Old Oct 10, 2008, 12:15 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
I put a 'twang' hook on the heavier model, and have tried a few CLG launches, but it requires 1) full down trim and 2) a hard-to-find helper. I have also used a length of 3/8" or 1/4" flat rubber with light string with a wire ring to do traditional bungee glider launches. It flies on tow just like a big 2 or 3 meter glider on Hi-Start.
I still have some of the not-too-efficient K&P folders that was to be used on an old KP-00 motor, and think it and a 7 mm pager would make one of these little jewels into a micro hot-liner...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Oct 10, 2008, 05:15 PM
Higher is offline
Find More Posts by Higher
Nashville, Tennesse, United States
Joined Mar 2004
I've been watching your progress with great interest.This is very neat. I was outside moments ago thinking about one for myself. And as Mike says above, put a motor on that thing. There's no reason not to add one of the 2gm brushless beauties going around here onto this. I know you're really aiming for the hlg but, as light as this is and as consuming as this has become I'd hate to hear of you specking this out i.e. up up and away. A small motor would ad ballast for better penetration and give you a chance to get out of or into trouble.
Higher is offline Find More Posts by Higher
Old Oct 10, 2008, 07:04 PM
ginsu1797 is offline
Find More Posts by ginsu1797
Master of Nothing!!!
ginsu1797's Avatar
Orange county
Joined Nov 2002
Nice bird model Mike
I like the pods to hide the bricks as well. I have to make one to hide the Vapor brick I am using here
Scorpio FF glider converted to R/C (1 min 5 sec)
I am interested in everyone's progress. I put a Vapor brick on my Scorpio to hopefully hunt for thermals and to not have to walk as far. The Scorpio is a Rapier powered FF endurance model. I'm limited in where I can fly especially now that the field you see is offically off limits to me. I hope you all don't mind me posting here. I think were after nearly the same thing, I just don't have a good throwing arm
The light was going down and it was getting cold in the video. I know I'll get better times with some good air. For those of you thinking about using the Vapor brick, I highly recommend it. I did not have any range problems that day. I used a DX7 as the x'mitter.
ginsu1797 is offline Find More Posts by ginsu1797
Old Oct 11, 2008, 12:06 AM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
Charos/Mike,
Thats all very helpful info, I'm still learning the ropes on gliders, thanks for the info. Mike, do you know of any other small folding props?
Higher,
I couldnt agree more with you and Mike, turning one of these into something like a mini hot-liner would be really fun. This particular plane will remain a glider, but after putting a 7mm motor with the 16" version I did earlier, I'd love to give that a try with the next version. Ailerons and a v-tail would be a cool addition as well. Micro F5B anyone?
Cool video, ginsu1797, rocket assist is fun to watch. Any pics of the plane itself?
Nick
micro_builder is offline Find More Posts by micro_builder
Old Oct 11, 2008, 04:04 AM
irish_lord99 is offline
Find More Posts by irish_lord99
Balsa for me, thanks.
irish_lord99's Avatar
Yalova, Turkey
Joined May 2007
Nick, for small folding props you could make your own using old-school techniques from old free flight models. You'll probably find one if you browse through www.theplanpage.com . You'd need a prop balancer of course. Some of those old planes would even use a single blade prop with a counter weight on the other side. Pretty neat stuff...
~Jake
irish_lord99 is offline Find More Posts by irish_lord99
Old Oct 11, 2008, 10:03 AM
Team 30 Micro EDF
Joined Apr 2002
There is a large difference in the technology needed to carve a balsa folder spinning at up to 400 to 600 rpm than needed for an electric motor spinning 10 times as fast. I have some fairly large electric folders. The hub and blade shapes both are complex shapes, made with closer tolerances than I can replicate in the shop without being more work than it is worth.
However, given Gordon's classic work on making CF props, recent silicone molding threads, and the vacuum forming threads in other forums, someone with a proper tooling could make some cute units, but doing so is not the same as making one of the thread/tube/wire/balsa units.
Old Oct 11, 2008, 10:42 AM
Yalova, Turkey
Joined May 2007
Uh, yeah, that's...uh, true... wasn't really thinking when I posted I guess. It was just the first thought that came to mind. An impulse answer if you will.
~Jake
Old Oct 11, 2008, 02:54 PM
b36roxs is offline
Find More Posts by b36roxs
Joined Sep 2006
edit
b36roxs is offline Find More Posts by b36roxs
Old Oct 11, 2008, 03:06 PM
Team 30 Micro EDF
Joined Apr 2002
If someone has the tooling, like a lathe and / or CNC set-up, I see a micro-niche product here. A CF spinner, backplate and folder hub and blades of a couple of sizes, vacuum formed or injection molded in female molds, made to fit the little BL motors, incorporating a lock like on Uttam's prop adapters... You could kill a number of birds with a single product...
Single blade props probably aren't a good idea. Even on rubber nose assemblies, they eventually bend the shaft from the asymmetrical load - that would be a bad thing...
Old Oct 11, 2008, 04:13 PM
ginsu1797's Avatar
Orange county
Joined Nov 2002
Nick
Hi Nick, there's some build pics here http://www.jetex.org/scripts/yabb2/n...num=1220951693. I'd post them straight here but I am not at my pc at the moment. It needs some more work. I just slapped the brick on there for proof of concept. I plan to lighten it up in the future.
Old Oct 11, 2008, 11:41 PM
Joined Jan 2005
This is maybe just a little too small in diameter, or may not handle a BL motor, but its a thought: PU04 Mark II w/folding prop. Graupner also has a 4.7x2.4" folding prop with spinner, but again, I dont know if it would work - I dont think I've ever used a folding prop before.
That wing on your glider looks great, ginsue1797, nice and clean. Good luck with the future version.
Anyone have any 3 views of hot liner type planes?
Nick
edit: I was wrong, found this little 3.5" folder while looking for my stash of LEDs. I think it came from a big twin motor thrust differential steering plane, there should be a 2nd one, but I have no idea where it would be. It could be lightened quite a bit I think if it were to be used.
Old Nov 18, 2008, 06:50 PM
Charos is offline
Find More Posts by Charos
Sydney, Australia
Joined Aug 2008
Well I decided to go back to the drawing board.
Im going with an RC CLG concept this time around, although this first version here may stay as a chucky.
Specs for this one are 375mm (14.75" Projected span).
Weight is 23g.
I have plenty of ideas to reduce the AUW to about 18g and I also want to
get another 2mm or so extra depth into the wing for the PZ Brick, which should be possible.
Wing was made from 6lb/cu/yd next time I will use 4lb as well as a smaller 4mm diameter fuselage carbon tube.
I am less than happy with the current installation but it will do for the time being.
As you can see in the pics the only thing to finish off is to attach the push rods and a nose cone (which is the pull tab for the battery), other than that its complete.
Charos is offline Find More Posts by Charos
Old Nov 21, 2008, 08:59 PM
Joined Jan 2005
Looks good, Charos. I think the way you installed the brick is pretty good, it lets you keep the fuselage nice and skinny and doesnt look like it adds too much drag. Cant quite tell in the pics, but does that CF tube taper to a smaller diameter at one end? If so, where'd you find it at?
Early next week I'll be putting in an order for a new PZ brick finally and putting it in my little HLG. I finished the building on mine a month and a half ago and its just been sitting on the shelf staring at me ever since. It needs to see some airtime.
Let us know how the maiden goes
Nick
Old Nov 21, 2008, 11:21 PM
Charos is offline
Sydney, Australia
Joined Aug 2008
Nick
I obtained the wrapped carbon tube from "peck-polymers" they have 3 different sizes in stock. The one you see is the 6.8g tapered tube its about 6.7mm at one end and 4.5mm at the other.
I also bought some 4mm Carbon Lenny Tubes from there as well, I intend on turning them on the lathe to shave them down to 3g weight for the next model.
The main reason the PZ Brick is not seated as I would like is due to the large root dihedral which really makes it hang out in the breeze, I will rectify that next time.
Other than work keeping me busy, I just got a day off today but its blowing a gale, the outlook looks the same for the next few days.
I did manage to get it balanced and a few trial glides in the few brief moments of still air and it went rather well.
Will let you know how things progress.
BTW: Weight creep really set in and now this version is about 26g
MK2 Will see some improvements in weight, even though it too may have 6lb balsa wing, as I seem to have a stockpile of it.
Let us know how you fair when you get you PZ Brick.
Regards
Trent.
Old Nov 22, 2008, 04:04 AM
ginsu1797's Avatar
Orange county
Joined Nov 2002
Nice job hiding the brick Charos. That's slick.
Micro Hlg ???????? AIR MOVER Hand Launch 14 Aug 04, 2009 09:28 PM
bug micro hlg f/s ERGO60SX Aircraft - Electric - Airplanes (FS/W) 8 Nov 27, 2002 09:01 PM
Micro HLG Conversion Q's RB Scratchbuilt Indoor and Micro Models 1 Nov 10, 2002 09:44 PM
Anyone Fly the DAW Dragonette Micro HLG??? webguyjv Electric Sailplanes 9 Feb 20, 2002 12:44 AM
Albatoss micro HLG? cheapflyr Electric Sailplanes 6 May 26, 2001 11:52 AM
