MAH 3.7v Li-Po's for Vapor
2X 120mah 3.7v Li-po's for mSR
3X 150MAH 3.7v Li-po's
1X 250MAH 3.7v Li-po
2X Common sense 280mah 3.7v Li-pos
2X Eflite 430mah 20C 2s1p
2X 325mah 45C 1s Thunderpower
Nimh's:
1x 1000 MAH 9.6v NiMh
1x 1000 MAH 8.4v NiMh
Tx's-
1x DX6I (Yeh baby!)
1x LP5DSM (5 channel)
1x HZ Supercub Tx (3 channel + X-port)
Aerial photography/Video gear:
1x 808 #3 Keychain camera
Misc:
Eflite power meter (Watts, amps, volts, mah)
Top Flight Magnetic prop balancer
Tons of props.. but never enough
Old Sep 16, 2008, 06:40 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Yak 55 Setup: This plane has died, fuselage is reserved to make patterns from in future)
2111 TURNIGY 28-30-azj 14A 1100Kv Brushless outrunner
10X4.7 SF prop, 12.5 amps, 2S1P, 95 watts, 152W/lb roughly
3X HXT500 servos, Rudder Elevator Ailerons
AR6200
Supersimple 30A BL ESC
AUW: 10oz roughly
Cheap setup, flies like stink.. good vertical, 10 minute flights on my 1300mah packs, and conservative 6 minute flights on my 900mah packs..
Old Sep 16, 2008, 06:43 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Reflection setup: (again, another dead one, the parts will live on in my Slow-Stick)
09X4.3 SF prop, 12 amps, 3S1P, 151 watts, 161W/lb roughly
4X HXT500 servos, Rudder, Elevator, Ailerons w/ flaperons
AR6100E
Supersimple 20A BL ESC
AUW: 10oz roughly on 2S, 15oz roughly on 3S
Not a bad bird, with the current setup it's definitely 3D, will go straight up and can slow fly like mad with flaperons deployed..
Old Sep 18, 2008, 07:36 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
AX 2306N 2000kv brushless Micro Motor (Aoxing outrunner)
5.5X5.5 Graupner Cam prop, 9 amps on 2S1P, 75 watts, 171W/lb roughly
2X HXT500 Servos, Elevons
AR6100E
Thunderbird 9 ESC
AUW: 7oz roughly
Amazing little screamer, does a hair over 60mph* on 2S, and 75+ on 3S.. at 20 inches it can and does get small in a hurry so I fly it mostly on my 2S packs.. Only chance for 3S is at a buddies house and larger field, borrow his pack and zoom zoom!
*: A little math behind the speed-
5280 feet in a mile, 60 mph covers 1 mile in 60 seconds, therefore, 60 mph, is 88 feet per second (FPS)..
The lot i fly in is 730 foot north to south, and with 2 peoples assistance we have timed level flight passes bi-directionally over 12 times in each direction, the avg time is 8.2 seconds..
730/8.2= 89 feet per second
or 60.681mph
Old Sep 18, 2008, 07:45 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
hexTronik 24gram Brushless Outrunner 1300kv,
9X6 SF prop, 8 amps on 2S1P, 65 watts
2X HXT500 servos, Im thinking Elevons
AR6100E
Supersimple 10A BL ESC
Have this spare setup, trying to figure out a way cheap plane to stuff it in for slow flying.. real slow flying indoors style..
