This thread is privately moderated by FieldofDreamsFlyer, who may elect to delete unwanted replies.
Old Jul 23, 2008, 07:20 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Trader Rating: 472
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Trader Rating: 472
Sold
Radio Shack Pro-94 Scanner Used Free Shipping
I have for sale a really nice scanner in great shape Works great here are the details of the scanner
$50.00 Shipped
Your RadioShack PRO-94 1000-Channel Handheld Trunking Scanner is one of a
new generation of scanners designed to track Motorola Type I, Type II,
hybrid analog systems, (such as Smartnet and Privacy Plus) plus GE/
Ericsson EDACS. Those systems are extensively used in many 800 MHz,
900 MHz, and UHF communication systems.
Trunking communications systems let a large group of 2-way radio users (or
even different groups of 2-way radio users) efficiently use a set of
frequencies. Instead of selecting a specific frequency for a transmission,
the user simply selects a talk group. The trunking system automatically
transmits the call on the first available frequency, and also sends (on a
different frequency called a Data channel) a code that uniquely identifies
that transmission.
Since the trunking system might send a call and its response on different
frequencies, it is difficult to listen to trunked communications using a
regular scanner. The Pro-94 lets you select and monitor the data channel
frequency sent with a 2-way radio transmission, so you can hear the call
and response for that user and more easily "follow" the conversation.
The scanner also lets you scan conventional transmissions, and it is
preprogrammed with service banks for convenience. By pressing a single
button, you can quickly search those frequencies most commonly used by
public service and other agencies, without tedious and complicated
programming.
This scanner gives you direct access to over 37,000 exciting frequencies,
including police and fire departments, ambulance services, and amateur
radio services, and you can change your selection at any time.
Your scanner also has these special features:
Triple-Conversion Circuitry - virtually eliminates any interference from
IF (intermediate frequency) images, so you
hear only the selected frequency.
20 Channel-Storage Banks - you can store up to 50 channels in each of
10 different banks, in two separate groups,
for a total of 1000 channels, so you can
more easily identify calls.
Five Scan Lists - you can store up to 50 trunking talk group
IDs in each trunk scanning bank.
NWR-SAME Circuitry - lets you listen to coded weather emergency
information using Specific Area Message
Encoding.
Two-Second Scan Delay - delays scanning for about 2 seconds before
moving to another channel, so you can hear
more replies that are made on the same
channel.
Lock-Out Function - lets you set your scanner to skip over
specified channels or frequencies when
scanning or searching, and skip over talk
group IDs when tracking trunked systems.
Priority Channels - lets you program one channel in each bank
(20 in all) and then have the scanner check
that channel every 2 seconds while it scans
the bank, so you don't miss transmissions on
those channels.
Five Service Banks - frequencies are preset in separate police
(fire/emergency), aircraft, ham, marine, and
weather banks, to make it easy to locate
specific types of calls.
Hypersearch - lets you set the scanner to search at up to
300 steps per second in frequency bands with
5 kHz steps, compared to the normal search
speed of 100 steps per second.
Hyperscan - the scanner automatically scans up to 50
channels per second to help you quickly find
interesting broadcasts.
Key Lock - lets you lock the scanner's keys to help
prevent accidental changes to the scanner's
programming.
Data Signal Skip - lets you set the scanner to skip non
modulated or data signals (such as fax or
modem transmissions) during searches. This
lets the scanner avoid non-voice signals,
making a search faster.
Disconnect Tone Detect - the scanner automatically tunes to the
trunking data channel when it receives a
disconnect transmission. You can turn this
off, so you can continuously monitor a
channel with a weak transmission where
conversations are often disconnected.
Manual Access - lets you directly access any channel.
Liquid-Crystal Display - makes it easy to view and change programming
information.
Display Backlight - makes the scanner easy to read in low-light
situations.
Flexible Antenna with BNC - provides adequate reception in strong signal
Connector areas and is designed to help prevent
antenna breakage. Or, you can connect an
external antenna for better reception.
Monitor Memories - lets you temporarily store up to 10
frequencies or talk group IDs.
Memory Backup - keeps the frequencies stored in memory for
an extended time if the PRO-94 loses power.
Three Power Options - lets you power the scanner using internal
batteries, external AC power using an
optional AC adapter/charger, or DC power
using an optional DC cigarette-lighter power
cable.
Key Confirmation Tones - the scanner sounds a tone when you perform
an operation correctly, and an error tone if
you make an error.
Battery Save - saves battery power when the scanner does
not detect any transmissions for more than 5
seconds when a channel is manually selected.
Battery Low Alert - warns you when battery power gets low.
Weather Alert Indicator - your scanner also functions as a severe
weather alert monitor.
Your scanner can receive these bands:
Frequency Step
Range (MHz) (kHz) Transmission
29-29.7 5 10-Meter Ham Band
29.7-50 5 VHF Lo Band
50-54 5 6-Meter Ham Band
108-136.9750 12.5 Aircraft Band
137-144 5 Military Land Mobile
144-148 5 2-Meter Ham Band
148-174 5 VHF Hi Band
216-224.9950 5 1-Meter Ham Band
406-420 12.5 Federal Government
420-450 12.5 70-cm Ham Band
450-470 12.5 UHF Standard Band
470-512 12.5 UHF "T" Band
806-956 12.5 Public Service "800" Band,
except cellular band
1240-1300 12.5 25-cm Ham Band
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Jul 23, 2008, 07:27 PM
johnbyrne is offline
Find More Posts by johnbyrne
Trader Rating: 90
Often wrong ("wife")
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Trader Rating: 90
Pro 35 or Pro 94? Big difference
johnbyrne is offline Find More Posts by johnbyrne
Old Jul 23, 2008, 07:36 PM
Trader Rating: 472
Joined Sep 2004
Trader Rating: 472
thank you johnbyrne its a pro-94
Old Jul 23, 2008, 07:51 PM
qualcity is offline
Find More Posts by qualcity
Trader Rating: 125
WHOHH..You See That??
qualcity's Avatar
Aurora, Colorado
Joined Jan 2005
Trader Rating: 125
PM Sent.
qualcity is offline Find More Posts by qualcity
Old Jul 23, 2008, 08:13 PM
tking2097 is offline
Find More Posts by tking2097
Trader Rating: 20
'Sky' King
tking2097's Avatar
Watauga, Texas
Joined Jul 2007
Trader Rating: 20
next in line if qualcity backs out....
pm sent
tking2097 is offline Find More Posts by tking2097
Sold 5 Hitec servos used free shipping FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 1 Jun 26, 2008 03:48 PM
Sold Radio South Pro-Driver II (used) (40$ shipped) adamg Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 11, 2006 10:47 PM
Yippee! Brand New Walkera Dragonfly 35 Z400 Cheap Free Shipping jtatarin Aircraft - Electric - Helis (FS/W) 157 Apr 25, 2005 12:42 AM
FS: Assorted batteries, rarely used, free shipping BrandoUno Aircraft - Electric - Airplanes (FS/W) 3 May 26, 2004 01:29 AM
Radio Shack PRO-25 scanner mods dmiller Electric Plane Talk 0 Jun 11, 2002 09:58 AM
