Old Jul 29, 2008, 10:01 PM
rickquirino is offline
Find More Posts by rickquirino
Joined Jul 2008
6100 binding problem with DX6i
I was able to bind 1 6100 to my DX6i. I attempted to bind a second 6100 to the same DX6i and am having no successs. Now the first 6100 will not work either.
I followed the instructions to bind (re-bind) but can't seem to get it to work. The LED in the RX comes on stedy bright and does not flash when power is applied. This happens on both devices.
Any suggestions about what I may be doing wrong? Or, is there a technical problem?
rickquirino is offline Find More Posts by rickquirino
Old Jul 30, 2008, 10:08 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
With the DX6i TURNED OFF:
Plug the bind plug into the BAT/BIND slot of the 6100. Now power up the 6100 (DX6i is still OFF). The 6100 LED should blink. If not - either 1. the bind plug is bad or 2. it is not in the BAT/BIND slot of the 6100 or 3. the 6100 is bad.
If the 6100 LED is blinking, then follow the procedure in the DX6i manual - AFAIK press and hold the trainer switch and turn the DX6i on. Keep the trainer switch pressed until the 6100 LED is solid amber.
Ivan
ivanc is offline Find More Posts by ivanc
Old Aug 01, 2008, 03:33 PM
Joined Jul 2008
Ivan,
Thanks for the advice. Apparently my procedure was incorrect. I have successfully completed the binding process.
Discussion First problem with DX7 and 6100 BRIT_BULLDOG Simulators 0 May 22, 2008 04:35 PM
Discussion Problem with my Funjet and Spektrum 6100 kushal_22 Pusher Prop Jet Models 5 May 17, 2008 02:53 PM
Discussion Spektrum DX6i Binding Problem berniek Radios 2 May 14, 2008 07:48 AM
The Problem with Electrics is... John E Electric Plane Talk 26 May 28, 2001 10:08 PM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
