USA, LA, Mandeville
Joined Feb 2005
http://www.rcgroups.com/forums/showthread.php?t=779699
I have built two. Both plank on shadows from plans. the first was a Vanquish, on the above link, and the second is a Vektor. The second hull was really a plug, as I made a mold from it, so I could make more than one. |
Joined Dec 2003
I was going to suggest the Nimbus MKIII plans from sailsect , http://www.sailsetc.com/miscplans.htm because they are the most detailed plans you can buy for an IOM( a beginner can actually build a boat from the plans). It might not be competitve , but it would get you started. But you allready have one.
I have built a couple of US1 Meter hulls using balsa plank on frame. To keep the boats light you use very light weight contest balsa ( 7lb/ cu ft). For the Nimbus and triple crown IOM's , I used cedar and redwood. Weight is not as much a problem because of the min weight limit for IOM's and you can still make it under the min weight using heavier, sturdier wood( looks good too). I think balsa is much easier to work with though, because everything can be done with out power tools. If I was going to build an IOM with balsa I would use a much heavier density than for a US1Meter( like 10 -12 lb/cuft) its sturdier and its easier to find. I have heard foam board works good , but whatever you use, make sure it is stiff enough to hold its shape with whatever type planking you are going to use. Harder woods put alot of strain on the formers. The only real problem I had when planking with balsa ( and I was using very light soft stuff) was when I went to sand the hull smooth.The CA glue is much harder than the balsa and the hull sands unevenly.Thats not really a problem if your going to do alot of filling and sanding but it adds alot of unwanted time and weight. Try to keep the glue off the outside of the hull. You can use thick CA and put it between the planks toward the inside of the hull so it doesnt squish to the outside of the hull or glue from the back for as long as you can( as you work your way up from the gunwhales to the bottom it gets harder to fit your hand in from behind). I also used a glue called Sigment by SIG for one for one of the US1Meter hulls. Its softer than the softest basa so there is no problem with sanding. The only problem with it is, its slow to dry. Dont worry about glueing the heck out of the planks, you will be glassing the outside and probably the inside( recomended) too. I dont know if you have seen this but there is alot of good info for all R/C boats http://www.modelyacht.org/us1m/us1mcons.html Here is a link to the triple crown http://www.mya-uk.org.uk/suppliers/triplecrown.html Other good sites http://www.iom-nordic.org/index.php?...sk=view&id=131 http://navi.modelisme.com/article174.html you will have to run this through babblefish translater. http://www.myrc.org/Library/Library.htm#SailMaking http://rcboatbuilding.fotopic.net/c833706.html http://woodenstars.net/50107693b3137...f08/index.html again babblefish. |
USA, LA, Mandeville
Joined Feb 2005
Most of the plans I've seen have "3mm offsets" shown on the shadows. This allows you to plank with 1/8" balsa, then sand lightly and a layer of glass. I would remove the hull from the shadows, and build the deck right onto the hull, next. Once the deck is finished, glass the hull, and deck. The reason for building both halves is because you will need to wetsand the final layers of primer and/or paint and any balsa that can get water on it WILL mess up the finish! You will get to see all of your planking "print" through to the outer surface.
Try to get the balsa as smooth and ripple free as you can, before the glass. Use a single layer of medium glass, maybe 4-6 oz/yd2. If it is smooth enough, you can spray a coat of auto primer on it and sand to a "ready for paint" finish. Then a coat of finish paint, and you are ready to make a mold from it. read the info on mold making in the "Composites" forum, unless you have done molds before. Once your mold is ready, 2 layers of 6oz S Glass, or three of 4oz S Glass, with extra where the finbox and mast go, is what I have been using. I have a few photos posted on my flickr account, http://www.flickr.com/photos/hew_ham...7604340965096/ and a few on our IOM group, http://groups.yahoo.com/group/mbrciom |
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jun 2007
Great stuff man ...... i wish i can make the plug nicely like yours.
So first step is to make the plug from balsa, then paint it ..... and then lay fiberglass to get the hull right? Or lay a thick fiber glass on the plug, paint the inside, and lay the fiber inside the painted fiber to get the hull ..... i'm so confused man ..... If i'm using the plans from the website, are they to scale or i have to scale them. I'm looking at the vanguish and it seems to have lots of details plan. Noux2 is just the shadow but i'm not too sure if that has been off set to 3mmQuote:
USA, LA, Mandeville
Joined Feb 2005
The painting I am refering to is to the plug. The plug needs a layer or two of glass to make it durable enough to handle during the wetsanding/polishing. This is on the balsa, followed by primer and paint. THe plug must be as smooth and as polished as you want the final hulls to be. Primer and paint can be wetsanded and polished to a high gloss.
Once the plug is perfect, begin your molding process. 3-5 coats of wax to the plug. A coat of PVA mold release. Then a coat of tooling resin... thickened epoxy or polyester gel coat. Next is several layers of chopped strand FG mat, followed by several of 6oz cloth. Note, these are not all laid up at the same time. You have to watch the heat buildup if it is too thick a buildup at one time. The whole mold needs to be about 1/4" thick to prevent it from deforming over time, as the resin continues to harden. I added some feet to mine too, so it would sit nice and level on the table when ready to lay up a hull in it. Another cool thing about having a mold, is that you can spray a coat of paint into the mold, then lay up your glass and resin. It will pop out of the mold with a nice glossy paint layer on it. |
