| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 | |
I meant to do that!
#62 | |
I'm waiting on parts
The one comment my friend made was how quiet this heli is considering its running 4 big motors. It makes much less noise than my CX2 does which was very surprising to me. |
#63 |
registered user
hi, does anyone know how much weight these helis can lift?
#64 | |
No seriously, I have no idea what kind of payload it could really lift. This is already a VERY heavy heli for a coax and the motors and electronics get really hot after only a 5 minute flight or so. I think you would be pushing the heli to the point of failure if you attempted to make the heli carry any more weight than it already is for any significant amount of time. The ESC would most likely burn out from the increased amp draw.I have already set one on fire myself for other reasons. It already takes almost 3/4 throttle just to fly it as is. |
#65 |
canicrashhere2
I Took The Deal On The Vm
HEY thanks X i'm going to hold off on the lights to i see this paper weight fly again.Now heres somthing i could use some in put on when i got the twins the front wheel was broke off all the fuseage mounting rods were broke and there was only two rubber body mounts can you guys come up with some tips on how to fix this? i bought new landing gear but i can't find the body rods or rubber mounts for sale
thanks again CRASH |
#66 | |
I meant to do that!
I've considered using Trex body mounts and grommets, but there's nothing to screw them into. |
#67 |
I meant to do that!
Here's my body mounts and linkage adjustments. Also an image for size comparison for those of you who don't have one. That's my Lama V4, W38 and GL450.
#68 | |
Full stick deflection barely made it move for me.I also cant help but think that the long flimsy flexible plastic rods used to move the swash arrent helping much either. Seems a solid threaded rod or a little thicker CF rod would have more authority. |
#69 | |
registered user
#70 | |
#71 |
I meant to do that!
Grrrrr..
.. crashed my W38 today. Too much control response is not a good thing with a coax that has lots of blades. I had the damn thing leaning at about a 45 degree angle sideways when I got blade strikes in the rear rotor. Two blades sheared in half on contact and one more cut badly. I could not control it, so I had to drop it on the side of a hill. Other than the blades, no damage I can't fix. I didn't think there was that much wind!
#72 | |
#73 | |
I meant to do that!
I cut back on extents a little and added some electrical tape to the ends of the bottom blades. That trick works on a regular coax heli, but I haven't had a chance to try it yet on this one. Last edited by Balr14; Sep 28, 2008 at 08:44 PM. |
#74 |
canicrashhere2
Gentlemen Thanks For Your Help
Gentelmen your a fine example of r.c. helicopter mentors and i thank you for all your help and patience.Im just begining to start to think outside the box with this hobby.A sense of why not make my parts not buy them from the hobby shop and its from reading this thread.So thanks to eveyone,my question is what is the OD of the body mount rod.I found a site to buy cf rod but i don't have a mic. to check the size.
thanks i got to go CRASH |
#75 |
I meant to do that!
I haven't got anything to measure with other than an old metric ruler and bad eyesight. But, it looks to me like about 20mm. It's whatever size fits the tubing or grommets you plan on using to hold it. |
| Thread Tools | |
| Discussion Walkera HM 38# (Chinook tandem) | grizzjr1 | Multi Rotor Helis | 20 | Nov 07, 2009 12:51 PM |
| Discussion PiccoZ Tandem Chinook | rccary | Multi Rotor Helis | 0 | Apr 06, 2008 10:46 PM |
| For Sale Guillows P-38 large detailed scale kit | sammy | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 23, 2007 07:14 PM |
| Idea Mini tandem(chinook) | planedude91 | Micro Helis | 20 | Feb 08, 2007 08:30 AM |
| Discussion Lama2 or Walkera #5 convert to CHINOOK | suwat | Multi Rotor Helis | 7 | Jun 04, 2006 12:13 PM |
