Old Sep 03, 2008, 10:42 PM
rich95 is offline
Find More Posts by rich95
Heli Whore
Toronto, Canada
Joined Nov 2007
Pretty much what Jim said.
Here's a log of my BL Lama v3. Soon, I'll be posting the CX2.
Components would be virtually the same for this bird, only heavier duty ESC's and stronger motors. This would actually even be easier since the "3-in-1" is already separated from the mixer / gyro as Jim mentioned. No messy electronics dismantling, etc.
Check out the vids of my BL Lama v3 and you'll be pretty amazed at how much more stable it is than stock. I can only imagine how cool this bird would be BL!
http://www.rcgroups.com/forums/showthread.php?t=848751
-Richard
rich95 is offline Find More Posts by rich95
Old Sep 03, 2008, 11:42 PM
ishady is offline
Find More Posts by ishady
Joined Sep 2008
Tq
Thank you for rich95, teammp, Hokum Jim and all for the replies.
Its shopping time.
I wonder hows my helis think about all these modification...LOL
I hope this discussion in not out of topics, since we - coax maniacs - try to convert the big lama into BL anyway.
ishady is offline Find More Posts by ishady
Old Sep 04, 2008, 08:39 PM
ishady is offline
Joined Sep 2008
wire diagram
I wonder if Mr.bz from strongrcmotor.com kind enough to share us all about the exact wiring diagram for all the rx, gyro, mixer, etc needed for LAMA BL convertion.
So we all - the kindergarten of electronics and soldering - would understand the detail and won't crash another LAMA...LOL.
Thanks.
Old Sep 04, 2008, 08:44 PM
rich95 is offline
Heli Whore
Toronto, Canada
Joined Nov 2007
Here's the diagram:
http://www.rcgroups.com/forums/attac...mentid=1733814
-Richard
P.S. I bought all my BL C10 motors from Don at Strongmotors and I highly recommend him. He's a good guy. You'll need different motors than the C10's for this new heli but for small co-axials, the C10's are the best. (I tried the F1818 and they were terrible).
Old Sep 04, 2008, 08:47 PM
ishady is offline
Joined Sep 2008
diagram
Originally Posted by rich95
Here's the diagram:
-Richard
Thanks for the info and suggestion Richard.
I believe mr.Don is a good guy indeed.
Old Sep 04, 2008, 10:45 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
I like dehicka's diagram linked in rich95's post above. The one below is basically the same except it shows the battery connections and shows the gyro control lead floating. If connected it allows changing from rate mode to HH mode from the transmitter on some gyro's.
bz1mcr is offline Find More Posts by bz1mcr
Old Sep 04, 2008, 11:25 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
I'd like Don a lot better if he gave away his motors for free. Overall though, he's been pretty patient with my stupid questions regarding wiring and setup on the brushless conversion.
Barak1001 is offline Find More Posts by Barak1001
Old Sep 05, 2008, 01:46 AM
ishady is offline
Joined Sep 2008
interesting
Interesting to see how the gyro and the mixer could work together to controll the blade spinning, even they went into one mixer.
Better not thinking too hard, now, my head is spinning...LOL
Thanks Don, now we all can make ourself a coax.
Anybody doing the BL convertion and dual swashplate both ?
Old Sep 05, 2008, 02:14 AM
dendog220 is offline
Find More Posts by dendog220
Joined Oct 2007
I am one...
dendog220 is offline Find More Posts by dendog220
Old Sep 05, 2008, 08:10 AM
bz1mcr is offline
AKA Don
Joined Dec 2002
project lama did a BL dual swash Lama. He has flown it a lot with both single and dual swash. He even won a compitition flying it from the down linked dual cameras on board! He flew in and out of buildings without being able to see the heli. It is described very well in his build log http://www.rcgroups.com/forums/showthread.php?t=862602
Old Sep 05, 2008, 11:06 AM
ishady is offline
Joined Sep 2008
BL and dual swash
Originally Posted by dendog220
I am one...
Both guys must be very happy guys..LOL
I hope my turn will be next.
Old Sep 05, 2008, 05:14 PM
ishady is offline
Joined Sep 2008
motor 370
While I buy the BL motors and esc from strongmotor (Don), I already keep what locally available for fun convertion project.
Wonder if is it possible to use the old 4 in 1 mixer (LAMA) for bigger motor 370 x 2 ...HAHAHA...(ready to blow), and why not complete the blade with bigger blade also ??? Fortunately, my local HS supply both the 370 motors (pinion and cable ready) and bigger coax blades for Walkera 53#1.
Old Sep 06, 2008, 11:39 AM
Velktron is offline
Find More Posts by Velktron
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
In line of principle, it is possible to use it "straight" if you don't exceed its rated power level (or, more simply, the current).
You could however build a small circuit board with beefier transistors driven by the 4-in-1, acting as a "buffer": the 4-in-1 sees a very small load, while the additional transistors do the actual hard work. Of course, this will take up some extra weight and space, but it allows using more powerful motors with no risk for the 4-in-1. All that can burn are the final transistors.
Velktron is offline Find More Posts by Velktron
Old Sep 06, 2008, 05:26 PM
ishady is offline
Joined Sep 2008
added board
Adding a second PCB as a buffer is a bright idea, could you please give us a diagram so I could order them to my technician? As I am not an electrical/soldering guy.
Thanks.
Old Sep 07, 2008, 01:36 AM
The Touch is offline
Find More Posts by The Touch
Perth
Joined Jun 2007
Also the EK1H-020 has larger (By 10mm) blades than the 53#1
The Touch is offline Find More Posts by The Touch
New E-Sky Model #EK1H-E010 flightdeck-guy Micro Helis 1 Sep 10, 2005 09:51 AM
Yippee! New E-Sky 2 Sparky_500 Micro Helis 2 Jun 12, 2005 02:23 PM
Brand new E-SKY 3D $185 shipped RCdude1 Aircraft - Electric - Helis (FS/W) 0 Mar 25, 2005 03:56 PM
Brand new E-SKY 3D $215 shipped RCdude1 Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2005 09:48 AM
Fs: New E Sky Honey Bee 2 Ccmp sambo32 Aircraft - Electric - Helis (FS/W) 1 Jan 01, 2005 02:43 PM
