Old Sep 07, 2001, 11:15 PM
CheeseWing is offline
Find More Posts by CheeseWing
Tantrums Rock!
CheeseWing's Avatar
Joined Jul 2001
Zagi THL . . . smallest motor for power?
I have not seen a Zagi fly, yet. I have read so much positive info. on these amazing wings and I am curious about powering a THL with a small motor an extra boost and good duration!
1)What small brushed motor would be suitable for good performance and duration?
2)What gearbox would be needed?
3)What prop would be best?
4)Got a link to powered Zagi THLs?
Thank you in advance!
CheeseWing
CheeseWing is offline Find More Posts by CheeseWing
Old Sep 08, 2001, 04:34 PM
Cadet is offline
Find More Posts by Cadet
Confirmed Adict
Cadet's Avatar
Malahat, BC, Canada
Joined Jan 2001
GOT a "E-THL" that I first used as a trainer to learn on then put a sp400 and 7x600ae into it, glides great and flies really slow for landing. Weight is under 17oz.
Cheers,
Grant
Cadet is offline Find More Posts by Cadet
Old Sep 08, 2001, 07:54 PM
totalboss is offline
Find More Posts by totalboss
Gaithersburg, MD, USA
Joined May 2000
Get a Zagi 400.
I have a THL I converted to s400 and 8x600 cells. It flies ok but it can't touch a Zagi 400.
If you want to slope soar buy the THL.
If you want an electric Zagi buy the 400.
I eventually plan on ordering a Zagi 400.
totalboss is offline Find More Posts by totalboss
Old Sep 08, 2001, 08:23 PM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
The Zagi 400 is a THL with a modified airfoil and a speed 400 power package. The THL airfoil is slower and better for thermalling if you like that. You could make a Zagi THL 400 by buying the tray, canopy, speed control, and battery pack from Trick. Before you do, you should realize what a great deal the Zagi 400 is. Hobby People sells the Zagi 400 for $109. If you add up the cost of just the power package you come close to that price.
John Gallagher is offline Find More Posts by John Gallagher
Old Sep 09, 2001, 11:51 AM
rparigoris is offline
Find More Posts by rparigoris
Kings Park, New York, USA
Joined Sep 2001
I am a THL Affecianato.
I have tried many a motor on the THL.
For light and powerful and cheap, try a Acro280BB (Hobby Lobby) or the equivilent Permex280BB. Be sure to use a 15 plus amp ESC. I am using a 20 amp Great Planes. Am using 8 S+R 575ma cells. You could use AR500 Sanyos, The AE 600s would work but would not keep up great. Awesome power and light. You need to advance the motor for reverse rotation. Running direct with 4.7x2.4 Graupner cam Folder.
For more money go for the astro 010, which is the same power with incredable run times. Astrobob is my hero for powering Zags. Oh yea the 010 is weigh lighter and you can use lighter batteries also too, ie 720ma NiMhs. I run Lithiums and get 45 minutes with no lift.
Ron Parigoris
rparigoris is offline Find More Posts by rparigoris
Old Sep 09, 2001, 09:51 PM
charles packard is offline
Find More Posts by charles packard
santa ana ca usa
Joined Nov 2000
Ron Parigoris
Ron is there any problem with the shaft on the 010 bending on landing?
charles
charles packard is offline Find More Posts by charles packard
Old Sep 10, 2001, 12:24 PM
Joined Sep 2001
charles
The 010 shaft is pretty thick, I would not think it a problem, tell me if I am wrong?
No problems to date, I am in pusher mode, and have a 4.7x2.4 Graupner Cam folder, so on landings it is folded or if you crash it just bends out the way.
Are there problems with bent shafts on the 010?
Ron Parigoris
Question Motor for power fan 400 ? Ks.jetflyer Foamy EDFs 0 Aug 17, 2007 09:48 AM
Discussion Rate This Motor For Power!!! Upside-Down Power Systems 6 Jul 16, 2006 01:05 AM
Discussion replacement motor for power fan rotccapt Electric Ducted Fan Jet Talk 7 May 08, 2006 06:03 PM
Nice Motor for power. WingMan33 Power Systems 0 Feb 22, 2004 09:54 PM
Smallest servo/Hitec servo for Zagi Thl? Ronbo Foamies (Kits) 4 May 10, 2002 12:11 AM
