Old Jul 30, 2008, 02:21 PM
psvpilot59 is offline
Find More Posts by psvpilot59
Joined Jul 2008
Question
SkyArtec Cessna 182 1530kv motor
Hi Guys,
I have had my C182 for several weeks now, but although all controls work ok, I cannot get the motor to work. I have tried with 3 different transmitters. My main Tx is a Futaba ff9. It has a new ArtTech 6 channel dual conversion receiver and compatible crystals. All I get when connecting the lipo is...music? and beeps. Is there any way of checking that the motor is not a dud? I've already had to return a Corona receiver to Hobby City at a cost of around $10.00 so I hope I don't have to send this motor back! Tx battery and C182 Lipo both fully charged. I already did all the Mods as advised by LOBO and I really want to get this plane in the air.
All advice greatly appreciated.
Louie
PS: I'm a Scotsman living in Yorkshire UK.
psvpilot59 is offline Find More Posts by psvpilot59
Old Jul 30, 2008, 07:22 PM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Man I wish I could help. I know that Hobby City offers a device that allows you to program the esc and possibly that is all you need to get the motor to function. I would suggest disconnecting the motor and to try it on a different esc but I know that the motor is hard wired to the esc. So sadly I have no other options for you. Hopefully someone else can chime in here to help you out more.
Orion
Orion Pax is offline Find More Posts by Orion Pax
Old Jul 30, 2008, 08:15 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
re
Louie,
Do you have any other esc's or motors from another aircraft? It could be a bad Rx circuit, esc or motor--although you probably already knew that Simplest/quickest would be to swap out each of those 3 items one at a time. These brushless motors run on a/c current, so I suppose you could cut the motor free from the esc wires and check the a/c output from the esc with a mutlimeter. If all controls work, and esc makes music the most likely problem would in fact be the motor, so why not just order/purchase a similar motor for about $10 and give it a shot?
Let us know what you find...
Sam
Sammy70 is offline Find More Posts by Sammy70
Discussion SkyArTec Cessna 182 Review and Notes Lobo Parkflyers 2915 May 18, 2015 11:27 AM
Motor for TopFlite Cessna 182 Skylane SiPet Power Systems 5 Jan 06, 2009 08:17 AM
Help! Cessna 182 and motor mount willlufixthis? Electric Plane Talk 10 Jan 02, 2008 04:24 PM
Help! Cessna 182 Skyline motor Panto Scale Kit/Scratch Built 0 Feb 01, 2006 01:21 PM
Ultrafly Cessna 182 Motor - Battery Help superboss Parkflyers 4 Dec 10, 2004 10:11 PM
