Old Jul 29, 2008, 05:34 PM
GLieberman1989 is offline
Find More Posts by GLieberman1989
GLieberman1989's Avatar
United States, CA, Oakland
Joined Jul 2008
Useful Brushless motor comparison chart
Take a look at this useful brushless motor comparison chart I found with hundreds of motors and brands
http://progressiverc.com/Brushless_Motor.html
GLieberman1989 is offline Find More Posts by GLieberman1989
Old Jul 29, 2008, 05:44 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Wow - that's quite a list. I wouldn't want to have to maintain that one.....
BEC is offline Find More Posts by BEC
Old Jul 29, 2008, 05:47 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
The guy that maintains it posts on here somewhere. I believe his thread introducing the battery portion is a sticky in the battery forum on here.
http://progressiverc.com/Research.html
There's MANY more tables than just that one.
habitforming is offline Find More Posts by habitforming
Old Jul 29, 2008, 10:30 PM
caseih is offline
Find More Posts by caseih
Joined May 2005
That's fine and all, but I'd like to know how many amps particular, common (to that motor) props are pulling, and at what RPM they are spinning. This is critical information that's so hard to find. Usually I look at the comments on hobbycity's web site to see this. Would be nice to have this all in one database.
Knowing a motor's Kv is not enough. It was a revelation to learn that 2 different same-Kv motors can spin the same prop at dramatically different speeds (and thus power levels). For example, my hacker clone 20-20L spins a 10x5 prop at 7800 rpm, 14 amps. Another motor (forget which at the moment) will spin that same prop at 10000 rpm (same labeled Kv, mind you!), and at 25 amps or more. The same motor spins a 9x6 prop at 20 amps, 11000 rpm or so.
I don't always understand how the unloaded Kv, the number of poles, the winding type, and the diameter and length of the stator play into things in a formulaic way, so having empirical results gathered over time from many of us would be wonderful. Sure we have spreadsheets and motor calculators, but sometimes theoretical isn't quite enough. There is one motor calculator backed by a large database of actual, empirical results, so that's a good start. It's currently missing most Turnigy motors, though, and I don't know how to convert the specs from hobbycity's descriptions into parameters the motor calculator can accurately use.
caseih is offline Find More Posts by caseih
Old Mar 03, 2010, 02:08 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Wrong thread!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Apr 27, 2014, 08:14 AM
SouthernSig is offline
Find More Posts by SouthernSig
Joined Apr 2014
Updated Link
http://www.progressiverc.com/research
SouthernSig is offline Find More Posts by SouthernSig
Old Apr 27, 2014, 02:20 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
The main reason there's a difference in R's on same kV is efficiency. Good magnets vs poor, metal losses, etc. One is just more efficient than the other for a given kV.....
mrittinger is offline Find More Posts by mrittinger
Motor Comparison Chart jmiceli11 Electric Plane Talk 12 Mar 08, 2010 12:35 PM
Brushless motor comparison. nybpete Power Systems 4 Dec 06, 2004 02:36 PM
Voyager E brushless motor comparison aeropuppy Electric Heli Talk 7 May 06, 2004 05:20 AM
IFO Brushless Motor Comparison dadspet Parkflyers 0 Jul 03, 2003 09:00 PM
Electric Motor comparison chart? dgoebel Foamies (Kits) 5 Jan 14, 2002 05:47 AM
