| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 | |
I'm waiting on parts
#32 |
canicrashhere2
X-man You Are A Wild One
Sorry about the fire, well your are trying, can't find out unless you try.lets face it even nasa had problems when they started and look who they had working full time for them.some how x-man i can tell you won't give up and if you do come up with your brand of X-COPTERS i will be glad to crash test them for you! HEY TT thanks for the banana info
latter i got to go CRASH |
#33 | |
Its all back together and flying with the stock motors and the 12 T pinions and all is fine so Im done with this one Just going to enjoy it now and stop messing around with it.
#34 |
I meant to do that!
So, it's pretty good with stock motors and better battery? I can only find an ESC and receiver listed as parts for the W38. Doesn't it have a 3 in 1 and gyro?
#35 | |
I blacked out all the ally today while I had it torn down and I think it looks so much better than all the multicolored stuff that it comes with. Last edited by Xrayted; Sep 20, 2008 at 11:54 PM. |
#36 |
canicrashhere2
looks alot better X
i lost teeth on both inside gears the ones on the outside shaft wish i would have caught that before i ordered parts, oh well got me wondering about how tight my blades should be in the grips.i tighted them so the gear would spin before they fold useing my hand.too tight what do you all think
crash |
#37 | |
You should instantly kill throttle if it looks like you are going to crash or make blade contact with anything. If the rotors come into contact with anything while under power, the amp draw from the motors will skyrocket and possibly burn out your 4&1 controller. |
#38 |
I meant to do that!
Here's a dumb question. How do you get the rear wheels out of the fuselage? They are really in there tight and I'm afraid I'll break them if I try to twist them.
Otherwise, my first impression is that it's quite an unusual bird. It's very stable, but very challenging, at the same time. It's really affected by air movement near the ground, where it gains and loses altitude easily. It will drop like a brick with any little throttle movement. It flys like a large boat. It takes awhile to build up momentum in any direction and it wants to keep going that way. But, it looks cool flying. Last edited by Balr14; Sep 23, 2008 at 12:33 AM. |
#39 | |
The wheels are snap locked into the frame and the only way I could get mine out were to stick a screwdriver in from the top and pry it out. The plastic is soft and I broke one. Once the sqeeze lock tabs go into the mounts you no longer have access to them to reverse the proccess. I assume your doing this to get the canopy off so what I have done since is to just notch or slit the fuselage at the wheels to allow me to slip it on or off over the wheels. You will want to do this...trust me! Made my life much easier. Another suggestion I have for you is to use a Sharpie marker and mark top dead center on you RX pots if its trimmed ok. Walkera RX's have no end points and you can be adjusting + and may cross over into the - part of the pot as they just go in circles and start over. You can get very lost in the adjustments so marking them allows me to always go back to where I was if needed. One of them changes the servo throw and I had to make it give me max throw in order for the cyclic trim on the TX to have any effect. God luck Last edited by Xrayted; Sep 23, 2008 at 09:07 AM. |
#40 |
I meant to do that!
I wonder if a couple Xtreme Lama V4 LED flybars would work on the W38?
#41 | |
Ive never used those LED flybars before so Im not sure if they are prone to TBE issues or not?? Would be interesting though |
#42 |
I meant to do that!
You can buy just the ends with the LEDS in them. I was thinking blue LEDs in the front flybar and red in the rear flybar would be pretty cool for flying at dusk.
#43 | |
I only snapped off the front wheel so no real damage though.Even though this thing has some wight to it,the wind is still a huge pain! Even the slightest breeze flying last night would take ALL cyclic control away from me and make me fight to keep it in one place. Still looks so cool in the air though
#44 |
where can I buy these at?
TT |
#45 | |
Banana Hobby now has them as well and is a U.S. based supplier Last edited by Xrayted; Sep 24, 2008 at 04:55 PM. |
| Thread Tools | |
| Discussion Walkera HM 38# (Chinook tandem) | grizzjr1 | Multi Rotor Helis | 20 | Nov 07, 2009 12:51 PM |
| Discussion PiccoZ Tandem Chinook | rccary | Multi Rotor Helis | 0 | Apr 06, 2008 10:46 PM |
| For Sale Guillows P-38 large detailed scale kit | sammy | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 23, 2007 07:14 PM |
| Idea Mini tandem(chinook) | planedude91 | Micro Helis | 20 | Feb 08, 2007 08:30 AM |
| Discussion Lama2 or Walkera #5 convert to CHINOOK | suwat | Multi Rotor Helis | 7 | Jun 04, 2006 12:13 PM |
