Old Jul 24, 2008, 06:21 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Help!
Quick Q: How do I mount this Park480 on my GWS-40? or: $20 shine on $3 pair of boots!
The guy at the hobby shop told me "good luck" when I said that I wanted to stick-mount an Eflite Park480 outrunner...
So are there other options that would place the motor far enough out to clear the cowl on the GWS-40? Has anyone done it?
The motor should be a blast in the GWS Warhawk if only I can get it mounted! It doesn't bother me that this is a $40 chunk of foam with a $70 motor. I like the way these GWS 'Birds go together.
Also, I am planning on making a balsa backing plate that would go behind the prop to glue the spinner cone on to...has anyone ever tried this?
Thanks for any insight.
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Jul 24, 2008, 06:28 AM
simonslim is offline
Find More Posts by simonslim
simonslim's Avatar
United Kingdom, England, Northd
Joined Nov 2005
I've tried the balsa backing plate and it worked fine, I just used UHU-POR so I could easily remove it if need be.
Simon.
simonslim is offline Find More Posts by simonslim
Old Jul 24, 2008, 08:16 AM
savageone is offline
Find More Posts by savageone
I work to Fly
savageone's Avatar
Lethbridge Alberta Canada
Joined Sep 2005
I would try to make a light ply fire wall as the park 480 has a ton of torque I'm sure it would rip the stick mount right out of the plane. do a quick search on the ultrafly p-40 thats t is in theirs and it's plenty strong enough.
savageone is offline Find More Posts by savageone
Old Jul 24, 2008, 09:44 AM
jismail is offline
Find More Posts by jismail
Joined Jun 2007
The GWS40 has 2 stick mount holes. The bottom hole is aligned for the GWS motors using their mount, the top hole is aligned for the outrunners. I have the 480 in my gws40 and just glued the stick inplace, cut it down to the appropriate length, and mounted the motor as usual. Not a big issue at all.
jismail is offline Find More Posts by jismail
Old Jul 24, 2008, 10:56 AM
hot glue is offline
Find More Posts by hot glue
Minnesota
Joined Jun 2007
Why would he say good luck? I use a stick mount on my E-flight P47 with a Park 480 and have never had any problems.
hot glue is offline Find More Posts by hot glue
Old Jul 24, 2008, 11:49 AM
Joined Jun 2005
savageone, thanks... I was looking into how the Ultrafly kit went together... until I saw jismail's post:
Nice! I love simple solutions.
And it doesn't torque out of place? Excellent... I have a GWS mount sitting around. I will try this when I get home.
Simonslim, glad to hear the back plate works! Thanks.
Old Jul 24, 2008, 11:50 AM
Joined Jun 2005
I guess he thought it wouldn't fit in the mount or that it would torque the stick out of the fuse.
Either way, he didn't think it would work. Per usual, it was too busy to get more than a couple word answer.. those guys are swamped... but they do the best they can.
Old Jul 24, 2008, 11:53 AM
Joined Jun 2005
Jismail,
How does the GWS-40 fly with the Park 480? Which prop did you go with?
I will probably run the stock 3 blade at first but I want to eventually move up to a 10x8 for some more speed...
Old Jul 24, 2008, 01:11 PM
jismail is offline
Joined Jun 2007
Jismail,
My first attempt was with a 11x7 cause I thought the spinner size limited the thrust to much. I burned up the ESC doing that (to much amp draw I guess) The second attempt was with a cheap LHS 10x8 and I hade issues with prop balance losening the stick. My last attempt was with a higher quality 10" Master prop (I can't recall if it is 10x6 or 10x8 and I can't verify without pulling the spinner) and it did the trick. Just be easy on the throttle and ramp it up to full RPM soothly.
here is a picture with the Master prop and Du-Bro spinner.
Old Jul 24, 2008, 06:43 PM
TopSpin is offline
Find More Posts by TopSpin
Leesburg, VA
Joined Jul 2005
That spinner looks like a perfect fit. You don't happen to have the DuBro part number do you?
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old Jul 25, 2008, 07:10 AM
Joined Jun 2005
Whoa.. what was the rating on the ESC you burned up?
Scary though. I will stick with the 10x6 until I can check with a watt meter.
The 3" DuBro spinner does look good... but IIRC its really heavy, no? I saw one at the LHS (only had black and white) and it seemed better suited to nitro planes... unless you have a different model there?
Old Jul 25, 2008, 10:19 AM
jismail is offline
Joined Jun 2007
It is heavy. I had to add weight to the tail to offset it. But the 480 has more than enough power to pull it up with the added weight.
Help! How do i mount the prop on this??? (and tail gear issue) ian_ryeng Beginner Training Area (Aircraft-Electric) 2 May 28, 2008 12:39 PM
Help! How do I mount the wing on ‘MY’ Edge 540 BoboG Giant Scale Airplanes 4 Mar 27, 2008 06:29 PM
Help! How do I get more vertical for my GWS P51 Mmarshall Power Systems 14 Mar 11, 2003 09:18 PM
How do i put the brake on my Jeti ESC fuzz Power Systems 2 Nov 29, 2002 11:53 PM
How do you mount your elevons on your Zagi? 177ichael Foamies (Kits) 8 Aug 03, 2001 10:54 PM
