Old Feb 01, 2003, 09:10 AM
SVX is offline
SVX
Find More Posts by SVX
SVX
SVX's Avatar
Joined Oct 2002
Need smallest retracts to support 25oz?
I would like to find a small (shallow) retract to fit in a plane that should come in at 20-25 oz. The dimensions that surfer was kind enough to give me of the Robarts were a little too deep. Any ideas?
Thanks, Dustin
SVX is offline Find More Posts by SVX
Old Feb 02, 2003, 03:20 AM
surfer is offline
Find More Posts by surfer
Brussels (Belgium)
Joined Nov 2001
dimensions
these are the dimensions:
-Block dimensions:
1 5/8 (41.3mm) lenght
29/32 (22.9mm) Wide (outside)
9/16 (13.7mm) wide (inside)
23/32 (18.2mm) max deep
-the 3/32 wire strut is really long and you cut it on dimension.
Hope it helps,
difficult to explain without the map but I can't scan it.
surfer is offline Find More Posts by surfer
Old Feb 02, 2003, 07:32 PM
SVX is offline
SVX
SVX
SVX's Avatar
Joined Oct 2002
Thank you much, that's just what I needed.
Dustin
1/2a Robart retracts in UK Robert May Electric Plane Talk 0 May 13, 2004 06:08 AM
Robart Retracts Wanted OBDoc Aircraft - Fuel - Airplanes (FS/W) 2 Apr 28, 2004 10:50 PM
WTB: Robart retracts/struts/air set gromitvt10 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 16, 2004 06:34 PM
WTB: Robart retracts/struts/air set gromitvt10 Aircraft - Electric - Airplanes (FS/W) 0 Mar 16, 2004 06:34 PM
