Old Jul 23, 2008, 11:07 PM
adamak46 is offline
Find More Posts by adamak46
Adam
adamak46's Avatar
brier, wa
Joined Jul 2008
Question
Brushless Airplane motor in an rc car
ive noteced Brushless airplane motors and ESCs are alot cheaper then car ones
has any one heard of or put a Brushless airplane motor and esc in there car?
did it work?
which ones did you use?
adamak46 is offline Find More Posts by adamak46
Old Jul 23, 2008, 11:47 PM
Deestingray is offline
Find More Posts by Deestingray
I like boats
Deestingray's Avatar
Brisbane Qld Australia
Joined Jun 2006
Depends on the type of brushless motor you speak of. If you are talking about outrunner style motors then yes they are cheaper however they probably wouldn't go very well in a car. 1 reason that I can think of right now....
The KV of car motors say a touring car for instance start at around 3600 for a nice mild system, to get an outrunner in a 540 size to do that many rpm would be very hard. Most of the larger outrunners turn a lot more slowly per volt, they are designed for torque and in an airplane application, allow you to swing a big prop off it. Unless you wanted to climb hills in your tourer than it probably isn't the motor for you.
Brushess aircraft escs have no reverse also.
Having said that though, you can use them in rock crawlers successfully because they are all about torque and don't need any speed hence a much slower turning motor.
Deestingray is offline Find More Posts by Deestingray
Old Jul 24, 2008, 12:01 AM
adamak46 is offline
Adam
adamak46's Avatar
brier, wa
Joined Jul 2008
thanks
i dont know much about airplane motors
thanks much
Old Jul 24, 2008, 12:47 AM
igotit is offline
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
i put a ultrafly 29 kv ,with heli max 25 amp esc in my a&e rc18r,it went about 40 mph explosive acceleration,the only draw back was no reverse and i had to use my 4 ch plane radio to control the car,because plane esc's, your throttle stick has to be all the way back,so if you used your car radio you would have to hold your throttle stick in reverse before you turned the car on,also no brakes.
igotit is offline Find More Posts by igotit
Old Jul 24, 2008, 01:02 AM
TheTick is online now
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Car motors are typically 540 size inrunners. Alot of airplanes also use 540 size inrunners. Doesn't matter if its for a plane or a car. Alot of rc car guys don't know that they can get these motors for less than $20.
You can use plane speed controllers if you don't need reverse. You can use your normal transmitter if you program it right. They work great and you can get them for $15-$40 depending on the size of your car and how fast you want to go.
TheTick is online now Find More Posts by TheTick
Old Jul 24, 2008, 01:08 AM
Spoooooon!
TheTick's Avatar
Joined May 2003
double post
Old Jul 24, 2008, 01:18 PM
adamak46 is offline
Adam
adamak46's Avatar
brier, wa
Joined Jul 2008
well i was kind of thinking of buying a plane motor and car esc
would that work?
Old Jul 24, 2008, 03:41 PM
smart_racer is offline
Find More Posts by smart_racer
Canada, BC, Victoria
Joined Feb 2006
check out EZ Run motors and esc's
smart_racer is offline Find More Posts by smart_racer
Old Jul 24, 2008, 05:03 PM
I like boats
Joined Jun 2006
would that work?
If you are talking a garden variety car esc then no, it won't work. Brushless motors work differently to brushed. On a brushed motor you have 2 wires, on a brushless you have 3. You could go to www.r2hobbies.com they sell complete brushless systems for cars at a great price. They also sell reversable brushless escs at a pretty decent price also.
There are many inrunners that are available at a great price as TheTick has mentioned, you want a 540 size. For some pretty good speed, look for something around the 4000kv mark if you are going to run it on a stick pack. If you want to go to lipo however, you can run something like a 3S lipo, 11.1 volts. You will notice a huge increase.
If you can put up with no reverse and still want to use your aircraft esc in a car with a pistol radio, there is a product available that tells the speed controller to arm with the throttle position on the pistol transmitter. It is called a pistix and the only place I know of it available is at www.offshoreelectrics.com
I use an aircraft esc with a pistol transmitter in my boat and it works a treat.
Old Jul 24, 2008, 05:04 PM
Spoooooon!
TheTick's Avatar
Joined May 2003
There is no difference between a plane motor and a car motor. A 540 inrunner is a 540 inrunner.
Old Jul 24, 2008, 08:50 PM
adamak46 is offline
Adam
adamak46's Avatar
brier, wa
Joined Jul 2008
ok thanks
Old Oct 27, 2009, 02:31 PM
7ender is offline
Find More Posts by 7ender
United States, CA, Mountain View
Joined Feb 2006
Sorry to bump such an extremely old thread, but I have a question related to this-
How do you determine how many amps the motor will draw when put in a car? I have a 3500kv inrunner I was using in an old plane, and a 40 amp esc. Would I be able to move this over to one of my cars?
7ender is offline Find More Posts by 7ender
Old Oct 28, 2009, 11:05 AM
dgaumond is offline
Find More Posts by dgaumond
Joined Sep 2007
i worked to reprog airplane esc for working in car
i can reprog many atmega8 esc like mystery hobbyking towerpro 40 to 200A 2 to 6 cell
i'm testing it in racing 1/10 4wd B44 and working fine
i have lipo auto cutoff and throtle ajust
work very good with ezrun mamba feigao motor inruner
dgaumond is offline Find More Posts by dgaumond
Old Nov 06, 2009, 12:15 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
The only problem I can see with using a plane motor is that they are not sealed up at all. They are designed to let air into them and in a car this means dirt too.
1320fastback is offline Find More Posts by 1320fastback
Old Jun 22, 2011, 03:41 AM
gannusingh is offline
Find More Posts by gannusingh
Joined Jun 2011
hi guys, i have tried this stuff(connecting a heli motor to rc cars) few days ago, this is the cheaper way of getting a car motor. i think that it should work but only if u r using a rc car esc. the mistake that i made was, i used a heli esc which only allowed me to run my brushless only in 1 direction. this will give u full throttle but no change in direction.
hope u'll succeed in ur project.....my wishes to u.......
gannusingh is offline Find More Posts by gannusingh
Discussion Can i use an Align BL500L brushless motor in an ECO 8 BowerR64 Electric Heli Talk 13 Mar 07, 2008 12:54 AM
Brushless Tail motor with an Esky 4 in 1..??? Flyin Brick Micro Helis 10 Nov 02, 2005 04:50 AM
useing an heli esc in an RC car??! Fallengod Micro Helis 4 Jul 22, 2004 04:00 PM
My #1 "feature" in an RC ornithopter mhackney Ornithopters 16 Sep 30, 2003 02:06 PM
IPS vs. EDF motor in an E box MKH Parkflyers 8 Jul 10, 2002 11:20 AM
