Old Aug 28, 2008, 06:11 AM
teammpp is offline
Find More Posts by teammpp
Northern Ireland
Joined Mar 2005
Yep. I just got an email yesterday saying it was being produced in late August and available early September. Cant wait to get one. Body looks really nice.
Some specs received:
overview : . Driven by two 370 super motors, equipped with digital servo and updated Esky 4ch transmitter.
copper counterweight adopted flybar stabilizes the heli in various flight states, silk-printing process provides bright colored & high lustrous canopy.
The high intensity carbon fiber-plastic made landing skid suits in various takeoff & flight conditions and is helpful to the beginners. Its able to fly outdoors in breeze.
Specification:
l 370 super motor * 2pcs
l 4 in 1 controller
l 7.5g digital servo * 2pcs
l upgraded 4ch transmitter
l 11.1V Li-Polymer battery
Length: 500mm
teammpp is offline Find More Posts by teammpp
Old Aug 28, 2008, 09:03 AM
Velktron is offline
Find More Posts by Velktron
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
I'd like to see an Esky EK1H-020 vs Walkera 53#1 comparative review with all pros and cons, although I'd probably go for Esky due to better electronics/radios and knowing the ruggedness and reliability of the Lama V3. If "xtreme" upgrades appear for this one too, it will be a very interesting camera platform or just fun free flying machine.
Velktron is offline Find More Posts by Velktron
Old Aug 29, 2008, 05:43 AM
teammpp is offline
Northern Ireland
Joined Mar 2005
Once I get the esky i will do a full comparison on the 2. I already have the Walkera 53#1. The Walkera will be hard to beat as far as flight characteristics go. From what I have been told by a couple of sources the blades on the esky are around 500mm too. Should be more stable once balanced and trimmed properly.
Old Aug 29, 2008, 09:42 AM
The Touch is offline
Find More Posts by The Touch
Perth
Joined Jun 2007
I was going to get a 53#1 but I decided to wait after hearing about this one. I look forward to your review Teammpp. Do we have a price estimate at all ?
The Touch is offline Find More Posts by The Touch
Old Aug 29, 2008, 10:42 PM
deadduck is online now
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Pictures
Big coax
Eurocopter
KOB
It's on the Esky website.
deadduck is online now Find More Posts by deadduck
Old Aug 30, 2008, 12:50 AM
Perth
Joined Jun 2007
EK1H-E020 Specifications
(1).Main rotor diameter: 460mm;
(2).Weight:410g;
(3).Length:510mm,width:110mm, height:260mm;
(4).Power system:370 motor*2;
(5).KIT/ARF/RTF:RTF;
(6).Transmitter:4 CH (including training switch and simulator port);
(7).Mix controller:Receiver and 3in1 Controller;
(8).Servo:digital servos;weight:7.5g;torque:1.3kg.CM;speed:0.12S/60
(9).Battery:11.1V 800mAh Li-polymer battery.
HM 53#1 Specifications
1). Main Rotor Dia. B : 450mm
2). Main Rotor Dia. A : 450mm
3). 53#8 Overall Length: 470mm
4). 53#1 Overall Length: 440mm
5). 53#8 All-up Weight: 365g (Battery included)
6). 53#1 All-up Weight: 359g (Battery included)
7). Main Motor: 2*370SH
8). Battery: 7.4V 1200mAh Li-Po
9).Servo: wk-7.6-3 / weight 8.5g / speed 0.11sec/60o(4.8V) / torque 0.9kg/cm (4.8V) / dimension 22.5*11.5*24mm
So it's slightly larger than the 53#1 and heavier
Old Aug 30, 2008, 06:33 AM
teammpp is offline
Northern Ireland
Joined Mar 2005
(2).Weight:410g;
Not quite the 500mm I heard but at least they are bigger than the Walkera which was close enough . Not got a price for them yet unfortunately. Im seriously doubting the 800mah battery will do the job. I believe the 370 motors will draw too much current from it after a few minutes flying. Probably take the extra couple of grams weight penalty and upgrade to 1200mah packs if they fit.
Old Sep 01, 2008, 07:30 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Price?
That heli is on par with a HBFP as far as size goes(19" rotor diameter). That makes it questionable for in- house use, so, it needs to be capable of outside flight, preferably in a little wind as most of us face. I'd be interested in a price. The KOB is the way to go!
kodak_jack is offline Find More Posts by kodak_jack
Old Sep 01, 2008, 08:49 AM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
In the E-sky catalog it's listed two ways.
As the "Big Lama" and as the "Outside Lama". Point being is that they plan on it being flown outside.
Barak1001 is offline Find More Posts by Barak1001
Old Sep 01, 2008, 11:01 AM
Velktron is offline
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
Isn't the "outside flight" capability all about being FP or CP? AFAIK, FP blades will always be a dog to fly outside in the wind, regardless of their size. So OK, this big bird may get more headspeed and lifting power, but won't it have the same wind vulnerability problems with the smaller Lamas? AFAIK the Walkera 53#1 is not all that wonderful either, so I'm curious to see if this one really makes a difference, and if so, why.
Old Sep 01, 2008, 02:48 PM
teammpp is offline
Northern Ireland
Joined Mar 2005
True. the walkera also suffers in wind. I actually crashed mine when a freak gust came round the side of the house. Caught it and sent it up above the height of the house (approx 35ft). I had to close the throttle nearly completely off to get it to come back down and then it fell like a brick. Full throttle but it wasnt enough and it bounced off the ground. Bottom bearing shattered and the tail exploded into bits. Gyro in the 4-in-1 unit hasnt been right since. Tail wonders around constantly. Hence the plan to purchase this Esky. Im using the walkera for a brushless dual swash conversion project.
Old Sep 01, 2008, 09:54 PM
Hokum Jim is offline
Find More Posts by Hokum Jim
This is what I want!!!
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
A thougtht for the Modders out there...
There are loads of 370 class brushless motors out there and the e-sky 4-in-1 is practically a RX + 3in1 once you take the cover off and pull the two boards apart (no soldering/desoldering required)... The thought of the doing a BL mod with the Walkera 53 wasn't a a pleasant one because the unknowns with the electronics and the control of the BL controllers (didn't stop me thinking of it though). On the surface it looks like a BL upgrade on this monster would be easier than a 340mm class Lama if not cheaper.
...and who can fault the promise of "...Happy Flight" !
Hokum Jim is offline Find More Posts by Hokum Jim
Last edited by Hokum Jim; Sep 01, 2008 at 10:47 PM. Reason: corrected 370mm to 340mm
Old Sep 01, 2008, 10:46 PM
Hokum Jim's Avatar
Brisbane, Australia
Joined Feb 2006
Just some more info...
The EC130 and the KOB are just 340mm 180 motor Lamas with new bodies... sorry to disapoint..
Here is the "official" E-sky product page for the big Lama they class in in their "500 series" which also includes the honeybee FP, CPs and HBKs
http://www.twf-sz.com/english/products.asp?prodid=0291
Just to dispell one misconceptions that I might have added to above it has a RX + 3-in-1 arrangement rather than using the Lama's 4-in-1. It's a bit annoying that they don't do a 2.4 G 6channel Rx Yet.
Still this is an interesting beast - was looking at the new sporty Walkera 53#8 now I might hold off until these things turn up at my favourite online hobby dealer... It's never to early to start dropping Christmas gift hints for the Wifey!
Last edited by Hokum Jim; Sep 01, 2008 at 11:01 PM. Reason: typos and adding extra comments etc. etc.
Old Sep 01, 2008, 11:43 PM
Perth
Joined Jun 2007
Well if you find someone offering decent shipping rates to Aus let me know
Old Sep 02, 2008, 12:16 AM
Hangar Rat is online now
Find More Posts by Hangar Rat
UK - in the middle somewhere
Joined May 2002
Originally Posted by Pirre
If your looking for a bigger coax maybe art-techs helis is of interest.
Here is a pic of a comparison btw lama and Eagle eye
For what it is worth, I saw the Eagle Eye flying in a hobby shop in Cape Town(South Africa) last week. It looked like a good machine, in fact so much so that I _nearly_ bought one! Unfortunately, I had to get it home to the UK and that was a problem. It flew rock solid (admittedly indoors) and looked impressive.
So, come on Esky, get yours out!
Cheers
Ratty
Hangar Rat is online now Find More Posts by Hangar Rat
New E-Sky Model #EK1H-E010 flightdeck-guy Micro Helis 1 Sep 10, 2005 09:51 AM
Yippee! New E-Sky 2 Sparky_500 Micro Helis 2 Jun 12, 2005 02:23 PM
Brand new E-SKY 3D $185 shipped RCdude1 Aircraft - Electric - Helis (FS/W) 0 Mar 25, 2005 03:56 PM
Brand new E-SKY 3D $215 shipped RCdude1 Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2005 09:48 AM
Fs: New E Sky Honey Bee 2 Ccmp sambo32 Aircraft - Electric - Helis (FS/W) 1 Jan 01, 2005 02:43 PM
