Old Jul 24, 2008, 08:42 PM
aslvrfrostcsvt is offline
Find More Posts by aslvrfrostcsvt
United States, FL, Cooper City
Joined May 2008
my atlantic tug into a navy YTB new progress*UPDATE*see page 4
Well my wife went out and got me the atlantic tug for my birthday. As expected the revese was bad, however i had a stock tamiya TEU-101BK esc from my lunchbox and now i have awsome reverse with the stock radio . there is a slight delay for reverse but i can live with it.The next thing is working smoke .i have a few smoke generators from some of my smoke and sound 1/16 rc tanks that i plan on using. they work really well. Plan on changing the pilot house door to the side of the wheel house ,add some wood trim around the pilot house windows as well as change the top of the stack to more of a carol moran type. I also plan on adding more realistic accessories to the tug and finish it off with a navy paint scheme .any other ideas or opinions from you boat guru's would be great thanks.
aslvrfrostcsvt is offline Find More Posts by aslvrfrostcsvt
Old Jul 24, 2008, 11:03 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Sounds like you are off to a good start.
Can't wait for pictures...
Are the smoke generators similar to the ones seen on ebay?
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Jul 24, 2008, 11:34 PM
Joined May 2008
this is like the one i have the only difference is the case on mine is clear.
Old Jul 25, 2008, 08:02 AM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Another Atlantic Bash...
...excellent!
We will need lots of pics!
Capt. Crash
Capt.Crash is offline Find More Posts by Capt.Crash
Old Jul 28, 2008, 04:00 PM
Joined May 2008
what would be the proper U.S. navy colors to use on the deck and the cabin areas. the hull will be black .im going to try to scratch build a fire monitor station in front of the wheel house (see pic).and change the bumpers out for the rope style .i just hope it turns out as nice as the rc tanks that ive done.
Old Aug 01, 2008, 02:04 PM
Joined May 2008
well i did some work mainly on design for my tug. I extended the top deck out so i can put a fire monitor in front (see pics) but before i make the deck in plastic i want some opinions from you guys as to weather it comes out far enough or not .It looks fine to me but opinions are always a good thing.also what would be a good thickness for the styrene to get .
Old Aug 01, 2008, 04:16 PM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
She's geting there. Look very nice. Thank you.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Aug 01, 2008, 04:18 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Looks like the extended deck for the fire monitor is about the right size to me! should be neat with that mod. Keep up the good work!
You might also consider doing what Kmot did with his tug and lower the deck house a little- (I would keep the wheel house the same) really changes the look of the boat.
Aerominded is offline Find More Posts by Aerominded
Old Aug 01, 2008, 06:05 PM
Joined May 2008
i thought about lowering the deck house still might. here are some more pics. i decided to move the wheel house door to the side instead oh the back i think it turned out pretty good. ill have to remake the back wall should be simple enough. next will be lip molding around the back of the deckhouse then on to making the masts (any suggestions on what to use would be great).
Old Aug 01, 2008, 06:40 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Originally Posted by aslvrfrostcsvt
then on to macking the masts (any suggestions on what to use would be great).
Fishing rod / pole from the local thrift store..
Make sure its a 'hollow' type if you want to light up the mast though..
toesup is offline Find More Posts by toesup
Old Aug 01, 2008, 11:54 PM
Joined May 2008
see now this is why i post here. i would never have thought about using a fishing rod to make a mast .thanks
Old Aug 02, 2008, 12:16 AM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
i would never have thought about using a fishing rod to make a mast.
Have a look at http://www.rcgroups.com/forums/showp...&postcount=146
The ST Type tugs had tapered masts made of steel tube, a fishing rod 'section' was just the right taper...
Old Aug 03, 2008, 09:03 PM
Joined May 2008
about how tall did you make your masts (for reference)
Old Aug 03, 2008, 09:11 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
The fore-mast is approx 6" off of the wheelhouse roof and the stern mast is approx 11" tall from the main deck (It goes up through the upper deck).
There is a block inside the wheelhouse roof that acts as a 'socket' for the fore-mast for strength
Old Aug 04, 2008, 05:29 PM
Joined May 2008
Well ive done some more work on the tug today.Thanks to some ideas from toesup i now have my masts mocked up with the rear mast fire monitor platform to see how it looks.I planned on lowering the rear mast to the top edge of the lower blue tape .Let me know what you guys think . Ive also done all the body work on the wheel house and deck house and both now have their first coat of primer. when all is done the deck house and wheel house will be haze gray and the deck itself will be a darker gray, the hull will be either all black or black with the top side edge gray cant decide which (see pictures for reference)the last pic is what look im going for with the rear monitor.
Vote my new aerobatic plane in... kepople Electric Plane Talk 11 Jul 30, 2001 03:24 AM
My new site is open... kepople Electric Plane Talk 7 Jul 10, 2001 04:46 PM
My new Easy 3000 esc doesn't beep Al P Electric Plane Talk 3 Jun 15, 2001 09:27 AM
My New Twin-Jet (R.I.P.) Steven DiStasio Electric Plane Talk 12 May 28, 2001 07:38 PM
Help I cant get my new Jasto inline gearbox to fit my motor Joe Elston Electric Plane Talk 1 May 21, 2001 10:49 PM
